Need help in finding error in boundary conditions |
October 2, 2024, 11:14 |
Parag
Hello everyone
I am working on a problem in openFOAM 2406. My task is to replicate a simulation which has already been performed in Ansys Fluent. The simulation in question is a tutorial case from Fluent tutorials regarding simulation of porous media. It is a flow simulation through a catalytic converter. I have already successfully performed the simulation in Fluent by following the tutorial pdf and am now working in openFOAM. I have imported the mesh from fluent. I have looked at the settings in fluent and tried my best to set up the case in openFOAM. I am using porousSimpleFoam for this. Problem: I am getting a floating point exception error. Solutions tried: My first search on this forum led me to believe it was a meshing problem. I ran checkMesh, found out 99 non orthogonal faces. To tackle the same, I tried increasing the 'nNonOrthogonalCorrectors' value. That did not work. I have also tried disabling floating point exception handling. Further searching has given me two ideas. One is my understanding of the output given by checkMesh is wrong. Or the other is that my boundary conditions are incorrect. I am leaning on the latter. I am sorry for this being my skill issue, but I really lack the theoretical background to find out which condition is wrong at this point. That is where I'd really like some help. Attaching a drive link with all the files. https://drive.google.com/drive/folde...usp=drive_link Folders (3): catcon: my case directory with all the files. (including 'flntgz.msh' file exported from fluent) ansys reference data: screenshots of settings in fluent which I have referenced for case setup error data: txt files of terminal output on running checkMesh and porousSimpleFoam. two outputs have been attached, one with exception handling enabled and one with disabled. Could not attach it in the post due to character limitations. Attaching the checkMesh result below as well for quick reference. checkMesh output: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2406 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _be01ca78-20240625 OPENFOAM=2406 version=2406 Arch : "LSB;label=32;scalar=64" Exec : checkMesh Date : Sep 30 2024 Time : 23:17:22 Host : localhost.localdomain PID : 30915 I/O : uncollated Case : /home/peter/opfm/catcon nProcs : 1 fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Check mesh... Time = 0 Mesh stats points: 2274333 faces: 3103361 internal faces: 2897633 cells: 550560 faces per cell: 10.8998002 boundary patches: 72 point zones: 0 face zones: 25 cell zones: 21 Overall number of cells of each type: hexahedra: 3742 prisms: 1687 wedges: 583 pyramids: 252 tet wedges: 9 tetrahedra: 859 polyhedra: 543428 Breakdown of polyhedra by number of faces: faces number of cells 4 4 5 18 6 407 7 39635 8 116666 9 37892 10 51796 11 71808 12 55408 13 53374 14 50626 15 36239 16 18754 17 7368 18 2407 19 706 20 237 21 60 22 19 23 1 24 3 Checking topology... Boundary definition OK. Cell to face addressing OK. ***Unused points found in the mesh, number unused by faces: 175923 number unused by cells: 175923 <<Writing 175923 unused points to set unusedPoints <<Found 130 neighbouring cells with multiple inbetween faces. Upper triangular ordering OK. <<Writing 260 unordered faces to set upperTriangularFace Face vertices OK. *Number of regions: 17 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" <<Writing region 0 with 35632 cells to cellSet region0 <<Writing region 1 with 346455 cells to cellSet region1 <<Writing region 2 with 33106 cells to cellSet region2 <<Writing region 3 with 2063 cells to cellSet region3 <<Writing region 4 with 7631 cells to cellSet region4 <<Writing region 5 with 2100 cells to cellSet region5 <<Writing region 6 with 2181 cells to cellSet region6 <<Writing region 7 with 2262 cells to cellSet region7 <<Writing region 8 with 22295 cells to cellSet region8 <<Writing region 9 with 7800 cells to cellSet region9 <<Writing region 10 with 3263 cells to cellSet region10 <<Writing region 11 with 35816 cells to cellSet