OpenForm fatal error:Could not find rho:rho in database
Old   October 28, 2024, 22:19
Default OpenForm fatal error:Could not find rho:rho in database
lee
klaus_ is on a distinguished road
Hi. I try to find coefficient of lift(Cl) and drag(Cd) of two-dimensional wing. I change the ControlDict as show below. but when I run the simulation always throws --> OpenFOAM fatal error: Could not find rho:rho in database
I have no idea where to put rho:rho
*--------------------------------*- C++ -*----------------------------------*\
| Generated by the CfdOF workbench for FreeCAD |
| https://github.com/jaheyns/CfdOF |
FoamFile
version 2.0;
format ascii;
class dictionary;
object controlDict;
application simpleFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
deltaT 1;
endTime 200;
writeControl timeStep;
writeInterval 100;
purgeWrite 0;
writeFormat ascii;
writePrecision 15;
runTimeModifiable true;
libs
// Needed for availability of porous baffle boundary in potentialFoam
#include "turbulenceLib"
functions
{ forceCoeffs
type forceCoeffs;
functionObjectLibs ("libforces.so");
outputControl timeStep;
outputInterval 1;
log yes;
patches (Cut);
PName p;
UName U;
rhoName rhoInf;
log true;
rhoInf 1.225; // density of air
CofR (0 0 0); // center of the wing(set to origin)
liftDir (1 0 0);
dragDir (0 0 1);
pitchAxis (0 1 0); // asis of rotaion(z-direction)
magUInf 10; // flow velocity
lRef 1.0; // wing reoresentaive length
Aref 1.0; // wing representaive area
klaus_ is offline   Reply With Quote
Unable to find turbulence model in the database mitbakhai OpenFOAM Post-Processing 3 June 24, 2024 02:33
Foam fatal io error: cannot find file smd2312 OpenFOAM 2 January 15, 2024 12:20
Error when executing simpleFoam - FOAM FATAL ERROR:(openfoam-2206) cannot find file astri OpenFOAM Running, Solving & CFD 5 November 18, 2022 04:11
FOAM FATAL ERROR in Foam::findEtcFile() : could not find mandatory file makaveli_lcf OpenFOAM Running, Solving & CFD 15 November 18, 2015 20:00
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
