How to increase the output precision for a variable?
Like Tree6Likes
  • 3 Post By Lieven
  • 3 Post By wyldckat
Old   April 19, 2013, 15:31
Default How to increase the output precision for a variable?
Jack
ripperjack is on a distinguished road
Hi all,
I am using OpenFOAM to simulate channel flows. I have a problem, and you guys can help me? Thanks.
I specified a very small temperature difference on top and bottom walls (e.g. 300.005 at top and 299.995 at the bottom wall), it seems that the temperature precision is not enough because when I check the T output in the flow field, the results are just 300.004, 300.003, etc. But what I expect is more accurate T value, like 300.004142, 300.003125. I want to increase the precision of temperature, how can I do it?
Regards
ripperjack is offline   Reply With Quote
Old   April 19, 2013, 16:52
Jack
I have checked my openfoam configuration, the $WM_PRECISION_OPTION=DP. It seems that it is double precision, but the output results just have 6 valid digits, it is weird....
Old   April 19, 2013, 16:55
Lieven
Lieven will become famous soon enough
U can control the "writePrecision" in the system/controlDict file.
Just a small question, how meaningful is writing the temperature up to 5 digits after the decimal point. Can't you assume the flow to be isothermal?
Cheers,
L
wyldckat, ripperjack and A H Gazi like this.
Lieven is offline   Reply With Quote
Old   April 19, 2013, 16:59
Retired Super Moderator
Bruno Santos
Greetings ripperjack,
I was trying to make a witty comment, but I'm too burn out from the long week of work... oh well...
So, here's what's happening: OpenFOAM is doing exactly what you told it to do!
Check your "system/controlDict"; then check the user guide: http://www.openfoam.org/docs/user/controlDict.php
There are two very important details here:
  1. "writePrecision" - 6 is the default and is the number of digits stored in the files.
  2. "writeFormat" - well, you have to read both entries to figure it out, but the idea is that "binary" mode preserves the full data resolution!
Best regards,
Bruno
Old   April 19, 2013, 19:04
Jack
Hi Lieven wyldckat,
Many thanks for your reply! I am simulating heat transfer using DNS method, the velocity is very small, so is the temperature difference. Now my results make sense. Thanks again and have a great weekend!
Regards
OpenFoam-1.6-ext Allwmake compilation error - one last barrier Pat84 OpenFOAM Installation 15 July 25, 2012 22:49
Condensation as an additional variable Clark Griswold CFX 2 April 21, 2012 08:20
Additional variable as output of an expression Chander CFX 1 November 22, 2011 13:54
help !!!!variable output in cylindrical coordinate rohit Phoenics 3 September 8, 2004 22:28
How to output one variable which is not stored sun Phoenics 3 June 18, 2002 03:37
