February 11, 2010, 10:28 |
#61 |
Margarita DUFRESNE
Rep Power: 16 |
Hi Morfeus80,
I have 7 years experience in R&D in automotive industry. The turbulence wake modeling is bit difficult, you can use k-eps model with mesh iterative improving (less complicated), or RSM model (very high grid squeness needing). KR, MDZ |
May 12, 2010, 10:45 |
#62 |
Hi Margarita,
would you recommend using a low Reynolds model with y+ values around 1 on the wall of the vehicle and a coarser mesh on the floor but with a slip condition on pressure and velocity? I'm questioning whether to use a high or low Re model and so far the high Reynolds with wall functions has done well but maybe LowRe would do even better (especially in detached zones)? Thanks for your insight! -Louis |
June 18, 2010, 10:11 |
#63 |
stephane sanchi
Rep Power: 18 |
can someone provide me the geometry file (iges format preferably) of the Ahmed body with 12.5 degree slant angle ? My email address is : stephane.sanchi@cfse.ch Best regards, Stephane. |
June 18, 2010, 16:35 |
#64 |
I will provide you a STL surface for snappyHexMesh if you agree to share your results on the forum after.
Cheers! -Louis |
June 18, 2010, 17:03 |
#65 |
stephane sanchi
Rep Power: 18 |
Hi Louis,
Yes, I just want to reproduce the results you have obtained and will present during the 5th OpenFOAM workshop in Chalmers ! I will use both snappyHexMesh and ICEMCFD Hexa for mesh generation for comparison. Regards, Stephane. |
June 24, 2010, 05:09 |
#66 |
Very nice. I am sending you the mesh shortly. Also, you might find better graphics in my presentation, which should be available on the OFW5 website.
Regards, -Louis |
July 1, 2010, 06:09 |
#67 |
Moritz Wied
Rep Power: 16 |
hi Louis,
have you made any progress with low-re modelling of the ahmed body? i'm on it for quite a while now with lam-bremhorst, but still have not reached convergence. i tried to make a laminar start and then switch on turbulence, but still epsilon diverges after a while in the subsurface layer. for the bc i use zeroGradient at the inlet for k and epsilon and slip on top, bottom, left and right for everything. i also used a lot of combinations of k and epsilon as initial conditions. so there is only a sublayer at the body, i tried different amounts of layers, up to 40. the cell closest to the wall is 0.05 mm diameter, the mesh is a polymesh made by ccm+ and the fvSchemes for convection are all set to upwind. as you seem to work on low-reynolds as well, it would be great to exchange our experiences. my plan now is to make just a cylinder flow and get this to converge with low-re to get the most stable schemes and relaxation factors. all the best, moritz Last edited by Mo-ITB; July 1, 2010 at 19:09. |
July 1, 2010, 11:31 |
#68 | |
Moritz,
Stephane, can you post your questions here, it will be easier for me to reply and allow others such as Moritz to follow our discussion! Best regards, -Louis |
July 1, 2010, 14:30 |
#69 |
Moritz Wied
Rep Power: 16 |
Hi Louis,
i use OF 1.6. At the beginning i had bc for k and eps at the inlet, but this always led to divergence in the boundary layer i used for the bottom. with zeroGradient and the initial conditions calculated by the equations given on cfd-online, i only have problems of divergence on the body itself. what characteristic length and turbulent intensity do you use? i tried different values for both and the best till now were: - 1mm for characteristic length, 0.5 mm turbulent lenght - turb. intensity 5 % that gives the initial conditions: - k=6 - epsilon= 26454 - nut= 0.0012 this was running quite well for 140 iterations, i also got the cd of 0.38 perfectly ( i have 30 deg ahmed body), but then epsilon rises till divergence, mostly on sharp edges or arround the feet. i used the slip condition on the floor to prevent epsilon from diverging here, which is working . when i used bc for k and epsilon, i saw in plots that nothing of that reached the body itself, it was only important for the boundary layer at the inlet. as i use slip, i have no boundary layer at the inlet, so i guess no need for a bc. could you post the url where to find your slides? i just found this one: http://www.openfoamworkshop.org/2010...itle=Main_Page but didnt find your slides. all the best, moritz |
July 1, 2010, 15:02 |
#70 |
stephane sanchi
Rep Power: 18 |
July 1, 2010, 15:47 |
#71 |
Moritz Wied
Rep Power: 16 |
hi stephane and louis,
thanks for the link, but for me its not working . Attached are some pics of my case where you can see the problem zones of epsilon behind a foot of the ahmed body. it seems its the stall zone... any ideas what to do to prevent this? i thought about thinner layers, but i already got 0.05 mm... having a look at the nut plot makes me wonder if the values are reasonable. may it be they are much too low and so the turb. layer at the surface cannot be build up properly? U.jpg k.jpg epsilon.jpg symmetry_k.jpg symmetry_U.jpg |
July 1, 2010, 23:49 |
#72 |
Moritz,
I used 0.5% turb int. and 3cm boundary layer to calculate char length. 5% turb int seems pretty high. Maybe you should try the new wall functions. There is nutSpalartAllmarasWallFunction, LowReWallFunction, etc.. that way you know what is being done at the wall instead of using zeroGradient.. Best, -Louis PS: maybe it's just a matter of make your boundary cells shorter (like cutting them in two on the long axis?) |
July 2, 2010, 02:50 |
#73 |
Moritz Wied
Rep Power: 16 |
Hi Louis,
are the new wallfunctions part of OF 1.7? best, Moritz |
July 2, 2010, 03:41 |
#74 |
Alberto Passalacqua
Rep Power: 36 |
Yes (at least the low-Re ones): http://www.openfoam.com/docs/release-notes.php
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
July 2, 2010, 05:05 |
#75 |
Moritz Wied
Rep Power: 16 |
how is the low-re-wallfunction working? is it like in lam-bremhorst a function which is added to the eps, k and nut equations or like standard-k-e a function which replaces the eps, k and nut equations?
