Weird physical observation in InterFOAM
Old   October 23, 2024, 21:59
Default Weird physical observation in InterFOAM
mohammad
mostanad is on a distinguished road
Hi foamers,
I have recently solved a simple case with three phases in openfoam and have seen a physical observation which cannot interpret.
The case is a vessel with open boundary condition at the top boundary.
The boundary conditions I set are as follows;
alpha.air:
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      alpha.air;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
    wall
        type            alphaContactAngle;
        thetaProperties
            ( slag air ) 90 0 0 0
            ( slag molten ) 90 0 0 0
            ( molten air ) 90 0 0 0
        value           uniform 0;
    inlet
        thetaProperties
        value           uniform 0;
    outlet
        type        fixedValue;
    value        uniform 1;
alpha.molten
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      alpha.molten;
boundaryField
    wall
        type            zeroGradient;
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 0;
alpha.slag
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      alpha.slag;
boundaryField
    wall
        type            zeroGradient;
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 0;
alphas
|  \\    /   O peration     | Version:  2.3.x                                 |
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      alphas;
boundaryField
    wall
        type            zeroGradient;
    inlet
        type            zeroGradient;
    outlet
        type            zeroGradient;
p_rgh
FoamFile
    version     2.0;
    format      ascii;
    object      p_rgh;
dimensions      [1 -1 -2 0 0 0 0];
boundaryField
    wall
        type        fixedFluxPressure;
        value       uniform 0;
    inlet
        value       uniform 0;
    outlet
        type        fixedValue;
        value        uniform 0;
U
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
        value           uniform (0 0 0);
    outlet
        type            pressureInletOutletVelocity;
    wall
        type            fixedValue;
transportProperties:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      transportProperties;
phases
     molten
         transportModel Newtonian;
         nu nu   [ 0  2 -1  0 0 0 0 ] 1e-06;
         rho rho [ 1 -3  0  0 0 0 0 ] 7000;
                 Cp  Cp  [ 0  2 -2 -1 0 0 0 ] 440;
                 kf  kf  [ 1  1 -3 -1 0 0 0 ] 73; // sped up! 16.5*20;
                 D   D   [ 0  2 -1  0 0 0 0 ] 0.17e-6; // sped up! 0.85e-8*20;
                 Cs  Cs  [ 1 -3  0  0 0 0 0 ] 335;
     slag
         nu nu   [ 0  2 -1  0 0 0 0 ] 2.8e-05;
         rho rho [ 1 -3  0  0 0 0 0 ] 2000;
         kf  kf  [ 1  1 -3 -1 0 0 0 ] 40; // sped up! 16.5*20;
     air
         nu  nu  [ 0 2  -1  0 0 0 0 ] 1e-05;
         rho rho [ 1 -3  0  0 0 0 0 ] 1.25;
         Cp  Cp  [ 0  2 -2 -1 0 0 0 ] 1000;
         kf  kf  [ 1  1 -3 -1 0 0 0 ] 0.025; // sped up! 0.1*20;
         D   D   [ 0  2 -1  0 0 0 0 ] 0.17e-6; // sped up! 0.85e-8*20; // dummy
         Cs  Cs  [ 1 -3  0  0 0 0 0 ] 0.00025;
sigmas
    (slag molten) 0.07
    (air slag) 0.07
    (air molten) 0.07
Having these boundary conditions, once I set the fields for the phases, air, slag, and molten with suitable thickness like:
Attched Image 1 (below)
and the simulation goes well. But when I set the fields thinner like:
Attched Image 2 (below)
The phases on the bottom (slag in image) becomes disturbed;
Attached image 3 (below)
My question is why this only happens with thinner layers of bottom phases? Which value in properties or BC is making this thin layers case disturbed?
I hope someone can help me to generate more physical result.
mostanad is offline   Reply With Quote
Gmsh does not ouput SU2 markers from physical surfaces stewels SU2 4 May 17, 2023 06:15
[Gmsh] Nasa Nozzle: Plot 3D -->gmsh -->fluent - no physical groups Nico89 OpenFOAM Meshing & Mesh Conversion 1 June 14, 2016 06:40
Mesh refinement with interFoam = solution that does no physical sense lyna OpenFOAM Running, Solving & CFD 2 January 19, 2016 12:05
Partition does not start on physical sector boundary!!?? immortality Lounge 1 December 8, 2013 16:04
Problem of InterFoam with LES SpalartAllmarasIDDES keepfit OpenFOAM 3 August 29, 2013 12:21
