CastalletedMesh is good but snapping creates errors |
May 8, 2024, 15:16 |
Marius
Rep Power: 4 |
I am trying to create a simulation for a duct. I already followed the tutorial from Tobi Holzmann on Youtube and created a combined stl in Salome that has the walls, inlet and outlet in it. I also followed the tutorial to create the backgroundMesh / blockMesh. When I run snappyHexMesh and only turn on the castallatedMesh the checkMesh is fine without any issues, but as soon as I run the case with snapping activated I have multiple mesh check errors. I also tried to export a coarser and finer mesh from Salome to see how the results change. If I make it more coarse I have less errors. Maybe someone could take a look at it. I think the issue is already in the mesh I export from Salome, but I have no idea to be honest. What do you think about the mesh file? I uploaded it on my google drive: https://drive.google.com/file/d/1CER...ew?usp=sharing I can also share all my settings if needed. This is the checkMesh result when castallatedMesh and snapping is active in snappyHexMesh: Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Check mesh... Enabling all (cell, face, edge, point) topology checks. Enabling all geometry checks. Time = 0 Mesh stats points: 16122045 faces: 43067034 internal faces: 40796061 cells: 13628462 faces per cell: 6.15353 boundary patches: 3 point zones: 1 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 11854173 prisms: 290583 wedges: 0 pyramids: 0 tet wedges: 45 tetrahedra: 0 polyhedra: 1483661 Breakdown of polyhedra by number of faces: faces number of cells 4 191202 5 306498 6 196869 9 588074 12 167246 15 33688 18 84 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Face-face connectivity OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box walls 1880080 2152825 ok (non-closed singly connected) (0.277328 -0.332841 -0.437397) (0.543067 0.202896 0.15) outlet 283044 325371 ok (non-closed singly connected) (0.279425 0.00409194 -0.437397) (0.543067 0.202896 -0.265074) inlet 107849 108453 ok (non-closed singly connected) (0.290787 -0.332841 0.149454) (0.483317 -0.194515 0.15) ".*" 2270973 2582660 ok (closed singly connected) (0.277328 -0.332841 -0.437397) (0.543067 0.202896 0.15) Checking faceZone topology for multiply connected surfaces... No faceZones found. Checking basic cellZone addressing... No cellZones found. Checking basic pointZone addressing... PointZone PointsBoundingBox frozenPoints 0(1e+150 1e+150 1e+150) (-1e+150 -1e+150 -1e+150) Checking geometry... Overall domain bounding box (0.277328 -0.332841 -0.437397) (0.543067 0.202896 0.15) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (1.48119e-15 9.69119e-15 -3.3278e-14) OK. Max cell openness = 1.18214e-15 OK. Max aspect ratio = 32.4546 OK. Minimum face area = 2.61988e-09. Maximum face area = 5.53432e-05. Face area magnitudes OK. Min volume = 2.09625e-12. Max volume = 4.04742e-07. Total volume = 0.0192226. Cell volumes OK. Mesh non-orthogonality Max: 75.3513 average: 16.0218 *Number of severely non-orthogonal (> 70 degrees) faces: 53. Non-orthogonality check OK. <<Writing 53 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 2.27597 OK. Coupled point location match (average 0) OK. ***Error in face tets: 94 faces with low quality or negative volume decomposition tets. <<Writing 94 faces with low quality or negative volume decomposition tets to set lowQualityTetFaces Min/max edge length = 2.94485e-06 0.00746041 OK. *There are 46297 faces with concave angles between consecutive edges. Max concave angle = 72.9746 degrees. <<Writing 46297 faces with concave angles to set concaveFaces Face flatness (1 = flat, 0 = butterfly) : min = 0.614082 average = 0.999016 *There are 43 faces with ratio between projected and actual area < 0.8 Minimum ratio (minimum flatness, maximum warpage) = 0.614082 <<Writing 43 warped faces to set warpedFaces Cell determinant (wellposedness) : minimum: 8.52307e-10 average: 1.57495 ***Cells with small determinant (< 0.001) found, number of cells: 173668 <<Writing 173668 under-determined cells to set underdeterminedCells ***Concave cells (using face planes) found, number of cells: 404035 <<Writing 404035 concave cells to set concaveCells Face interpolation weight : minimum: 0.00797014 average: 0.459465 ***Faces with small interpolation weight (< 0.05) found, number of faces: 64 <<Writing 64 faces with low interpolation weights to set lowWeightFaces Face volume ratio : minimum: 0.0216916 average: 0.811961 Face volume ratio check OK. Failed 4 mesh checks. End Marius |
May 8, 2024, 17:32 |
Will Kernkamp
Rep Power: 14 |
The stl looks fine to me.
