OF Compressible equations SIMPLE/PISO
Like Tree5Likes
Old   May 18, 2010, 15:23
Alberto Passalacqua
Originally Posted by truong_nm View Post
How many sub-iterations (nOuterCorrectors) do you recommend to me ?
Hard to say given that the only know I think are the solver you're using and the type of the BC's
I can only say you need a number that makes your solution converge.
Best,
Alberto Passalacqua
Old   May 19, 2010, 15:16
Ngoc-Minh Truong
truong_nm is on a distinguished road
Send a message via MSN to truong_nm
I made some investigations and I think that I will keep rhoPisoFoam + SLTS. This duo gives me the best convergence/accuracy/speed.
truong_nm is offline   Reply With Quote
Old   September 2, 2010, 13:56
Nilesh Rane
nileshjrane is on a distinguished road
Hello truong_nm,
i am quite new to OF so dont know much about it. Can you please tell me how to make this "rhoPisoFoam + SLTS" thing work?? how to set it up?? What needs to be modified??
Thank you,
Imagination is more important than knowledge..
nileshjrane is offline   Reply With Quote
Old   August 15, 2011, 15:25
Ashish
gashishr is on a distinguished road
Ngoc-Minh Truong: It seems you have good experience in OpenFoam. I am very new to it. I want to solve steady state airoil problem for Mach 0.3 to 0.9. I am very confused with the solver. Can you suggest me suitable solver?
gashishr is offline   Reply With Quote
Old   August 16, 2011, 03:03
Alberto Passalacqua
Take a look at rhoCentralFoam.
Alberto Passalacqua
Old   November 29, 2011, 23:16
Daniel
dancfd is on a distinguished road
Entered in error, my apologies.
Dan
dancfd is offline   Reply With Quote
Old   November 30, 2011, 01:47
Alberto Passalacqua
@daniel: I received the notification of your comment. rhoCentralFoam has turbulence models in OF 2.0.x, while it did not have them in previous versions. :-)
Best,
Alberto Passalacqua
Old   November 30, 2011, 12:04
Default cyclic boundary conditions in sonicFoam!
  #28
giovanni silva
giovanni10 is on a distinguished road
Has anybody ever used cyclic boundary conditions in sonicFoam?
I have used them in mhdFoam ( a solver for magnetohydrodynamics (MHD): incompressible, laminar flow of a conducting fluid under the influence of a magnetic field.). As far as this solver concerned, everything worked well! Nevertheless, when I tried to use cyclic boundary conditions in sonicFoam I had errors!I don`t know how can I write the cyclic boundary conditions for the pressure. I have a 2-D cavity.
For example in sonicFoam/laminar/forwardstep/0/p:
outlet
type waveTransmissive;
field p;
phi phi;
rho rho;
psi psi;
gamma 1.4;
fieldInf 1;
lInf 3;
value uniform 1;
when I want to declare it as cyclic , I can write:
outlet
type cyclic;
But I have errors!
Could everybody help me?
Thanks in advance!
giovanni10 is offline   Reply With Quote
Old   December 4, 2011, 22:31
Daniel
Thank you, Alberto, for clearing that up.
Regards,
Dan
Guide: Writing Equations in LaTeX on the CFD Online Forums pete Site Help, Feedback & Discussions 27 May 19, 2022 04:19
Grid generation and Compressible Euler equations oe Main CFD Forum 7 September 8, 2008 22:28
trying to solve 2d compressible euler equations dave Main CFD Forum 4 July 16, 2003 10:08
Navier-Stokes equations in compressible flow GACEM Hatem Phoenics 1 June 3, 2001 06:30
3d discretisation of compressible NS equations sanku Main CFD Forum 1 January 30, 2000 22:01
