June 26, 2008, 06:54 |
Hello davey david.
I don't
#81 |
Sebastian Gatzka
Rep Power: 20 |
Hello davey david.
I don't know why this problem is related to the parabolic inlet velocity? I had a similar problem. I made a mistake with the pressure distribution. Do you have pdRefCell and pdRefValue entries in your fvSolution-file? Maybe these entries do not correspond to your mesh? You can try setting a reference value for the pressure directly at a boundary instead.
Schrödingers wife: "What did you do to the cat? It's half dead!" |
June 26, 2008, 07:09 |
@sebastians question whether i
#82 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
@sebastians question whether it is possible to use funkySetFields:
Yes. You can do something similar to http://openfoamwiki.net/index.php/Co...t-Room_Example (basically set a parabolic internal field, use that field on selected patches and afterwards clear the internal field and keep the values at the patches). Whether this is easier than programming a util is a matter of taste Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
July 1, 2008, 11:33 |
hello,
i need to implement a
#83 |
davey david
Rep Power: 17 |
hello,
i need to implement a boundary condition on a patch(wall) and write out only those values.it is more of a slip condition enforced at the boundary(case is 2D).can the parabolic velocity boundary condition be modified to do this??any ideas and thoughts are welcome. cheers davey |
July 1, 2008, 14:24 |
Hello!
So, I have worked a
#84 |
Sebastian Gatzka
Rep Power: 20 |
Hello!
So, I have worked a little bit with the tool. As a reminder I tried to change it so it would set the velocity components in y-direction instead of x. It's compiling and looks like this: setParabolicInlet.C I would like to set the parabolic inflow to the boundary-patch inflow so I did this: setParabolicInlet . . inflow 0.5305 Have a look at the output: Exec : setParabolicInlet . . inflow 0.5305 Date : Jul 01 2008 Time : 19:13:59 Host : M1530 PID : 9011 Root : /home/sega/OpenFOAM/sega-1.4.1/run/nucleateBoiling Case : . Nprocs : 1 Create time Create mesh for time = 0 Vector field U Patching inlet x [ 0 , 0 ] z [ -1.98553e-22 , 2.43404e-22 ] => x [ 0 , 0 ] z [ -1.98553e-22 , 4.41957e-22 ] Writing modified field U End But it looks like the tool does nothing at all . Maybe beacuse of this strange x-interval? I think I made some severe mistakes changing the directions. I hope you have some suggestions? Thanks so far & Greetings from Germany. Sebastian
July 1, 2008, 14:53 |
Hi Sebastian!
In your code
#85 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Sebastian!
In your code the minX/maxX-line should now access component(0) Bernhard
July 2, 2008, 04:08 |
Yes, Thank you. I have changed
#86 |
Sebastian Gatzka
Rep Power: 20 |
Yes, Thank you. I have changed it and now its working.
But I have some more problems setting the right parabolic inlet. If I set scalar vel=maxVel*(1-(x/1e-3)*(x/1e-3)); I get a parabolic profile, which is axi-symmetric (an arc). The length of the area I want so set up with the profile is 1mm, thus the 1e-3 in the denumerator. But the values are far too big (1e+6) and negative. If I just set scalar vel=maxVel*(1-x*x) I get the "complete" parabolic profile, but with the right magnitude. So, what I want is a half parabolic profile with the correct magnitude. What may be wrong with the code?
July 2, 2008, 04:48 |
The problem might be that the
#87 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The problem might be that the extent of the patch is calculated using the face centres, but in reality the face vertices should be used.
July 2, 2008, 06:29 |
I dont know how and why this c
#88 |
Sebastian Gatzka
Rep Power: 20 |
I dont know how and why this can effect the profile, but this sounds like a limitation.
As I just have 8 cells over the inflow-patch in x-direction I have written a small MATLAB-file which is calculating the values at the cellcenters an put them into a nonuniform List into the U-file by hand. I'm not sure where this will lead, but I will get back to you.
July 3, 2008, 06:13 |
Hi Sebastian!
Well in your
#89 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Sebastian!
Well in your case the utility thinks that the channel is 1/8th narrower than it actually is (misses half a cell on the left and on the right) Bernhard
July 8, 2008, 22:26 |
hi,
I have go through all the
#90 |
weihong yao
Rep Power: 17 |
hi,
I have go through all the messages.but I don't know how to compile the setParabolicInlet.I am doing a simulation about the compute wind engineering,I do the simulation in rhoturbFoam.my inlet velocity profile:U=U_0*(Z/Z_0)^0.25,"U_0","Z_0"are constants I provide."Z" is the height of the building.I am using OF1.4,and I have downloaded the parabolicVelocity_HJ_17Jan2007.tgz,but I don't know what I should do next.is there anyone help me step by step?that is very important to me.I would very very appreciate it. thanks,Ivan |
November 17, 2008, 15:08 |
I have no idea. A debug-versio
#91 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I have no idea. A debug-version of OF would give us the line-number of the program at which this is occuring:
http://openfoamwiki.net/index.php/Main_FAQ#An_application_ends_with_a_segmentati on_fault._What_is_wrong.3F Bernhard
November 17, 2008, 16:07 |
Thanks Bernhard
I'll try.
