April 16, 2009, 16:41 |
totalPressure in rhoSonicFoam
Mihir
Rep Power: 17 |
hello im trying to simulate a supersonic free jet . I tried to impose totalPressure boudary condition at the inlet :-
type totalPressure; U U; value uniform 0; phi phiv; rho rho; psi psi; gamma 1..4; p0 uniform 1e5; However i get the following error #0 Foam::error:rintStack(Foam::Ostream&) at OSspecific/Unix/printStack.C:203 #1 Foam::sigFpe::sigFpeHandler(int) at OSspecific/Unix/signals/sigFpe.C:130 #2 Uninterpreted: [0xffffe420] #3 void VectorSpaceOps<3, 0>:pVS<Foam::Vector<double>, Foam::VectorSpace<Foam::Vector<dou ble>, double, 3>, double, Foam::divideOp3<double, double, double> >(Foam::Vector<double>&, F oam::VectorSpace<Foam::Vector<double>, double, 3> const&, double const&, Foam::divideOp3<dou ble, double, double>) at ~/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/VectorSpaceM.H:34 #4 Foam::Vector<double> Foam:perator/<Foam::Vector<double>, double, 3>(Foam::VectorSpace< Foam::Vector<double>, double, 3> const&, double) at ~/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/l nInclude/VectorSpaceI.H:512 #5 void Foam::divide<Foam::Vector<double> >(Foam::Field<Foam::Vector<double> >&, Foam::ULis t<Foam::Vector<double> > const&, Foam::UList<double> const&) at ~/OpenFOAM/OpenFOAM-1.4.1/sr c/OpenFOAM/lnInclude/FieldFunctions.C:509 #6 void Foam::divide<Foam::fvPatchField, Foam::Vector<double> >(Foam::FieldField<Foam::fvPa tchField, Foam::Vector<double> >&, Foam::FieldField<Foam::fvPatchField, Foam::Vector<double> > const&, Foam::FieldField<Foam::fvPatchField, double> const&) at ~/OpenFOAM/OpenFOAM-1.4.1 /src/OpenFOAM/lnInclude/FieldFieldFunctions.C:626 #7 void Foam::divide<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>(Foam::Geometr icField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<Foam ::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Fo am::fvPatchField, Foam::volMesh> const&) at ~/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude /GeometricFieldFunctions.C:563 #8 Foam::tmp<Foam::GeometricField<Foam::Vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>(Foam::GeometricFi eld<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<do uble, Foam::fvPatchField, Foam::volMesh> const&) at ~/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/l nInclude/GeometricFieldFunctions.C:563 #9 main at ~/OpenFOAM/OpenFOAM-1.4.1/applications/solvers/compressible/rhoSonicFoam/createF ields.H:96 #10 __libc_start_main in "/lib/libc.so.6" #11 __gxx_personality_v0 in "/home/msamel/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGcc DPDebug/rhoSonicFoam" which obviously a FPE error due to division by 0. It mostly occurs while calculating rhoE . what can be the error in initializing the totalPressure BC in the above manner ??? with a fixedValue bc for pressure, the code runs absolutely perfect !!!!!!!!!!! |
Problem when running rhoSonicFoam solver | gaottino | OpenFOAM Running, Solving & CFD | 3 | March 1, 2011 05:59 |
variable Time step in rhoSonicFoam | mihir1310 | OpenFOAM Running, Solving & CFD | 2 | March 31, 2009 12:22 |
TotalPressure %3d data to specify | floooo | OpenFOAM Running, Solving & CFD | 0 | December 8, 2008 04:58 |
RhoSonicFoam | srinath | OpenFOAM Running, Solving & CFD | 0 | May 30, 2008 02:21 |
RhoSOnicFoam | shuo | OpenFOAM Running, Solving & CFD | 2 | November 6, 2006 01:25 |
