Temperature in rhoSimpleFoam
Like Tree1Likes
  • 1 Post By tomf
Old   May 6, 2011, 12:46
Question Temperature in rhoSimpleFoam
Ammar Tareen
atareen64 is on a distinguished road
Hi all,
Does anybody know how temperature is handled in rhoSimpleFoam? I have a semi-complicated simulation that runs really well and I am getting great results for pressure and velocity but the temperature profile seems quite wrong. From the rhoSimpleFoam.C files I couldn't figure if enthalpy is taking care of temperature.
Basically, this might be stupid but I have no clue how temperature is solved for in rhoSimpleFoam or a simple loop in OF. Can somebody give me some insights?
Thanks a million,
~Ammar.
atareen64 is offline   Reply With Quote
Old   December 3, 2015, 08:59
Default rhoSimpleFoam
jcw
Christian Wolf
jcw is on a distinguished road
Hello!
I am facing the same problem. I try to simulate a radial compressor with pressure ratio about 2. I can not see any temperature rise. This behaviour is unphysical. OF2.3.
Does anyone have a hint?
Regards, JCW
jcw is offline   Reply With Quote
Old   December 3, 2015, 11:05
Olivier
olivierG is on a distinguished road
hello,
take a look at http://cfd.direct/openfoam/energy-equation/
... and also the source file EEqn.H for rhoSimpleFoam.
what did you use in you thermophysicalProperties ? enthalpy or internal energy ?
regards,
olivier
olivierG is offline   Reply With Quote
Old   February 11, 2021, 11:33
anthony761 is on a distinguished road
Originally Posted by olivierG View Post
hello,
regards,
olivier
Ok, I think I understand now ...
I observed same problem with a calculation of a centrifugal compressor.
OpenFOAM-v2006
Geometry: Centrifugal compressor, only one blade passage with cyclic/cyclicAMI (with diffuser vanedless and without volute)
BCs: flowRateInletVelocity with fixedValue temperature inlet and fixedValue pressure outlet
MRF model
Turbulence: kOmegaSST
Thermophysical: hePsiThermo/heRhoThermo, pureMixture, transport const, hConst, perfectGas, sensibleInternalEnergy/Enthalpy
Solvers: rhoSimpleFoam, rhoCentralFoam, sonicFoam
The pressure increased as expected at the exit but not the temperature which seems remain almost constant.
So is this due to the viscous heating term \mathbf{\nabla\cdot(\tau\cdot U)} missing in the energy equation? And probably the most important question: Why OpenFOAM doesn't include this term in energy equation?
It seems that lot of people is facing about this problem, see:
anthony761 is offline   Reply With Quote
Old   February 12, 2021, 06:28
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
It is usually not important for a lot of flows, but it is available via fvOptions in the OpenFOAM.com variants:
viscous dissipation fvOption
I do remember I once created something myself many years ago, but I would use that fvOption if I need it again.
Cheers,
Tom
anthony761 likes this.
tomf is offline   Reply With Quote
Old   March 1, 2021, 09:54
Originally Posted by tomf View Post
Cheers,
Tom
Thanks a lot! It's better behaviour is much more phyisical, I haven't my temperature level I have expected but I will continue to look for it.
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 07:36
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 18:31
High temperature methane+air Peter FLUENT 5 January 26, 2009 19:04
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
