Help on detecting wrong configuration
Old   June 3, 2024, 17:02
Default Help on detecting wrong configuration
Matias Alberto Aguirre
maguirre is on a distinguished road
Hi everyone!
I'm trying to solve a case where an electric arc (represented as a zone filled with "superheated air", any electromagnetic simulation is not taken into account) heats the air inside a metal box, see attached GMSH geometry screenshot.
I'm using OpenFoam v11 (openfoam.org version 11) with foamRun application and fluid solver. Transonic option is set on. I set a heatSource at the little dot, called blastSource, which radiates with P1 model to the rest of the volume. Also, buoyancy is applied. You can see all this configuration here:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      fvModels;
volumetricHeatSource
    type            heatSource;
    select          cellZone;
    cellZone        blastSource;
    q               7600000000;//1486693; 0.4*4553000 aprox. 1.8e6
radiationCoeffs
    type	    radiation;
    libs	    ("libradiationModels.so");
buoyancyForce
    type	    buoyancyForce;
FoamFile
    format      ascii;
    class       dictionary;
    object      radiationProperties;
radiationModel  P1;
// Number of flow iterations per radiation iteration
solverFreq 10;
absorptionEmissionModel constant;
constantCoeffs
   absorptivity    0.5;
   emissivity      0.5;
   E               0;
scatterModel    none;
sootModel       none;
Around this dot, there is a surface called plasmaSurf which is applied the MarshakRadiation condition.
FoamFile
    format      ascii;
    class       volScalarField;
    location    "0";
    object      G;
dimensions      [1 0 -3 0 0 0 0];
internalField   uniform 0;
boundaryField
    back
        type            zeroGradient;
    front
        type            zeroGradient;
    bottom
        type            zeroGradient;
    right
        type            zeroGradient;
    top
        type            zeroGradient;
    left
        type            zeroGradient;
    opening
        type            zeroGradient;
    plasmaSurf
	type		MarshakRadiation; //constantAbsorptionEmission;
	emissivityMode	lookup;
	emissivity	uniform 1.0;
	T		T;
	value		uniform 0;
The problem is I do not see much change in the temperature profile, see Paraview attached image. I thought it could be of a wrong BC at plasmaSurf but I think InletOutletTotalTemperature is the correct choice
FoamFile
    format      binary;
    location    "0";
    object      T;
#include	"inputs"
dimensions      [0 0 0 1 0 0 0];
internalField   uniform $temperature;
boundaryField
    back
        type            zeroGradient;
    front
        type            zeroGradient;
    bottom
        type            zeroGradient;
    right
        type            zeroGradient;
    top
        type            zeroGradient;
    left
        type            zeroGradient;
    opening
        type            zeroGradient;
    plasmaSurf
	type		inletOutletTotalTemperature;
	gamma		1.4;
	Qr		Qr;
	T0		uniform $temperature;
(The code asks me for the definition of Qr, although it is always zero. I think it is because Qr is for fvDOM radiation model, still, I don't know why it is needed)
That T profile does not change much throughout the simulation (0.25 s with a 1e-06 s as deltaT), those few cells are the only ones heated. Does anyone know what could be the problem? Maybe I set wrong the radiation model? Or any BC?
Cheers,
Matias.
maguirre is offline   Reply With Quote
fluid; radiation;
FOAM FATAL IO ERROR: Wrong token type francedisab OpenFOAM 4 January 30, 2024 07:09
What's wrong with COMSOL? andy.sun.wei COMSOL 9 March 23, 2022 13:30
Something wrong running rhoSimpleFoam (urgent!) PeterShi OpenFOAM Running, Solving & CFD 7 March 1, 2017 10:21
udf error srihari FLUENT 1 October 31, 2016 15:18
calculating missle configuration by panel method Daniel Main CFD Forum 5 January 6, 2003 09:09
