Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
Which equations are solved by rhoCentralFoam, rhoSimplecFoam and sonicFoam?
Old   March 16, 2015, 20:04
Default Which equations are solved by rhoCentralFoam, rhoSimplecFoam and sonicFoam?
Guilherme
gamma_user is on a distinguished road
Is there any documentation describing the system of equations solved by rhoCentralFoam, rhoSimplecFoam and sonicFoam? Since I am relatively new to OpenFoam, I am not quite sure about the meaning of the equations I found in the source code.
Thanks in advance.
gamma_user is offline   Reply With Quote
Old   April 19, 2015, 13:13
Hassan Kassem
hk318i is on a distinguished road
rhoCentralFoam was discussed before in this forum, you can search for it.
The original paper for rhoCentralFoam;
http://onlinelibrary.wiley.com/doi/1....2069/abstract
and you can check this paper as well;
http://www.cimec.org.ar/ojs/index.ph...File/4231/4157
If you are going to use rhoCentralFoam make sure that you are using the latest version of OF because the solver was updated recently.
Bw,
Hassan
Thanks in advance.
hk318i is offline   Reply With Quote
