Render Velocity values along a slice
Old   May 5, 2015, 17:49
Default Render Velocity values along a slice
Ashwin
lpashwin is on a distinguished road
I am a novice OpenFoam and Paraview user. I have run a tutorial case and I have converted the results into VTK using FoamToVtk. I would now like to plot/render a sliced view of the velocity values at a specific time step.
Below is the code I have so far. I am unable to figure out how to activate the velocity and display(/render/plot) it at different time steps.
## list of the time steps
time_step=[0,520,1021,1522,2023]
## File path
file_path="/home/lpashwin/to_home_server/tutorial_case/DTCHull/VTK/"
## Case Name
case_name="DTCHull_"
## File names
file_names=[file_path+case_name+str(ii)+'.vtk' for ii in time_step]
# Reading in the VTK Files (reader is the source as per the manual definition)
reader=OpenDataFile(file_names)
# Creating a Slice View
sliced_view=CreateView("MultiSlice")
sliced_view.YSliceValue=[1]
Show(view=sliced_view)
Render(view=sliced_view)
lpashwin is offline   Reply With Quote
Old   May 5, 2015, 18:01
Cyp
Cyprien
Cyp is on a distinguished road
You can use sample utility.
cp    $FOAM_UTILITIES/postProcessing/sampling/sample/sampleDict    system/.
Then edit this file to set up the plane you want to extract and the output format (vtk for instance, for visualization with paraview). Then run,
sample
Cheers,
Cyp is offline   Reply With Quote
Old   May 5, 2015, 19:45
Ashwin
Thank you Cyp for the quick response. I output a VTK file using Sample. Is there any quick and dirty way to create a jpeg file from the VTK files. I am running my simulations on a linux server and creating jpg files makes it easier to view the results on my windows based client.
pvpython vtk openfoam
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 10:08
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 23:38
how to extract velocity values from cells fromain STAR-CCM+ 2 May 27, 2015 15:12
Results of CFX Simulations Sof_70_Usthb CFX 3 July 9, 2011 07:15
Nodes positions + velocity and pressure values at the nodes Lily Kabanj FLUENT 1 March 13, 2000 20:21