#92 |
Ranjiv Maulana
Thanks Bernhard
I'll try. |
November 19, 2008, 23:09 |
hi,
I have compiled the lib
#93 |
carrieyang
Rep Power: 17 |
hi,
I have compiled the libs successfully,but when i type paraFoam <root> <case>,it show: From function dlLibraryTable::open(const fileName& functionLibName) in file db/dlLibraryTable/dlLibraryTable.C at line 79 could not load /home/ivan/OpenFOAM/ivan-1.4.1/lib/linuxGccDPOpt/libparabolicVelocity.so: undefined symbol: _ZN4Foam4word5debugE what is problem?could anyone give me a hand? |
December 16, 2008, 08:03 |
Hello All,
A question which
#94 |
Mark Couwenberg
Rep Power: 17 |
Hello All,
A question which is not exactly related to this thread but it looks like here are people who might be able to help me a bit further. For some postprocessing utility I need to read in the value of the BC (fixedValue uniform) on some patch, usually U on Inlet patch. So I ask the user to give the name of the inlet patch, the field to be read and than the utility should find in the times directory the correct value. E.g. if the the next BC for Inlet is given: >>> Inlet { type pressureInletVelocity; value uniform (5 0 0); } >>> the utility should return the vector (5 0 0); Does anyone know how to perform this (simple) task? Thanks in advance, Brgds, Mark |
December 16, 2008, 11:12 |
Radu,
Thanks for your reply
#95 |
Mark Couwenberg
Rep Power: 17 |
Radu,
Thanks for your reply, very useful. I am getting closer, but still not there. Now, if I imcorporate your snippet, during build I get the error message 'U' was not declared in this scope. I also have a variable "fieldName", which is declared as const word. If I use this instead of U (to generalize the use of the final utility). In that case I get the error message that const class::Foam has no member named 'boundaryField'. Well, I understand the meaning of these messages but I do not know how to correct them. Any advice here? Do I have to add some kind of createfield.H for U? This did not work so far as well. Kind regards, Mark |
January 9, 2009, 15:42 |
anyway
i wave to write a B
#96 |
antonio segalini
Rep Power: 17 |
anyway
i wave to write a BC that, taking a surface patch, each point with coordinates (x,y,z) must have a velocity omega*(-y,x,0). Can someone send me an example? thanks again for all the help |
January 13, 2009, 16:57 |
I have used the following piec
#97 |
sesha
Rep Power: 17 |
I have used the following piece of code as a InletVelocityProfile.H include file in my solver. The idea is to assign some section of the inlet a particular velocity and the rest something else. However, the 'for loop' does not seem to do anything! Can anyone comment on this?
InletVelocityProfile.H looks like this label inletPatchID = mesh.boundaryMesh().findPatchID("inlet"); // Get reference to boundary value, patch centers fvPatchVectorField& inletU = U.boundaryField()[inletPatchID]; const fvsPatchVectorField& inletFaceCentres = mesh.Cf().boundaryField()[inletPatchID]; scalarField y = inletFaceCentres.component(vector::Y); forAll(inletU, faceI) { if (y >= 0.02) { inletU == 0.5*vector(1,0,0); } else { inletU == 0.0*vector(1,0,0); } } |
January 13, 2009, 16:58 |
Ofcourse, I also have
U.wr
#98 |
sesha
Rep Power: 17 |
U.write() at the end of the include file. Thanks Sesha |
January 14, 2009, 11:13 |
It should work with:
#99 |
It should work with: forAll(inletU, faceI) { if (y >= 0.02) { inletU[faceI] == 0.5*vector(1,0,0); } else { inletU[faceI] == 0.0*vector(1,0,0); } } Regards, Jose Santos |
January 14, 2009, 11:15 |
Also replace == with =.
#100 |
UDF Unsteady velocity parabolic profile | Rashad | FLUENT | 3 | October 1, 2018 16:27 |
2D air parabolic velocity profile | ilker | FLUENT | 2 | November 12, 2008 09:43 |
parabolic velocity profile? | bssdyl | FLUENT | 4 | March 22, 2006 12:32 |
problem in 3d parabolic velocity profile | Lokesh | FLUENT | 8 | August 11, 2005 06:36 |
Parabolic temperature Inlet Profile in a tube | majestywzh | FLUENT | 0 | April 9, 2003 07:37 |