The number of cells 13+ million seems very high for this simple geometry. It is not an airplane. Easier and quicker to troubleshoot with less cells. Are you requesting layers on the surface? If yes, turn it off for now. |
May 9, 2024, 05:06 |
Marius
Rep Power: 4 |
Thank you for the feedback. No, I am not using addLayers if you mean that. I changed some settings and reduced the number of cells. I am getting less errors, but still have issues. Could this just be a wrong config as the mesh itself looks good?
Current checkMesh: Code:
Create time Create mesh for time = 0 Check mesh... Enabling all (cell, face, edge, point) topology checks. Enabling all geometry checks. Time = 0 Mesh stats points: 3865244 faces: 10453102 internal faces: 9947098 cells: 3330659 faces per cell: 6.12497 boundary patches: 3 point zones: 1 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 2869307 prisms: 104547 wedges: 0 pyramids: 0 tet wedges: 227 tetrahedra: 1 polyhedra: 356577 Breakdown of polyhedra by number of faces: faces number of cells 4 73904 5 53055 6 44851 9 136897 12 39838 15 7997 18 35 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Face-face connectivity OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box walls 421003 486202 ok (non-closed singly connected) (0.277328 -0.33284 -0.437448) (0.543041 0.202946 0.15) outlet 58080 67686 ok (non-closed singly connected) (0.279424 0.00381865 -0.437448) (0.543041 0.202946 -0.265026) inlet 26921 27199 ok (non-closed singly connected) (0.290788 -0.33284 0.148975) (0.483297 -0.194507 0.150043) ".*" 506004 579218 ok (closed singly connected) (0.277328 -0.33284 -0.437448) (0.543041 0.202946 0.150043) Checking faceZone topology for multiply connected surfaces... No faceZones found. Checking basic cellZone addressing... No cellZones found. Checking basic pointZone addressing... PointZone PointsBoundingBox frozenPoints 0(1e+150 1e+150 1e+150) (-1e+150 -1e+150 -1e+150) Checking geometry... Overall domain bounding box (0.277328 -0.33284 -0.437448) (0.543041 0.202946 0.150043) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-1.40715e-15 6.12712e-15 4.49513e-15) OK. Max cell openness = 3.30839e-16 OK. Max aspect ratio = 15.7768 OK. Minimum face area = 6.1379e-08. Maximum face area = 5.56495e-05. Face area magnitudes OK. Min volume = 2.93545e-11. Max volume = 4.07347e-07. Total volume = 0.0193077. Cell volumes OK. Mesh non-orthogonality Max: 80.5465 average: 10.321 *Number of severely non-orthogonal (> 70 degrees) faces: 67. Non-orthogonality check OK. <<Writing 67 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 2.14612 OK. Coupled point location match (average 0) OK. Face tets OK. Min/max edge length = 7.23737e-05 0.00749861 OK. *There are 133 faces with concave angles between consecutive edges. Max concave angle = 89.4954 degrees. <<Writing 133 faces with concave angles to set concaveFaces Face flatness (1 = flat, 0 = butterfly) : min = 0.757178 average = 0.998955 *There are 10 faces with ratio between projected and actual area < 0.8 Minimum ratio (minimum flatness, maximum warpage) = 0.757178 <<Writing 10 warped faces to set warpedFaces Cell determinant (wellposedness) : minimum: 5.15721e-08 average: 1.58641 ***Cells with small determinant (< 0.001) found, number of cells: 106 <<Writing 106 under-determined cells to set underdeterminedCells ***Concave cells (using face planes) found, number of cells: 91726 <<Writing 91726 concave cells to set concaveCells Face interpolation weight : minimum: 0.0641447 average: 0.470851 Face interpolation weight check OK. Face volume ratio : minimum: 0.0438647 average: 0.851465 Face volume ratio check OK. Failed 2 mesh checks. End |
May 9, 2024, 11:54 |
Will Kernkamp
Rep Power: 14 |
The offending cells are written to files. Might be a good idea to look to where things are going wrong.
May 9, 2024, 14:43 |
Marius
Rep Power: 4 |
This is what the concaveCells set looks like.
May 9, 2024, 15:57 |
Will Kernkamp
Rep Power: 14 |
Very Odd. These cells look rectangular. Also, they are throughout the domain.
Can you have a closer look at a couple of individual cells. T spot exactly what is wrong with them. How did you set up your run? Maybe start over from this example? https://holzmann-cfd.com/community/t...meshing-a-pipe |
May 9, 2024, 17:38 |
Will Kernkamp
Rep Power: 14 |
It might help to look at the tutorial iglooWithFridgesDirectionalRefinement.
look in system/snappyHexmesh and use that file in your own setup. Note you also need to substitute fvSolution and fvSchemes because thedisplacementSolver used to add layers requires it. |
May 18, 2024, 14:09 |
Marius
Rep Power: 4 |
Thanks for the tip with the tutorial files.
