July 3, 2006, 18:11 |
I am new to CFD and I
larry
Rep Power: 17 |
I am new to CFD and I am toying around with the tutorial examples provided by OpenFoam. I am experiencing this problem with engineFoam. I generate the mesh (mesh-generation ---> blockmesh), then I try visualizing it with parafoam using: paraFoam /home/lorenzo/OpenFOAM/OpenFOAM-1.3/tutorials/engineFoam kivaTest but then paraFoam crashes with the output: --> FOAM FATAL ERROR : Cannot find file "points" in directory "constant/polyMesh" From function Time::findInstance(const word& dir, const word& name) in file db/Time/findInstance.C at line 133. FOAM exiting Why is "points" not created? I did not have this problem when trying the icoFoam case following the pdf guide. Any suggestions? Furthermore, is there anything like a collection of OpenFoam codes? For instance, in my case I need to model the flow coming from the mixing of the air out of two pipes (same axis, one injecting air inside the other), but I am finding it hard set it up correctly (starting from the mesh generation) Many thanks Lorenzo |
Collection Efficiency in Fluent? | Jason | FLUENT | 8 | May 5, 2015 04:18 |
Collection of simple functionObjects | gschaider | OpenFOAM | 48 | July 31, 2014 11:06 |
NASA COSMIC COLLECTION | D.D | Main CFD Forum | 1 | May 18, 2006 14:20 |
Collection efficiency | Jen | FLUENT | 0 | November 16, 2005 11:16 |
Data output collection | simon | Main CFD Forum | 0 | September 29, 2003 10:03 |
