June 8, 2012, 07:03 |
Moving mesh: how to fix a zone?
Samuele Z
Rep Power: 19 |
Dear All,
I have a problem with a moving mesh. I have 2 cellZones and I would like to fix one of them. What I wanna do is to make only one zone move. Is it possible? Thanks a lot, Samuele |
June 12, 2012, 07:46 |
Ivar de Hoogt
Rep Power: 14 |
I'm not sure, but my first hunch says that it should be possible to define the grid diffusivity to be much larger in the region you'd like to remain stationary than in the moving zone. That way, the deformation in the ''stationary'' zone will be negligable at least..
June 12, 2012, 07:55 |
Samuele Z
Rep Power: 19 |
Thanks Ivar,
any idea about how to do that? Thanks, Samuele |
June 12, 2012, 08:09 |
Ivar de Hoogt
Rep Power: 14 |
I do know of a few cumbersome methods, but as for an efficient one, I'm afraid I have to disappoint you. Might be that it's possible, but unfortunately, I'm not an expert..
A few options that I know of are: - inverseVolume grid diffusivity -> this is not really what you want, since it requires a high cell density in the stationary region, which is probably not of significant importance. - a specified list of grid diffusivity values (for each mesh point) - Define all grid lines in the stationary region as patches with uniform value (0 0 0) boundary condition for motionU (EDIT: this is for the 1.6-extend version interTrackFoam solver. I read in other posts that you use OF 2.1. The dictionaries might differ, but the general idea stays the same) Perhaps these give a hint to determining a better method, but it might depend on the case you're trying to solve. Last edited by Ivho; June 12, 2012 at 08:53. |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
Dynamic Mesh moving interface help | akash.iitb | FLUENT | 0 | August 24, 2010 00:53 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
Moving Mesh Run problem - Scientific Linux | G. SE | Siemens | 2 | May 7, 2008 08:15 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