region11 <<Writing region 12 with 41771 cells to cellSet region12 <<Writing region 13 with 4102 cells to cellSet region13 <<Writing region 14 with 3132 cells to cellSet region14 <<Writing region 15 with 477 cells to cellSet region15 <<Writing region 16 with 474 cells to cellSet region16 Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology sensing_element-65-solid:257:6501 220 438 ok (non-closed singly connected) quadribbed_body_bottom_af0-solid:1:6500 3574 3502 multiply connected (shared edge) quadribbed_body_bottom_af0-solid:1:6499 13820 26708 ok (non-closed singly connected) quadribbed_body_top_af1-solid:1:6498 14642 28485 ok (non-closed singly connected) quadribbed_body_top_af1-solid:1:6497 4432 4356 multiply connected (shared edge) pipe_connetions_cc-71-solid1:1:6496 3216 3032 multiply connected (shared edge) pipe_connetions_cc-solid1:1:6495 3116 2956 multiply connected (shared edge) outlet 778 1320 ok (non-closed singly connected) inlet 784 1332 ok (non-closed singly connected) sensor_innertube-67-solid:266 495 991 ok (non-closed singly connected) quadribbed_body_bottom_af0-solid:265 4360 4353 multiply connected (shared edge) sensor_protectiontube-66-solid1:262 21470 20385 multiply connected (shared edge) sensor_protectiontube-66-solid1:261 969 1273 ok (non-closed singly connected) quadribbed_body_top_af1-solid:260 185 370 ok (non-closed singly connected) quadribbed_body_top_af1-solid:259 4578 4549 multiply connected (shared edge) socket_for_sensor_solid_1-solid1:258 921 1661 ok (non-closed singly connected) sensing_element-65-solid:257 21660 21390 multiply connected (shared edge) out1 170 321 ok (non-closed singly connected) in1 170 321 ok (non-closed singly connected) quadribbed_body_bottom_af0-solid-welding_2-54-solid1 192 192 multiply connected (shared edge) quadribbed_body_top_af1-solid-welding_2-54-solid1 220 214 multiply connected (shared edge) pipe_connetions_cc-solid1-welding_2-54-solid1 496 496 multiply connected (shared edge) welding_2-54-solid1:1 281 564 ok (non-closed singly connected) sensor_innertube-67-solid:1 32132 29963 multiply connected (shared edge) quadribbed_body_bottom_af0-solid:1 3636 3559 multiply connected (shared edge) quadribbed_body_bottom_af0-solid-recessed_cushioningmat-solid1 2800 2795 multiply connected (shared edge) honeycomb-solid1-recessed_cushioningmat-solid1 3676 3676 multiply connected (shared edge) quadribbed_body_bottom_af0-solid-recessed_cushioningmat_af0-solid1 2818 2810 multiply connected (shared edge) honeycomb_af0-solid1-recessed_cushioningmat_af0-solid1 3674 3674 multiply connected (shared edge) quadribbed_body_bottom_af0-solid-siderings-73-solid1 634 635 multiply connected (shared edge) recessed_cushioningmat-solid1-siderings-73-solid1 1168 1165 multiply connected (shared edge) honeycomb-solid1-siderings-73-solid1 708 700 multiply connected (shared edge) siderings-73-solid1:1 1580 1547 multiply connected (shared edge) quadribbed_body_bottom_af0-solid-siderings-72-solid1 652 652 multiply connected (shared edge) recessed_cushioningmat-solid1-siderings-72-solid1 1208 1203 multiply connected (shared edge) honeycomb-solid1-siderings-72-solid1 728 720 multiply connected (shared edge) siderings-72-solid1:1 1630 1601 multiply connected (shared edge) quadribbed_body_bottom_af0-solid-siderings-solid1 656 653 multiply connected (shared edge) recessed_cushioningmat_af0-solid1-siderings-solid1 1238 1236 multiply connected (shared edge) honeycomb_af0-solid1-siderings-solid1 754 747 multiply connected (shared edge) siderings-solid1:1 1676 1641 multiply connected (shared edge) quadribbed_body_bottom_af0-solid-siderings_af0-solid1 626 628 multiply connected (shared edge) recessed_cushioningmat_af0-solid1-siderings_af0-solid1 1160 1159 multiply connected (shared edge) honeycomb_af0-solid1-siderings_af0-solid1 692 683 multiply connected (shared edge) siderings_af0-solid1:1 1572 1558 multiply connected (shared edge) quadribbed_body_bottom_af0-solid-welding_2-solid1 196 195 multiply connected (shared edge) quadribbed_body_top_af1-solid-welding_2-solid1 212 209 multiply connected (shared