Laminar simpleFoam does not converge
Like Tree2Likes
  • 1 Post By Alczem
  • 1 Post By geth03
Old   August 5, 2024, 09:26
Default Laminar simpleFoam does not converge
Alberto
Gyros is on a distinguished road
Hello everyone!
I'm new to OpenFOAM and finite volume simulations, and I'm trying to run a simulation using simpleFoam in a laminar regime. The fluid is incompressible and Newtonian, with the value of the dynamic viscosity of 3.3e-6. The most relevant velocity component is Uz. The Reynolds number for my problem is around 6000-7000, so it's likely in a transient regime. However, based on experimental results, I do not expect turbulence.
My issue is that the solution converges when I set the residual control to 1.e-3, but it does not converge at 1.e-4. I've tried changing the URF, using different schemes and solvers, and testing various types of meshes. I even tried to ramp up the viscosity and the boundary velocity as well. While the residuals vary somewhat, I still can't achieve the desired convergence.
I can't share specifics about the mesh, but running the code:
checkMesh -allGeometry -allTopology
yields "Mesh OK" with a non-orthogonality around 55.
Does anyone have any ideas on what might be wrong with my case? I have copied the relevant files below:
fvSchemes (but I tried a lot of different schemes and well):
ddtSchemes
    default         steadyState;
gradSchemes
    default           cellMDLimited Gauss linear 0.5;
    grad(p)           cellMDLimited leastSquares 0.5;
divSchemes
    //Working Schemes
    default         none;
    div(phi,U)      bounded Gauss linearUpwindV grad(U);
   div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default          Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fvSolutions (I tried the PCG and PBiCGstab combination as well)
solvers
    p
        solver          GAMG;
        tolerance       1e-8;
        relTol          0.;
        smoother        GaussSeidel;
        nPreSweeps      0;
        nPostSweeps     2;
        cacheAgglomeration      on;
        agglomerator          faceAreaPair;
        nCellsInCoarsestLevel 1000;
        mergeLevels 1;
        minIter 3;
U
        solver          GAMG;
        tolerance        1e-12;
        relTol           0.;
        minIter 3;
PIMPLE
        nOuterCorrectors 4;
        nCorrectors     1;
        nNonOrthogonalCorrectors 1;
        pRefCell        0;
        pRefValue       0;
SIMPLE
    nOuterCorrectors 1;
    nNonOrthogonalCorrectors 3;
    nCorrectors 1;
    consistent      yes;
    residualControl
        p               1e-4;
        U               1e-4;
relaxationFactors
    fields
      default           0;
        p               0.7;
    equations
        default           0;
        U               0.1;
potentialFlow
    nNonOrthogonalCorrectors 15;
0/p
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    Inlet
        type            zeroGradient;
    Outlet
        type            fixedValue;
        value           uniform 0;
    Wall
        type            zeroGradient;
0/U
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0. 0. 0.);
boundaryField
    Inlet
        type            fixedValue;
        value           uniform (0 0 0.604201);
    Outlet
      type            zeroGradient;
    Wall
        type            noSlip;
Last iterations (I stopped at 2000 in this case, but You can see that the residuals of Ux and Uy are increasing):
Time = 1997
GAMG:  Solving for Ux, Initial residual = 0.00102127988842, Final residual = 3.78843410895e-14, No Iterations 4
GAMG:  Solving for Uy, Initial residual = 0.00102127873465, Final residual = 3.66920583825e-14, No Iterations 4
GAMG:  Solving for Uz, Initial residual = 6.84716366464e-05, Final residual = 1.93793345052e-13, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.000264545972474, Final residual = 7.91106068333e-09, No Iterations 20
GAMG:  Solving for p, Initial residual = 2.15211854916e-05, Final residual = 6.44141210732e-09, No Iterations 12
GAMG:  Solving for p, Initial residual = 3.90868944978e-06, Final residual = 9.50674813054e-09, No Iterations 8
GAMG:  Solving for p, Initial residual = 7.78381617016e-07, Final residual = 6.01070548673e-09, No Iterations 6
time step continuity errors : sum local = 4.26235491328e-07, global = 2.80680362419e-09, cumulative = -0.000273761795971
ExecutionTime = 2396.85 s  ClockTime = 2398 s
Time = 1998
GAMG:  Solving for Ux, Initial residual = 0.00102210900128, Final residual = 3.78439650521e-14, No Iterations 4
GAMG:  Solving for Uy, Initial residual = 0.0010221077803, Final residual = 3.66159293664e-14, No Iterations 4
GAMG:  Solving for Uz, Initial residual = 6.85176412086e-05, Final residual = 1.9473011416e-13, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.000266006998858, Final residual = 5.91567974654e-09, No Iterations 22
GAMG:  Solving for p, Initial residual = 2.1515117835e-05, Final residual = 7.53548884828e-09, No Iterations 10
GAMG:  Solving for p, Initial residual = 3.92752594773e-06, Final residual = 5.16086621663e-09, No Iterations 8
GAMG:  Solving for p, Initial residual = 7.74893068203e-07, Final residual = 5.43745707001e-09, No Iterations 6
time step continuity errors : sum local = 3.85463673237e-07, global = 5.3841699939e-09, cumulative = -0.000273756411801
ExecutionTime = 2398.26 s  ClockTime = 2400 s
Time = 1999
GAMG:  Solving for Ux, Initial residual = 0.00102287550141, Final residual = 3.78609861112e-14, No Iterations 4
