simpleFoam turbulent flow laminar results
Old   September 19, 2011, 12:20
Nickolas P
NickolasPl is on a distinguished road
Hello everybody,
I have simulated turbulent air flow in a complex geometry at the past and I had a lot of problems concerning the values for the k-epsilon model. I am attaching a link that I found after hours searching at the internet that it was extremely helpful for my case. Maybe this can give you more insight concerning your matter. My results were far better than I expected!
http://ebookbrowse.com/tutorial-mino...-pdf-d74878981
Cheers,
Nickolas
NickolasPl is offline   Reply With Quote
Old   September 28, 2011, 08:00
Miles
miles_davis is on a distinguished road
Hi Nicolas,
Why are you mentionning a ref point for pressure in the transportProperties file?
I thought it was in the fVsolution file?
regards,
miles_davis is offline   Reply With Quote
Old   March 25, 2016, 13:31
LeeRuns is on a distinguished road
Originally Posted by NicolasB View Post
My last case is set up using this tutorial http://www.me.psu.edu/cimbala/Learni...e_OpenFOAM.pdf
changing the tolerance and relTol in the fvSchemes. Even if simpleFoam is steadyState, I've also changed the deltaT according to this document.
I've checked the U_mag in Paraview after 300it (just before leaving the office) and once again the flow seemed to be laminar. I haven't look at the stability with probe point.
That's something wrong with my case, but I don't know where ...
I'll try with a basic elbow tomorrow. This one is a bit elaborate (or do we say chased ?): that's why I can't share it.
this link is broken can you please update with a new link to the PDF?
LeeRuns is offline   Reply With Quote
laminar, simplefoam, turbulent
SimpleFoam as Newtonian laminar flow solver titio OpenFOAM Running, Solving & CFD 2 March 8, 2013 05:44
Can I use turbulent model to solve a laminar flow? nikhil FLUENT 5 February 1, 2011 11:42
Is this understanding of turbulence models correct? 3kha Main CFD Forum 3 January 31, 2011 22:31
Pressure driven laminar flow simpleFoam pressure higher at the outlet than inlet gabriel OpenFOAM Running, Solving & CFD 16 September 30, 2009 19:20
laminar and turbulent flow over a single airfoil. Pablo Cornejo FLUENT 0 August 30, 2005 18:57
