Changing time integration in dieselEngineFoam
Old   March 20, 2009, 04:56
Default Changing time integration in dieselEngineFoam
Andrea Aprovitola
AndMOT is on a distinguished road
I'm a novice in the field of engine simulation and in the use of OpenFoam so be patient ...
My objective is to perform some simulations with dieselEngineFoam. I noticed that in fvSchemes file, the discretization in time is performed with a first order scheme by default. So I'm inquiring if this kind of accuracy should be improved by using a 2nd scheme in time at first glance such as the backward one, or the first order is enough for this kind of simulation.
However with the 2nd order schemes the constraint imposed by the Courant number should requires a small time step with expensive computational cost.
thanks,
Andrea
AndMOT is offline   Reply With Quote
Fourth Order Runge Kutta time integration lr103476 OpenFOAM Running, Solving & CFD 45 November 10, 2022 03:36
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
DPM: Particle Tracking Madhukar FLUENT 1 July 24, 2007 04:51
Doubt on Implicit Methods analyse In India Main CFD Forum 10 March 9, 2007 04:01
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 13:32