edge) pipe_connetions_cc-71-solid1-welding_2-solid1 500 496 multiply connected (shared edge) sensor_innertube-67-solid-sensor_protectiontube-66-solid1 2504 2504 multiply connected (shared edge) quadribbed_body_top_af1-solid-sensor_protectiontube-66-solid1 294 293 multiply connected (shared edge) sensor_protectiontube-66-solid1:1 1524 3046 ok (non-closed singly connected) welding_2-solid1:1 286 575 ok (non-closed singly connected) quadribbed_body_bottom_af0-solid-quadribbed_body_top_af1-solid 8956 8980 multiply connected (shared edge) quadribbed_body_top_af1-solid-recessed_cushioningmat-solid1 2924 2920 multiply connected (shared edge) quadribbed_body_top_af1-solid-recessed_cushioningmat_af0-solid1 2966 2960 multiply connected (shared edge) quadribbed_body_top_af1-solid-siderings-73-solid1 654 656 multiply connected (shared edge) quadribbed_body_top_af1-solid-siderings-72-solid1 664 665 multiply connected (shared edge) quadribbed_body_top_af1-solid-siderings-solid1 682 680 multiply connected (shared edge) quadribbed_body_top_af1-solid-siderings_af0-solid1 648 647 multiply connected (shared edge) quadribbed_body_top_af1-solid:1 3920 3842 multiply connected (shared edge) pipe_connetions_cc-71-solid1-quadribbed_body_bottom_af0-solid 690 692 multiply connected (shared edge) pipe_connetions_cc-71-solid1-quadribbed_body_top_af1-solid 698 699 multiply connected (shared edge) pipe_connetions_cc-71-solid1:1 841 1682 ok (non-closed singly connected) pipe_connetions_cc-solid1-quadribbed_body_bottom_af0-solid 622 623 multiply connected (shared edge) pipe_connetions_cc-solid1-quadribbed_body_top_af1-solid 690 692 multiply connected (shared edge) pipe_connetions_cc-solid1:1 838 1674 ok (non-closed singly connected) quadribbed_body_top_af1-solid-socket_for_sensor_solid_1-solid1 370 370 multiply connected (shared edge) socket_for_sensor_solid_1-solid1:1 549 1098 ok (non-closed singly connected) sensing_element-65-solid-sensor_innertube-67-solid 5606 5511 multiply connected (shared edge) sensing_element-65-solid-sensor_protectiontube-66-solid1 300 288 multiply connected (shared edge) sensing_element-65-solid-socket_for_sensor_solid_1-solid1 1098 1098 multiply connected (shared edge) sensing_element-65-solid:1 329 658 ok (non-closed singly connected) ".*" 205728 225391 multiply connected (shared edge) Detected 239987 bad edges (possibly relevant for finite-area) Checking faceZone topology for multiply connected surfaces... FaceZone Faces Points Surface topology interior--welding_2-54-solid1 1786 1902 multiply connected (shared edge) interior--welding_2-solid1 1791 1907 multiply connected (shared edge) interior--pipe_connetions_cc-solid1 15292 14864 multiply connected (shared edge) interior--socket_for_sensor_solid_1-solid1 24486 21393 multiply connected (shared edge) interior--sensing_element-65-solid 261154 220882 multiply connected (shared edge) interior--sensor_innertube-67-solid 207167 179648 multiply connected (shared edge) interior--pipe_connetions_cc-71-solid1 16021 15470 multiply connected (shared edge) interior--fluid:substrate:2 73326 55473 multiply connected (shared edge) interior--fluid:3 156278 113388 multiply connected (shared edge) interior--recessed_cushioningmat_af0-solid1 42885 39359 multiply connected (shared edge) interior--sensor_protectiontube-66-solid1 127338 113340 multiply connected (shared edge) interior--fluid:0 1278464 891753 multiply connected (shared edge) interior--siderings-solid1 11096 10909 multiply connected (shared edge) interior--siderings-72-solid1 10649 10518 multiply connected (shared edge) interior--siderings-73-solid1 10221 10099 multiply connected (shared edge) interior--fluid:substrate:1 72314 54691 multiply connected (shared edge) interior--recessed_cushioningmat-solid1 41795 38478 multiply connected (shared edge) interior--siderings_af0-solid1 9975 9871 multiply connected (shared edge) interior--quadribbed_body_bottom_af0-solid 175079 162834 multiply connected (shared edge) interior--fluid:1 169162 120900 multiply connected (shared edge) interior--quadribbed_body_top_af1-solid 188517 175709 multiply