March 13, 2009, 02:58 |
Hi Jose,
it works perfectly
#121 |
Johannes Alken
Rep Power: 17 |
Hi Jose,
it works perfectly. Thank you. regards Johannes |
June 8, 2009, 00:08 |
#122 |
vinu varghese
Rep Power: 17 |
Hi
I am using OpenFOAM 1.4.1. I did as Bernhard Gschaider said. But got the following error message. Does anyone know what went wrong?. [caelinux@rgdlab1 setParabolicInlet]$ wmake Making dependency list for source file setParabolicInlet.C could not open file fvPatchFieldFields.H for source file setParabolicInlet.C SOURCE=setParabolicInlet.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/src/cfdTools/lnInclude -I/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/setParabolicInlet.o setParabolicInlet.C:36:32: error: fvPatchFieldFields.H: No such file or directory setParabolicInlet.C: In function int main(int, char**): setParabolicInlet.C:71: error: fvPatchVectorFieldField was not declared in this scope setParabolicInlet.C:71: error: Upatches was not declared in this scope make: *** [Make/linuxGccDPOpt/setParabolicInlet.o] Error 1 |
June 16, 2009, 10:13 |
#123 |
Brugiere Olivier
Rep Power: 17 |
Hi all,
I want to create an intersection between a patch and a plane. I've find this part of code and I put some lines but that it doesn't work. // Create a patch set intesecting a plane point pnt(4.5,2,2.25); vector spanwiseDirection(0,0,1); plane pl1(pnt,spanwiseDirection); cuttingPlane cutPlane(mesh.boundaryMesh().findPatchID("mur_bas" ),pl1); const labelList& cutCells = cutPlane.cells(); word setName("someCells"); cellSet currentSet(mesh, setName, cutCells); the error's message is : wallGradU.C: In function âint main(int, char**)â: wallGradU.C:121: error: no matching function for call to âFoam::cuttingPlane::cuttingPlane(Foam::label, Foam:lane&)â /home/users/brugiere/OpenFOAM/OpenFOAM-1.4.1/src/sampling/lnInclude/cuttingPlane.H:142: note: candidates are: Foam::cuttingPlane::cuttingPlane(const Foam:rimitiveMesh&, const Foam:lane&, const Foam::labelList&) /home/users/brugiere/OpenFOAM/OpenFOAM-1.4.1/src/sampling/lnInclude/cuttingPlane.H:133: note: Foam::cuttingPlane::cuttingPlane(const Foam:rimitiveMesh&, const Foam:lane&) /home/users/brugiere/OpenFOAM/OpenFOAM-1.4.1/src/sampling/lnInclude/cuttingPlane.H:112: note: Foam::cuttingPlane::cuttingPlane(const Foam:lane&) /home/users/brugiere/OpenFOAM/OpenFOAM-1.4.1/src/sampling/lnInclude/cuttingPlane.H:58: note: Foam::cuttingPlane::cuttingPlane(const Foam::cuttingPlane&) make: *** [Make/linux64GccDPOpt/wallGradU.o] Error 1 thank's for your messages Olivier |
January 5, 2010, 14:02 |
#124 |
Rep Power: 16 |
nvm................
February 10, 2010, 16:02 |
Make setParabolicVelocity work for OF1.5
#125 |
Hamed Aghajani
Rep Power: 17 |
for those who may still interested in setParabolicVelocity
you should do the following two minor correction to make it work with OF-1.5 scalar maxVel(....args()[2]).. word ... args()[1]); Best, Hamed |
February 19, 2010, 12:18 |
Error Setting parabolicVelocity as BC in round Inlet
#126 |
Rep Power: 16 |
Hi folks,
I am using OF 1.6 (stable) and have compiled the parabolicVelocity lib. I am having trouble with the simulation as such. It inlet is a 2D pipe in the XY-Plane. The direction of the flow is in Z-Direction with an initial velocity U of 6.6 m/s. The initial "0/U" file looks this way: INJET { type parabolicVelocity; n (0 0 1); y (1 1 0); maxValue 6.6; value uniform (0 0 0); } However, the results I am getting are completely wrong! The U(z) distribution (Z-Plane => X=0 Y=0) at the INJET is not even circular (the INJET is a pipe). On the other hand, the distribution of the U(z) velocity in the Y=0 and X=0, not even not symmetrical but also incoherent. I read on this thread that this code could also be used to set an initial parabolicVelocity profile for a 2D case, if the patch was 2D. This is my case. Any help or any ideas why this might no be working? best regards, |
February 23, 2010, 07:36 |
#127 |
Rep Power: 16 |
Anyone using this BC with openFoam 1.6?
