Parabolic inlet velocity profile
Like Tree8Likes
Old   August 8, 2010, 07:29
Default Parabolic inlet velocity profile
  #141
ata
ata's Avatar
ata kamyabi
ata is on a distinguished road
Hi
I think you can use groovy boundary condition and transform cylindrical cordinate to cartesian.
Good luck
Ata
ata is offline   Reply With Quote
Old   August 9, 2010, 07:08
heavy_user is on a distinguished road
Originally Posted by pradeeppandeygbpec View Post
hello...all..
i need to prescribe parabolic velocity profile at inlet to a 3-D circular pipe . The pipe is along the x-Axis...ie. x-axis as its centerline.
I know the parabolic velocity profile for cylindrical coordinates system but how to implement the same in Cartesian coordinates....i need "u" as a function of x,y,z at inlet.
plz help me out...
Hi There,
i postet a while ago(further up somewhere) a "tool" that should be able to do that.
Just download and insert your equation...hope it works..
regards
heavy_user is offline   Reply With Quote
Old   January 21, 2011, 15:08
Default setParabolicInlet.C
  #143
Santiago
gascortado is on a distinguished road
Hi. Does anyone have setParabolicInlet.C file previously posted? It is not available any more. If anyone can email it to gascortado@gmail.com I will greately appreciate it. Thanks
gascortado is offline   Reply With Quote
Old   January 22, 2011, 15:01
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi
You would be better off considering the tool swak4foam: http://openfoamwiki.net/index.php/Contrib/swak4Foam
Have a nice weekend,
Niels
ngj is offline   Reply With Quote
Old   May 2, 2011, 05:44
Default information in parabolic inlet
  #145
bamba
kbambas is on a distinguished road
Good morning evryone!
I 'm new in OpenFoam ,i want set parabolic inlet.I use the version 1.7.0. my geometry is a canal with attach in a tab.I have read in forom but i don't understand.
Please some help me to explain the procedure.
I try to english but my language is french.
kbambas is offline   Reply With Quote
Old   August 25, 2011, 16:38
Default Hi
  #146
s.rasoul_varedi
desert_1250 is an unknown quantity at this point
Send a message via Yahoo to desert_1250
Hi all, can every one tell me how to define U0=1-exp(-y^2) profile at the inlet BCs?
_____
Rasoul
desert_1250 is offline   Reply With Quote
Old   August 25, 2011, 18:31
Assistant Moderator
Bernhard Gschaider
If you like C++-programming you can do it with codedFixedValue (only in 2.0). There was a discussion on that in the forum today
Or you can do it with groovyBC (now part of the swak4Foam-package). You find info about that either inthe Forum or on the Wiki
Old   August 26, 2011, 03:09
s.rasoul_varedi
tanx for your reply, i have not any information about swak4Foam and not have enough time to study it, would you tell me the simplest way to set this BCs at the inlet? (i used OF.1.5-dev)
________
Rasoul
Old   August 26, 2011, 05:24
Assistant Moderator
Bernhard Gschaider
________
Rasoul
Unless you know the OpenFOAM-API by heart and program two boundary conditions every day (before breakfast) in my opinion groovyBC is the fastest way to get what you want (BTW: for your OF version you'll have to use "old school" groovyBC. Advantage: compilation is faster)
As you're very short on time: http://tinyurl.com/3fklrwd
jferrari likes this.
Old   August 26, 2011, 13:20
s.rasoul_varedi
i successed to set the Bcs that i mentioned in the last posts by using nonuniform BCs. now i wanna to add osscillation to the inlet after reaching to the steady state. i know how to use oscillating bc, but dont know how to set it be continued from previous issue!!!??? on the other hand i wanna set unsteady BCs so that after a special time that the problem reached to the steady state, apply oscillation at the inlet. whoud you tell me how do it?? tanx
__________
Rasoul
Old   August 27, 2011, 04:25
s.rasoul_varedi
can every one tell me how to exert (1-exp(-y^2)+0.5Cos2t) profile at the inlet BCs by groovy BCs?? i did not find any manual for groovyBC so that help me do it, i am very glad if intruduce me any documention a bout it.
_____
Rasoul
Old   August 27, 2011, 12:14
Assistant Moderator
Bernhard Gschaider
_____
Rasoul
You asked the same question in three threads in under an hour. Rule of thumb: usually this makes it LESS likely that anyone cares to answer. See also http://openfoamwiki.net/index.php/Ho..._Message_Board
(especially points 5&7)
Old   August 27, 2011, 14:10
s.rasoul_varedi
tnx for your attention, you are right!!!
I've done my work with a combination of two other boundary conditions, without use groovyBC )
Old   August 27, 2011, 23:13
Alberto Passalacqua
Ehhh...there are many examples on the download page of GroovyBC, so it's really a question of *reading* before asking.
Alberto Passalacqua
Old   August 28, 2011, 03:11
s.rasoul_varedi
you are right too someone else no idea ...
_______
Rasoul
Old   March 22, 2013, 11:00
starter
sihaqqi is on a distinguished road
Hello Håkan
I am going through your tutorial. I am using OpenFoam 2.1. I am a beginner and freshly started learning openFoam. I cannot find parabolicvelocity folder and relevant files in the path.
parabolicVelocity/parabolicVelocityFvPatchVectorField.C
parabolicVelocity/parabolicVelocityFvPatchVectorField.H
Can you please send them at sihaqqi@gmail.com. I shall be very grateful. I have tried to find them on internet but every link is useless.
Thanks and Regards
sihaqqi is offline   Reply With Quote
Old   January 2, 2014, 19:17
Retired Super Moderator
Bruno Santos
FYI: The way to get those files and build them (for any OpenFOAM version) is fully explained here: http://www.cfd-online.com/Forums/ope...tml#post446451 post #10
Old   February 6, 2020, 06:13
Default Regarding parabolic velocity profile at inlet
  #158
SHIVA
shivab is on a distinguished road
Hello!
I am trying to give a parabolic velocity profile at the inlet.
I got the default code from Ansys fluent manual, how can I adjust it such as I get a particular velocity at inlet. Initially, I have taken up the code and interpreted and during initialization, I gave the velocity required.
Here is the code I used and any suggestions regarding the improvement of the code to get a required velocity?:
#include "udf.h"
DEFINE_PROFILE(x_velocity,thread,index)
real x[ND_ND];
real y;
face_t f;
begin_f_loop(f,thread)
F_CENTROID(x,f,thread);
y = x[1];
F_PROFILE(f,thread,index) = 20. - y*y/(.0745*.0745)*20.;
end_f_loop(f,thread)
Regards,
Shiva
shivab is offline   Reply With Quote
UDF Unsteady velocity parabolic profile Rashad FLUENT 3 October 1, 2018 16:27
2D air parabolic velocity profile ilker FLUENT 2 November 12, 2008 09:43
parabolic velocity profile? bssdyl FLUENT 4 March 22, 2006 12:32
problem in 3d parabolic velocity profile Lokesh FLUENT 8 August 11, 2005 06:36
Parabolic temperature Inlet Profile in a tube majestywzh FLUENT 0 April 9, 2003 07:37
