October 26, 2024, 12:37 |
Temperature Dependent Heat Source
Asiimwe Paul
Hi All, I am trying to add a temperature dependant cooling source fvModel in a coldRoom simulation case. Below is my code:
coolingModel { type coded; active yes; codedCoeffs { name coolingSource; selectionMode all; // Apply to entire mesh or specify a cellZone // cellZone coolingZone; // Uncomment if applying to a cell zone fields (e); // Energy field to which the source is applied code #{ #include "fvCFD.H" // Access the mesh and time objects const fvMesh& mesh = this->mesh(); const Time& runTime = mesh.time(); // Source term addition function for scalar equations void addSup(fvMatrix<scalar>& eqn) { const volScalarField& T = mesh.lookupObject<volScalarField>("T"); const scalarField& V = mesh.V(); scalarField& source = eqn.source(); scalar Tmax = 280.15; // Upper temperature limit (5°C) scalar Q = -100; // Cooling rate in W/m³ forAll(source, celli) { if (T[celli] > Tmax) { source[celli] += Q * V[celli]; } } Info << "Applied cooling source term at time " << runTime.timeName() << endl; } // Source term addition function for vector equations (if needed) void addSup(fvMatrix<vector>& eqn) { // Do nothing for vector equations } // Correct function (called after the solution) void correct() { // No corrections needed } #}; } } As much as the fvModel is executed during simulation, I don't see its impact on the temperature field as the temperature in my cold room keeps rising beyond the set threshold (Tmax) until it settles at ambient temperature. Any ideas on how I can better this approach? |
October 27, 2024, 19:20 |
Desh
Rep Power: 5 |
Just double check if you can implement a negative value for the heat source? you can certainly decrease of power say 100 to 0 W/m^3 over specified period of time. hope this helps |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 09:06 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 10:07 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 02:41 |