February 23, 2010, 07:53 |
#128 |
Rep Power: 16 |
Hi Noob,
i have created a "tool" that writes an inlet profile. In my case the inlet is in the x-y-plane, flowdirection is z. You need to modify the equations and also change the name of the inlet. (and pay attention to the flow direction and orientation of your case) Then you compile it with wmake and you need to source it, then you should be able to execute the tool in the directory of your case. I attached the files... regards |
February 28, 2010, 09:44 |
#129 |
Rep Power: 16 |
Hi Heavy_User,
Thank you, I will try it out! |
March 8, 2010, 12:41 |
Parabolic Profile and Lift&Drag Forces in OF-1.6
#130 |
Evren
Rep Power: 16 |
I am working on benchmark problem "Flow Around Cylinder" and I am a freshman in OF world. I could obtain preliminary results for my geometry. Nevertheless, the results has to be improved by imposing a parabolic velocity on the inlet patch and the lift and drag forces has to be obtained for a quantitative comparison. My main bottlenecks are 1) How to impose a parabolic profile in OF 1.6. 2) How to obtain lift and drag forces in OF 1.6. Actually, bottleneck 1 is very well described by Bernhard in his several posts and I liked his way of implementation. Nevertheless, his code is good upto OF 1.4.1 (?). It gives following run time error when it's compiled and executed in OF 1.6. //////////////////////////////////////////////////////////////////////////////////// #0 Foam::error:rintStack(Foam::Ostream&) in "/home/user/ebayrakt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/home/user/ebayrakt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib64/libc.so.6" #3 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/user/ebayrakt/OpenFOAM/ebayrakt-1.6/applications/bin/linux64GccDPOpt/setParabolicInlet" #4 __libc_start_main in "/lib64/libc.so.6" #5 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/user/ebayrakt/OpenFOAM/ebayrakt-1.6/applications/bin/linux64GccDPOpt/setParabolicInlet" Segmentation fault //////////////////////////////////////////////////////////////////////////////////// I tried to debug but it seems it will take ages for me to fix it without external support. So, any suggestion is greatly appreciated. About bottleneck 2, I've found a thread titled "Forces in v1.6" and I think that it is gonna solve the issue. Cheers, Evren PS: May be, the code is all fine but naming convention or some libraries have been updated and it is just a matter of incompatibility of versions. |
March 8, 2010, 12:46 |
#131 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Evren
Make a search for groovyBC either here on the Forum or on the wiki, and you will find all you need. Best regards, Niels |
March 8, 2010, 12:49 |
#132 |
Evren
Rep Power: 16 |
Hi Niels,
I'm gonna check it out and post my feedback. Thanks, Evren |
April 28, 2010, 06:11 |
#133 |
Evren
Rep Power: 16 |
Hi all,
groovyBC seems to be a power tool to modify BCs, nevertheless it requires Bison to be installed. In my case, i just needed to implement parabolic BC at the inlet thus I preferred to follow the suggestions in the openfoamwiki (www.openfoamwiki.net). In wiki, under the title "Sig Turbomachinery / Tutorials", it is explained how to implement a parabolic BC in 2D. It's quite straight forward to modify it for 3D. And, if someone needs in 3D, I can send my source files. Cheers, evren |
April 28, 2010, 17:27 |
#134 |
Fernando
Rep Power: 16 |
I have a problem with a customized 3D parabolic BC. I followed all the steps of the Sig Turbomachinery in wiki, but when i try to run the case, an error occurs. The write function is as follows:
