Incompressible axisymmetric sudden expansion
Old   June 17, 2008, 18:00
Default Hi I have been running a si
samarth saurav
samarth is on a distinguished road
Hi
I have been running a simulation for an axisymmetric device with a sudden expansion. The working material is Nitrogen. I have run the simulation using fluent and openfoam. The results that I got from fluent are closer to experimental results that I got from a paper. The boundary conditions that I used in fluent are :
1)entrance : Constant inlet velocity of 1 m/s.
2)Wall: Adiabatic no slip
3)Exit: Constant pressure 1 atm (zero gauge)
I am getting a difference in the solutions that I get from both softwares. The solutions are qualitatively similar. The difference lies in the reattachment lengths. Fluent gives me a reattachment length that is closer to the one mentioned in the paper. Am I making a mistake in the boundary conditions in openfoam.
The bc's in openFOAM are as follows
boundaryField
velocity-inlet-6
type fixedValue;
value uniform (1 0 0);
pressure-outlet-5
type zeroGradient;
wall-4
type fixedValue;
value uniform (0 0 0);
Thanks in advance for any help
samarth is offline   Reply With Quote
Flow in a sudden pipe expansion John Haynes Main CFD Forum 4 December 1, 2008 10:23
Recirculation Length in Sudden expansion Manu CFX 1 June 12, 2006 07:46
Pressure loss due to sudden expansion in pipe flow Ahmed FLUENT 0 January 2, 2006 11:01
Sudden expansion problem yongha Siemens 0 August 16, 2002 08:10
heat transfer in sudden expansion flow Adrian Yeap Main CFD Forum 1 October 27, 1998 11:15
