Multiphase flow and Phase change due to heat transferevaporation
Like Tree6Likes
Old   August 6, 2009, 08:48
Rachel Vogl
Rachel is on a distinguished road
@Hamed : If you are upgrading to OpenSUSE 11.1 for OF-1.6 it is not necessary. I am using SLED 10 till now. paraFoam does not work...
@ Sandy: I could not find interPhaseChangeFoam tutorial in OF-1.6
Rachel is offline   Reply With Quote
Old   August 13, 2009, 10:47
Rachel Vogl
Anybody managed to get rhoReactingFoam working ?
I am still having problems with this solver... as mentioned in this thread.
http://www.cfd-online.com/Forums/ope...ctingfoam.html
Old   August 23, 2009, 06:10
J. Cai
chiven is on a distinguished road
Hi, guys, how about your progresses on the two phase flow simulation? I am trying to use OpenFOAM to simulate the two phase flow with condensation (vapor to water). I think it is difficult, but very interesting.
Best regards,
Chiven
chiven is offline   Reply With Quote
Old   September 24, 2009, 07:24
Sanjib Das Sharma
sanjibdsharma is on a distinguished road
Hi Matvej,
I am new to OpenFoam. Having started with the basics 2 months ago, I am now stuck with modeling of steady-state, liquid-phase, multi-species transport with chemical reaction. Can you provide some input as to how I proceed i.e., which modules should I use.
As far as I understood, I compiled with the following:
simpleFoam solver + basicMixture.H + basicThermo.H + liquidMixture.H + liquid.H + pEqn.H + UEqn.H
I have tried to use YEqn.H, but gave error. How to combine this and proceed ? It will be great if you have any example.
Regards,
Sanjib
sanjibdsharma is offline   Reply With Quote
Old   September 25, 2009, 13:15
isabel
isabel is on a distinguished road
I have a doubt about interPhaseChangeFoam.
The momentum equation is:
fvVectorMatrix UEqn
fvm::ddt(rho, U)
+ fvm::div(rhoPhi, U)
- fvm::Sp(fvc::ddt(rho) + fvc::div(rhoPhi), U)
- fvm::laplacian(muf, U)
- (fvc::grad(U) & fvc::grad(muf))
UEqn.relax();
if (momentumPredictor)
solve
UEqn
fvc::reconstruct
fvc::interpolate(interface.sigmaK())*fvc::snGrad(g amma)
- ghf*fvc::snGrad(rho)
- fvc::snGrad(pd)
) * mesh.magSf()
Why the red line is ghf*fvc::snGrad(rho) ???
I think it would be ghf*rho
isabel is offline   Reply With Quote
Old   September 26, 2009, 22:10
Sandy Lee
sandy is on a distinguished road
Hi isabel,
Do you understand the blue line?? How to derive it?
fvVectorMatrix UEqn
fvm::ddt(rho, U)
UEqn.relax();
Thanks.
sandy is offline   Reply With Quote
Old   September 27, 2009, 04:28
isabel
I don't know. For me fvc::ddt(rho) + fvc::div(rhoPhi) is the continuity equation, which is equal to zero.
In interFoam (a similar solver), you don't have this blue line:
fvVectorMatrix UEqn
fvm::ddt(rho, U)
solve
UEqn
fvc::reconstruct
- fvc::snGrad(pd)
) * mesh.magSf()
But I still don't know why the term ghf*rho doesn't appear and what the term snGgrad(rho) means.
Old   September 28, 2009, 17:07
Lakshman
lucky1729 is on a distinguished road
@isabel
snGrad(rho) calculates the normal component of gradient to a surface. Momentum equation in differential form requires 'rho*g' in right hand side. So to get that 'ghf'{g*hf} is multiplied by snGrad(rho).
lucky1729 is offline   Reply With Quote
Old   September 29, 2009, 04:58
isabel
Thanks lucky. But I still think that I don't need grad(rho), so I have modified the UEqn.H as follows. Is this way wrong???
surfaceScalarField muf = twoPhaseProperties.muf();
volVectorField gravityterm = rho*vector(0, -9.81, 0); // this means rho*g
fvVectorMatrix UEqn
fvm::ddt(rhoU)
- (fvc::grad(U) & fvc::grad(nuf))
- gravityterm
UEqn.relax();
solve
UEqn
fvc::reconstruct
- fvc::snGrad(pd)
) * mesh.magSf()
Old   September 30, 2009, 10:28
isabel
I already know why the term fvc::snGrad(rho) appears. It is a consequence of the UEqn equation works with dynamic pressure (pd) instead total pressure (p).
But I still have a question:
What is the advantage of working with dynamic pressure (pd) instead total pressure (p)
Old   November 13, 2009, 10:02
Default compressibe phase change modelling by rhoReactingFoam
  #71
Hamed Aghajani
haghajani is on a distinguished road
Hi Rachel,
Have you got new experiences with rhoReactingFoam, to simulate phase change of a liquid into another medium?
Have you find out sth from counterFlowFlame2D?