void parabolicVelocityFvPatchVectorField::write(Ostream & os) const { fvPatchVectorField::write(os); os.writeKeyword("maxValue") << maxValue_ << token::END_STATEMENT << nl; os.writeKeyword("n") << n_ << token::END_STATEMENT << nl; os.writeKeyword("y") << y_ << token::END_STATEMENT << nl; os.writeKeyword("freq") << f_ << token::END_STATEMENT << nl; os.writeKeyword("phi") << phi_ << token::END_STATEMENT << nl; writeEntry("value", os); } In the 0/U files, i specify the boundary condition as: inlet { type parabolicVelocity; maxValue 0.452; n (0 0 -1); y (0 0 0); freq 0; phi 0; } And when i run the case, the following error occurs: Cannot find 'value' entry on patch entrada of field U in file "./SmeriglioSilviaP/0/U" which is required to set the values of the generic patch field. (Actual type parabolicVelocity) Please add the 'value' entry to the write function of the user-defined boundary-condition or link the boundary-condition into libfoamUtil.so file: ./SmeriglioSilviaP/0/U::boundaryField::entrada from line 35 to line 40. From function genericFvPatchField<Type>::genericFvPatchField(con st fvPatch&, const Field<Type>&, const dictionary&) in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 72. FOAM exiting So, i add in 0/U an entry after phi: value (0 0 0); As is sugested in wiki tutorial, and says: FOAM FATAL ERROR: gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type parabolicVelocity) on patch entrada of field U in file "./SmeriglioSilviaP/0/U" You are probably trying to solve for a field with a generic boundary condition. From function genericFvPatchField<Type>::gradientInternalCoeffs( ) const in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 782. FOAM exiting Any ideas? I need help! |
April 29, 2010, 10:19 |
#135 | |
Evren
Rep Power: 16 |
libs ("libmyBCs.so"); If you build the dynamic library with another name then you should change "libmyBCs.so" with yours. You can check your own build libraries in this directory: $FOAM_USER_LIBBIN I hope this fixes your problem |
April 29, 2010, 11:32 |
#136 |
Fernando
Rep Power: 16 |
Thanks for the reply. Actually, i added that line in the controlDict file. And everything is as should be (or seems to), the fact is that the library libmyBCs.so isnīt anywhere. Should i create it before? i think that adding in the Make/files file in the BC folder this:
parabolicVelocity.......C LIB = $(FOAM_USER_LIBBIN)/libmyBCs Is all i needed to do and that by this, when i compile, it creates the library, is that right? Thanks! |
April 30, 2010, 05:16 |
#137 | ||
Evren
Rep Power: 16 |
And if you compile the source code as it's described in the wiki page, it should create libmyBC.so in this directory $(FOAM_USER_LIBBIN). Quote:
/////////////////////////////////////////////////// parabolicVelocityFvPatchVectorField.C LIB = $(FOAM_USER_LIBBIN)/libmyBCs /////////////////////////////////////////////////// So libmyBCs will be created in the specified directory. Of course your source file might have another name then, you should write the proper file name. And this should do the work for you. You build the library, you tell the solver where to find this library. So, this should be all... Good luck ;-) Evren |
April 30, 2010, 16:07 |
#138 |
Fernando
Rep Power: 16 |
Thanks very much!!!!!! it seems that there where some errors in the code of the BC that didnt allow the compliation and building to finish succesfully and that caused that the library woudlnt be linked. I could run succesfully now, ill see if it is doing what it was supposed to do.
Thanks! |
May 14, 2010, 06:15 |
general profile inlet bc
#139 |
Aldo Iannetti
Rep Power: 16 |
Hi
I'm a new OF 1.6 user, I'd like to know how to implement an interpolated inlet velocity profile taken from an external data file. Is this possibility already there in OF 1.6? thanks |
August 7, 2010, 03:13 |
#140 |
pradeep
Rep Power: 16 |
hello...all..
i need to prescribe parabolic velocity profile at inlet to a 3-D circular pipe . The pipe is along the x-Axis...ie. x-axis as its centerline. I know the parabolic velocity profile for cylindrical coordinates system but how to implement the same in Cartesian coordinates....i need "u" as a function of x,y,z at inlet. plz help me out... |
UDF Unsteady velocity parabolic profile | Rashad | FLUENT | 3 | October 1, 2018 16:27 |
2D air parabolic velocity profile | ilker | FLUENT | 2 | November 12, 2008 09:43 |
parabolic velocity profile? | bssdyl | FLUENT | 4 | March 22, 2006 12:32 |
problem in 3d parabolic velocity profile | Lokesh | FLUENT | 8 | August 11, 2005 06:36 |
Parabolic temperature Inlet Profile in a tube | majestywzh | FLUENT | 0 | April 9, 2003 07:37 |