July 2, 2010, 09:19 |
#76 |
Should be.
I use 1.6.x and they are available. Look for source files in Code:
src/turbulence/incomp/derivedFvPa/RAS/wallFunctions Also, be aware that the spalding function (nutSpalartAllmarasWallFunction) will not work if you have a zero velocity on the wall, the trick is to set the velocity to something like (0 0 1e-10). To use these new functions, set them in the nut file of the 0 directory and use kRqWallFunction on corresponding k and omegaWallFunction on omega. Values = 0 might be required but not used and values of constants (C_mu, etc) are not necessary in these files.... Sorry I don't have the files in front of me so I'm telling you this by memory. Best, -Louis PS: what meshing software are you using on the Ahmed body? |
July 2, 2010, 12:57 |
#77 |
Moritz Wied
Rep Power: 16 |
here is what i did till now:
when chosing lam-bremhorst i use no wall functions, because in low-reynolds-models there are correction-functions (f1 and f2) implemented in the equations for k, epsilon and turb.visc. for cells close to patches (they depend on the distance from the patch) which simulate the increased turbulent viscosity there and this should build up the laminar layer. so i have no wall boundary conditions, only patches where the low-reynolds model should apply. on the patches eps is zero-grad. and k should be 0, where you have to use the trick you mentioned like k=1e-10 because somewhere its divided by k. what is a low-reynolds-wall-bc changing here? at the moment im trying to play arround with C_mu which helps to get a thicker boundary-layer at the patches and prevents k and eps to explode there caused by the very high velocity-gradients. this should be only to get close to a solution and then to be turned back to the standard value.. louis, you mention the nutSpalartAllmarasWallFunction, i think this is for the one-equation-model SpalartAllmaras only or not? as i understood low-re-models are extended k-eps-two-equation models... im very interested in the progress in this discussion . all the best, moritz |
July 8, 2010, 06:37 |
#78 |
stephane sanchi
Rep Power: 18 |
Louis,
What are the dimensions of the external domain that you have used for comparison with wind tunnel data ? Graz University has used the following dimensions 15 x 1.87 x 1.4 m3. https://online.tu-graz.ac.at/tug_onl...cumentNr=81599 And where is located the ahmed body in the X-direction ? Regards, Stephane. |
July 8, 2010, 14:04 |
#79 | ||
Mortiz,
Stéphane, Overall domain bounding box (-6.364 -0.338 -0.8405) (10.636 1.062 1.0295) and I am pretty sure I have the vehicle frontmost part at x=-0.1 (the start of the cubic box is at x=0 and y=-0.288 . 1.87 width x 1.4 height are pretty much ERCOFTAC recommended dimensions and that is also whats I used for a basis. http://www.ercoftac.org/fileadmin/us...9.4/index.html Have you started getting interesting results for the 12.5 degree body? Best, -Louis |
July 26, 2010, 04:52 |
#80 |
stephane sanchi
Rep Power: 18 |
Could someone provide me experimental data (drag, lift, drag coefficient and lift coefficient) for the ahmed body with 12.5 deg slant angle ? Inlet velocity is 40 m/s. Regards, Stephane. |
Aerodynamics | vengi | FLUENT | 5 | October 25, 2011 11:43 |
Aerodynamics | Bonny Jacob Zachariah | Phoenics | 3 | February 10, 2009 05:43 |
CFD in aerodynamics | Ujjwal Bhaskar | FLUENT | 1 | December 26, 2007 11:29 |
Use of Pro-Am in aerodynamics | Javidan Ahmad | Siemens | 8 | December 3, 2004 00:27 |
unsteady aerodynamics | R.KRISHNAMURTHY | Main CFD Forum | 1 | December 6, 2000 02:17 |