connected (shared edge) honeycomb-solid1 695 1387 ok (non-closed singly connected) honeycomb_af0-solid1 738 1473 ok (non-closed singly connected) honeycomb-solid1:1 709 1415 ok (non-closed singly connected) honeycomb_af0-solid1:1 695 1387 ok (non-closed singly connected) <<Writing 2097438 conflicting points to set nonManifoldPoints Checking basic cellZone addressing... CellZone Cells Points VolumeBoundingBox quadribbed_body_top_af1-solid 35632 175777 140488.5687 (-89.25303047 -495.3971674 126.6885722) (92.00181648 -420.6894226 431.8766174) fluid:1 33570 120900 364948.8778 (-67.35107436 -493.3719532 85.38852855) (67.62889772 -376.3692818 188.2706778) quadribbed_body_bottom_af0-solid 33106 162902 129282.6741 (-89.18355249 -442.9903589 141.0764618) (92.0444393 -390.6283942 431.8763428) siderings_af0-solid1 2063 9875 5538.543623 (-65.02862755 -493.3960695 371.06991) (69.9717266 -392.6567879 375.7563556) recessed_cushioningmat-solid1 7631 38482 140909.9657 (-67.29843546 -493.3788712 189.5840797) (68.62098676 -392.6321115 267.7647698) fluid:substrate:1 13647 54691 782565.9499 (-62.31094676 -488.3775689 186.6470244) (63.64515801 -397.640984 270.7017878) siderings-73-solid1 2100 10103 5532.214945 (-67.3300333 -493.3739302 186.5843062) (67.66477203 -392.6306958 191.2707634) siderings-72-solid1 2181 10522 5533.248115 (-66.34006556 -493.3846924 266.0781007) (68.65987514 -392.6450566 270.7645569) siderings-solid1 2262 10913 5533.676383 (-66.02127606 -493.3870487 291.5760985) (68.97755891 -392.6451234 296.2625829) fluid:0 254574 891753 406230.5489 (-64.98911829 -493.3985064 374.0696653) (69.98967841 -392.656759 481.4665707) sensor_protectiontube-66-solid1 22295 113341 327.5374673 (-42.68133668 -480.8622351 390.9661809) (-23.50691186 -459.7457359 409.1832804) recessed_cushioningmat_af0-solid1 7800 39363 140896.0812 (-65.98622217 -493.3937832 294.5644307) (69.93310547 -392.6478643 372.7565797) fluid:3 30842 113388 238837.7495 (-66.30253869 -493.3864609 269.0778708) (68.94127875 -392.6408651 293.2628044) fluid:substrate:2 13822 55473 782645.0457 (-61.00912665 -488.3921419 291.6387288) (64.94941023 -397.6537144 375.6936107) pipe_connetions_cc-71-solid1 3263 15474 19776.58067 (-26.98878116 -451.360631 84.38826318) (26.99423409 -374.6371539 163.332589) sensor_innertube-67-solid 35816 179649 301.0792091 (-42.25021107 -480.5370971 392.6253623) (-25.04204015 -460.6072002 408.7350925) sensing_element-65-solid 41771 220882 2515.582575 (-50.10277567 -490.4136124 396.0486906) (-30.18830638 -467.1138687 415.8363787) socket_for_sensor_solid_1-solid1 4102 21393 5850.789181 (-53.73747886 -493.0283601 389.9834713) (-21.51146424 -458.4651551 419.7203729) pipe_connetions_cc-solid1 3132 14868 19666.48647 (-23.91994322 -470.0276303 420.8223445) (30.7930795 -416.0570606 481.4917884) welding_2-solid1 477 1919 524.1464666 (-28.98954527 -448.0972039 125.1002025) (28.99555016 -397.9132508 155.662292) welding_2-54-solid1 474 1914 525.6332165 (-25.79293374 -472.0130345 430.7962726) (32.18635419 -414.0590558 434.4954346) Checking basic pointZone addressing... No pointZones found. Checking geometry... Overall domain bounding box (-89.26570129 -495.4034358 84.38024139) (92.06241608 -374.6228638 481.4920349) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-2.692040361e-17 -3.0703598e-16 -2.291180947e-17) OK. Max cell openness = 3.150474567e-16 OK. Max aspect ratio = 40.46283584 OK. Minimum face area = 1.40953289e-05. Maximum face area = 107.5372978. Face area magnitudes OK. Min volume = 7.388465188e-06. Max volume = 1400.97198. Total volume = 3198430.98. Cell volumes OK. Mesh non-orthogonality Max: 77.49293932 average: 9.629569954 *Number of severely non-orthogonal (> 70 degrees) faces: 99. Non-orthogonality check OK. <<Writing 99 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 3.563607979 OK. Coupled point location match (average 0) OK. Failed 1 mesh checks. End |
reverse flow in centrifugal fan blades | kalm | CFX | 20 | December 2, 2023 07:25 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 05:39 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