Please keep us posted,
Hamed
haghajani is offline   Reply With Quote
Old   November 13, 2009, 12:51
Exclamation Questions on cavitatingPimpleFoam
  #72
Hamed Aghajani
Originally Posted by mkraposhin View Post
Here is a link for source code of caviatingPimpleFoam solver for OpenFOAM 1.5
http://www.os-cfd.narod.ru/small_fil...leFoam_1.5.tgz
Dear Matvej,
In cavitatingPimpleFoam/pEqn, Line 17, phid2 = fvc::interpolate(psi) * (phid1 + fvc::ddtPhiCorr(rUA, rho, U, phi) / fvc::interpolate(rho)), the two sides of "+" are inconsistent because of red bold part. Am I right?
Regarding the thermodynamicProperties, beside the items indicated in rascavitatingfoam tutorial, there should be some data for following parameters, according the chosen gammaModel, say Kunz;
CgammaP [0 0 0 0 0]
CgammaA [0 0 0 0 0]
UInf [0 1 -1 0 0] ?
tauInf [0 0 1 0 0] ?
pCoeff1 [0 0 0 0 0] ?
CgammaEff [0 0 0 0 0] ?
Would you please drop a line on their Initiation, values.
I am facing some other incompatible dimension errors, which may share with you here, later.
Best regards,
Hamed
Old   November 13, 2009, 22:06
Sandy Lee
Hi hamed, you think, what is the difference between the interPhaseChangeFoam solver with the cavitatingPimpleFoam solver? Thanks.
Old   November 16, 2009, 08:01
Smile interphaseChangeFoam vs. cavitatingPimpleFoam
  #74
Hamed Aghajani
Sandy,
As far as I have understood, cavitatingPimpleFoam is a Homogenous cavitation solver which uses PISO-SIMPLE coupling loop. Homogeneous might means there is no slip velocity between liquid and its cavitated phase. It is compressible, so uses a barotropic EOS, to deal with density. It solves for one phase wich might result in two phase [first phase + vapour/liquid of first Phase]
On the other hand, interPhaseChangeFoam considers the Phase change of, say a liquid as water, into another phase, say Air. so at the end we may have two phases, (liquid and [vapour of that liquid + Air]). and the solver is incompressible here.
Hope it would be a step forward,
Best regards,
Hamed
Old   January 25, 2010, 09:19
Matthias Voß
mvoss is on a distinguished road
hello,
i was pretty happy to find these post. since i´m trying to understand the rasCavtiation-solver in OF1.5. Like usual, i was trying to read through the code and got stuck while reading the rhoEqn.H.
I think my question is: what is this phiv doing? It is some sort of correction? I read
phiv=phi/fvc::interpolate(rho) but i didn´t got the grasp.
I found two parts for correction in pEqn.H: resetphiPatches and resetphivpatches... but i have no clou what they are doing.
Could somebody please be so kind and give me a hint?
Thanks in advance,
neewbie
mvoss is offline   Reply With Quote
Old   April 8, 2010, 07:44
Default Moment method
  #76
john
mach is on a distinguished road
Does any body used moment method for aerosol coagulation of size less then 0.1 um in Fluent?.
Does any know about moment method UDF?.
Please let me know
Thanks
mach is offline   Reply With Quote
Old   April 9, 2010, 03:09
matej forman
matejfor is on a distinguished road
John, sending the same question to this forum as well as to Fluent one is not a good thing. This forum is for OpenFOAM. It will make people annoyed, not attracted to answer your question.
good luck
matej
matejfor is offline   Reply With Quote
Old   May 25, 2010, 05:30
Default interPhaseChangeFoam tuterial
  #78
Nima Samkhaniani
nimasam is on a distinguished road
hi openFoam former
im going to work on evaporation of incompressible flow, can any body send me a simple model which can work properly with openFoam 1.6 solver (interPhaseChangeFoam) ?
nimasam65@gmail.com
nimasam is offline   Reply With Quote
Old   May 25, 2010, 09:08
Sandy Lee
No, I guess interPhaseChangeFoam is not suiltable to your problem, because its mode is about the specified cavitation flows, and they are some empirical formula to defined the phase change, but not really solve equations of the heat and mass transfer. Moreover, this phase change is an isothermal process.
If you need the tutorial about this solver, you can find it in OF 1.6.x
Kummi likes this.
Old   May 28, 2010, 09:43
Nima Samkhaniani
thanks sandy
is there any solver in openFoam which is appropriate for my simulation?
if no , whats ur suggestion for further progress? i dont know use whether interfoam (direct model) or bubbleFoam (Eulerian _Eulerian model) or interChangePhaseFoam as a basic solver and then add mass and heat transfers equation.
could you give me some hints
thanks
Modelling Supersonic TwoPhase Flow with Phase Change wes OpenFOAM Running, Solving & CFD 9 July 27, 2021 12:05
About phase change heat and mass transfer Michael FLUENT 2 February 13, 2011 02:49
Two phase flow with phase change Ahmad Al-Zoubi CFX 1 November 26, 2008 04:59
Two-phase flow in T-junction, multiphase of DPM? Tony FLUENT 2 July 8, 2008 02:26
how to deal with phase-change heat exchanger? cherry FLUENT 1 April 16, 2002 22:59
