Rep Power: 17 ![]() |
Dear Foamers,
I'm currently running a simulation with theses settings : - Launder Sharma KE for turbulence model - RANS - SimpleFoam solver what I would like to know is typical values of epsilon near the walls? I know I have to impose a BC epsilon <<<< 1 at the wall for Low-Re model. Right now I'm running a simulation and I'm getting values of epsilon of 6000 - 8000 near the walls. Is it possible? Where could I find information about this? Thanks for your help |
#2 | |
maddalena
Rep Power: 23 ![]() |
what I usually do whit the same turbulence model and solver as you is to use a zeroGradient BC for both k and epsilon at the wall... Hope this help, cheers, mad |
About boundary conditions, I'm sure @99% that setting k and epsilon @0 @walls is the way to do it. Well, actually not zero but a very low value as 1e-06 for example.. I've seen someone skilled in turbulence to check my simulation and he thinks that my results are good. I get epsilon values of about 5000 - 10 000 near the walls and to him, this is logical. Regards |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 16 | March 4, 2017 09:30 |
k and epsilon Values for High Pressure Water | nikhiljain.iitk | FLUENT | 0 | March 12, 2010 07:06 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 21:21 |
K epsilon values | Adrian | FLUENT | 3 | September 26, 2008 12:16 |
Modify, G_k,k and epsilon values on wall functions | Javier Larrondo | FLUENT | 0 | September 15, 2008 22:34 |
