August 13, 2024, 07:10 |
How to read a text file in OpenFoam
BabuG
Rep Power: 2 |
Dears,
I am running a CFD case in which fluid and solid regions are present. The solid region (or the solid object) has to rotate at an angular velocity "omega". I could successfully launch the case with rotation. However, I want the solid object to oscillate (rotate in clockwise for some time and then rotate in anti-clock wise direction). How to setup this OpenFoam12 or 2406 versions preferably (2406) 1. Is there any inbuilt-functionality to read a data file with contains data of rotation (omega) with respect to time step. If such possibility is not there!!. 2. How to read a data file and assign the values to omega Thank you in advance |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 17:05 |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 09:06 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 04:23 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 13:41 |
