How to calculate <w'T'>?
Like Tree4Likes
  • 1 Post By ripperjack
  • 2 Post By morard
Old   April 4, 2013, 16:18
Default How to calculate <w'T'>?
Jack
ripperjack is on a distinguished road
Hi guys,
I am simulating DNS channel flows using Openfoam, and I want to show contours of <w'T'>, where <> means average, w' is the z-direction velocity fluctuation, and T' is temperature fluctuation.
I tried to define a new variable Q=w*T and average Q by adding the following lines into system/controlDict. But it seems to be incorrect because it will calculate <(wT)'> instead of <w'T'>.
    fieldAverage1
        fields
            Q
                mean        on;
                prime2Mean  on;
                base        time;
I am thinking if I can add some lines into the solver to define <w'T'> as a new variables and output them correctly.You guys can give me some hint to do this? Many thanks!
tariq likes this.
ripperjack is offline   Reply With Quote
Old   April 4, 2013, 17:59
Lieven
Lieven will become famous soon enough
I guess the easiest way would be to do two simulations.
1. During the first run you calculate <w> and <T>
2. During the second run you read in <w> and <T>, and evaluate Q = (w-<w>)*(T-<T>) and take the average of Q like you are doing
I'm aware that this is a bit unfavourable from computational point of view, but I don't really see an other option. If you find one however, let me know! cause this is an interesting issue.
Cheers,
L
Lieven is offline   Reply With Quote
Old   April 4, 2013, 22:23
Jack
Cheers,
L
Hi Lieven,
Thanks very much for your reply!
Based on your suggestion, I am thinking may be I can do it in one run. I will try the following procedures:
1. Define new variables w (U.component(2)), wMean (<w>) and TMean (<T>) in solver and read their values from meshes (an initial value is given at start-time).
2. Define new variable Q=(w-wMean)*(T-TMean). (that is the instant w'T' value, not averaged one)
3. Add the following average lines in system/controlDict to calculate wMean, TMean, and QMean (that is <w'T'> we want).
    fieldAverage1
        fields
            w
                mean        on;
                prime2Mean  on;
                base        time;
            T
                mean        on;
                prime2Mean  on;
                base        time;
            Q
                mean        on;
                prime2Mean  on;
                base        time;
By doing this, at each running step, the solver will read wMean and TMean calculated by the above commands in system/controlDict. And based on the wMean and TMean, the instant w'T' is calcualted and then <w'T'> can be calculated.
I have added the lines mentioned above into my solver, and it is running, no error. However, I need to run a real simulation to verify if the above method produce correct results.
Cheers!
tariq likes this.
Old   April 5, 2013, 04:00
Dejan Morar
morard is on a distinguished road
Hi ripperjack,
you just have to add a new field in your solve, wT, and then average it. You wil also need averaged values of w and T. At the end, you can modify postChannel utility to calculate <w'T'>.
<w'T'> = <wT> - <w><T>
Regards
Lieven and ripperjack like this.
morard is offline   Reply With Quote
Old   April 5, 2013, 10:13
Jack
Originally Posted by morard View Post
Hi ripperjack,
Regards
Hi Morard,
Great! That the simplest way to do it! Thanks Morard!
Regards
[swak4Foam] Problem to calculate grad(U) using swak4Foam Hugoles OpenFOAM Community Contributions 12 November 24, 2020 11:28
calculate Nu number Diana.N FLUENT 3 February 27, 2012 14:40
How to calculate grid width in control volume Ingenierias2003 OpenFOAM 5 November 24, 2010 13:40
calculate values for eps and k from Re or u????? sbar OpenFOAM Pre-Processing 5 August 16, 2010 05:10
How to calculate Torque for francis turbine manish CFX 4 March 15, 2007 03:57