GAMG:  Solving for Uy, Initial residual = 0.00102287422025, Final residual = 3.66569823254e-14, No Iterations 4
GAMG:  Solving for Uz, Initial residual = 6.85632941851e-05, Final residual = 1.956562032e-13, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.000260697977053, Final residual = 6.70872317025e-09, No Iterations 22
GAMG:  Solving for p, Initial residual = 2.18089265959e-05, Final residual = 5.60718051847e-09, No Iterations 10
GAMG:  Solving for p, Initial residual = 3.93294974769e-06, Final residual = 5.50368960367e-09, No Iterations 8
GAMG:  Solving for p, Initial residual = 7.68216082053e-07, Final residual = 4.81018719123e-09, No Iterations 6
time step continuity errors : sum local = 3.40865014092e-07, global = 4.70000373712e-09, cumulative = -0.000273751711797
ExecutionTime = 2399.61 s  ClockTime = 2401 s
Time = 2000
GAMG:  Solving for Ux, Initial residual = 0.0010238956283, Final residual = 3.78588038726e-14, No Iterations 4
GAMG:  Solving for Uy, Initial residual = 0.0010238944556, Final residual = 3.66586957047e-14, No Iterations 4
GAMG:  Solving for Uz, Initial residual = 6.86066516146e-05, Final residual = 1.95873799441e-13, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.000260974085062, Final residual = 6.49579910429e-09, No Iterations 22
GAMG:  Solving for p, Initial residual = 2.18087255747e-05, Final residual = 6.20127413556e-09, No Iterations 10
GAMG:  Solving for p, Initial residual = 3.93472473082e-06, Final residual = 6.10523977338e-09, No Iterations 8
GAMG:  Solving for p, Initial residual = 7.62268058637e-07, Final residual = 4.27575427211e-09, No Iterations 6
time step continuity errors : sum local = 3.02870846598e-07, global = 5.26248358204e-09, cumulative = -0.000273746449314
ExecutionTime = 2401.57 s  ClockTime = 2403 s
Residuals: https://drive.google.com/file/d/1oGP...ew?usp=sharing
Thank you to anyone who can offer me some suggestions to solve this problem.
Regards.
Gyros is offline   Reply With Quote
Old   August 6, 2024, 07:21
Alczem is on a distinguished road
Hey!
Other than residuals, do you monitor any physical values in your domain, such as velocity probes? Your residuals look ok to me, not the lowest ever achieved, but not bad either. If your velocity field is stable, I would say you have a decent solution.
Your relaxation factor for U is really low considering you are using the consistent option. It was not stable with a high value?
Last thing, I would avoir any kind of gradient limiter for grad(p), there are several threads recommending the same thing.
Gyros likes this.
Alczem is offline   Reply With Quote
Old   August 6, 2024, 08:27
geth03 is on a distinguished road
1. based on your Reynolds-Number nobody can tell what you are simulating. for pipes you are in turbulent regime, for flat plate you are in laminar regime.
2. you should not limit the pressure gradient.
3. why do you use urf for pressure field in the simple-c algo? when your mesh is that good, why do you use nonOrtho-Correctors?
SIMPLE
    nNonOrthogonalCorrectors 0;
    consistent      yes;
    residualControl
        //adjust to whatever you want
relaxationFactors
    equations
        U               0.9; // 0.9 is more stable but 0.95 more convergent
        ".*"            0.9; // 0.9 is more stable but 0.95 more convergent
first fix your fvschemes and fvsolution dicts.
using simplefoam does not guarantee a steady state solution if a steady state solution does not exist. a laminar flow is no promise for steady state case if you have periodic flow for example. what you can do is drop the reynolds number to low values (increase viscosity, decrease velocity ...) and reach a creeping flow condition, it is likely that you will find a steady state solution, from there you can increse reynolds number again.
one more tip: you can use first order upwind also that will add numerical diffusion and drop residual levels. but keep in mind to switch back to second order upwind afterwards. your residuals will increase again, but the solution will be better.
Gyros likes this.
geth03 is offline   Reply With Quote
Old   August 6, 2024, 12:11
Alberto
Thank you both for your kind responses. I will avoid the limiters for grad(p).
Dear Alczem,
Yes, I checked the velocity solution but it doesn't seem to me that it reaches a stable solution. And, yes, with higher URF the residuals are higher and oscillate a lot.
Dear geth03,
I used the URF for the pressure because, by trial and error, I thought I was getting a better solution, but removing the limiter for the grad(p) it seems to work better without URF. I used nonOrtho-Correctors to try to stabilize the solution and not have problems with the mesh, but it's probably useless in my case. Thank you for your tips, it seems that by using upwind and then changing scheme I get a better solution, and I will try to reach convergence using this method.
Ncrit for a glider Xfoil. How to use it. GPT4 answer AlanMattanó Main CFD Forum 0 April 10, 2023 13:16
simpleFoam turbulent flow laminar results NicolasB OpenFOAM Running, Solving & CFD 22 March 25, 2016 13:31
Laminar doesn't converge; Turbulent models do? Amit FLUENT 11 April 23, 2015 23:55
simpleFoam pipe flow case doesn't converge me3840 OpenFOAM Running, Solving & CFD 5 February 8, 2014 14:54
SimpleFoam: Laminar vs. Turbulent Convergence JasonG OpenFOAM 0 June 2, 2011 09:29