I managed to get down to 1 concaveCells and 17 faces with concave angles. I also checked the VTK files and all of those cells and faces are on the edges of the model (see screenshot). How can I get rid of those? As soon as I change any of the settings in snappyHexMeshDict it gets worse. I am currently testing it without even adding the layers. This is how my current snappyHexMeshDict looks like: Code:
FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } castellatedMesh true; snap true; addLayers false; geometry { ductPipe { type triSurfaceMesh; file combined.stl; regions { inlet { name inlet; } outlet { name outlet; } walls { name walls; } } } }; // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 200000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 4000000; // The surface refinement loop might spend lots of iterations refining just a // few cells. This setting will cause refinement to stop if <= minimumRefine // are selected for refinement. Note: it will at least do one iteration // (unless the number of cells to refine is 0) minRefinementCells 100; // Allow a certain level of imbalance during refining // (since balancing is quite expensive) // Expressed as fraction of perfect balance (= overall number of cells / // nProcs). 0=balance always. maxLoadUnbalance 0.10; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. nCellsBetweenLevels 1; features ( { file "combined.eMesh"; // Feature edges extracted earlier level 3; // Feature refinement level } ); refinementSurfaces { ductPipe { level (1 1); regions { inlet { level (2 2); patchInfo { type patch; }} outlet { level (2 2); patchInfo { type patch; }} walls { level (2 3); patchInfo { type wall; inGroups (walls); }} } patchInfo { type wall; inGroups (walls); } } }; refinementRegions { ductPipe { mode inside; levels ((0.01 3)); } }; resolveFeatureAngle 30; locationInMesh (0.4 0.04 -0.2); // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces true; }; // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 3; //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 4.0; //- Number of mesh displacement relaxation iterations. nSolveIter 10; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 15; // Feature snapping //- Number of feature edge snapping iterations. // Leave out altogether to disable. nFeatureSnapIter 10; //- Detect (geometric only) features by sampling the surface // (default=false). implicitFeatureSnap true; //- Use castellatedMeshControls::features (default = true) explicitFeatureSnap true; //- Detect points on multiple surfaces (only for explicitFeatureSnap) multiRegionFeatureSnap false; }; // Controls for adding boundary layers addLayersControls { relativeSizes true; layers { walls { nSurfaceLayers 3; } } // Expansion factor for layer mesh expansionRatio 1.0; // Wanted thickness of final added cell layer. If multiple layers // is the thickness of the layer furthest away from the wall. // Relative to undistorted size of cell outside layer. // See relativeSizes parameter. finalLayerThickness 0.05; // Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. minThickness 0.005; // If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. // Note: changed(corrected) w.r.t 1.7.x! (didn't do anything in 1.7.x) nGrow 0; // Advanced settings // When not to extrude surface. 0 is flat surface, 90 is when two faces // are perpendicular featureAngle 60; // At non-patched sides allow mesh to slip if extrusion direction makes // angle larger than slipFeatureAngle. slipFeatureAngle 30; // Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 3; // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 10; // Smooth layer thickness over surface patches nSmoothThickness 10; // // Stop layer growth on highly warped cells maxFaceThicknessRatio 0.5; // // Reduce layer growth where ratio thickness to medial // // distance is large maxThicknessToMedialRatio 0.3; // // Angle used to pick up medial axis points // // Note: changed(corrected) w.r.t 1.7.x! 90 degrees corresponds to 130 // // in 1.7.x. minMedialAxisAngle 90; //- Use displacementMotionSolver to shrink mesh meshShrinker displacementMotionSolver; //- Use laplacian for shrinking solver displacementLaplacian; displacementLaplacianCoeffs { diffusivity quadratic inverseDistance (walls); } // Create buffer region for new layer terminations nBufferCellsNoExtrude 0; // Overall max number of layer addition iterations. The mesher will exit // if it reaches this number of iterations; possibly with an illegal // mesh. nLayerIter 100; // Max number of iterations after which relaxed meshQuality controls // get used. Up to nRelaxIter it uses the settings in meshQualityControls, // after nRelaxIter it uses the values in meshQualityControls::relaxed. //nRelaxedIter 20; }; // Mesh quality controls meshQualityControls { #include "meshQualityDict" // Optional : some meshing phases allow usage of relaxed rules. // See e.g. addLayersControls::nRelaxedIter. relaxed { //- Maximum non-orthogonality allowed. Set to 180 to disable. maxNonOrtho 65; } // Advanced //- Number of error distribution iterations nSmoothScale 4; //- amount to scale back displacement at error points errorReduction 0.75; }; // Advanced // Write flags writeFlags ( scalarLevels layerSets layerFields // write volScalarField for layer coverage ); // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1e-6; And my meshQualityDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2312 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object meshQualityDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Include defaults parameters from master dictionary #includeEtc "caseDicts/meshQualityDict" nSmoothScale 4; errorReduction 0.75; // Additional quality controls maxNonOrtho 65; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 70; minFlatness 0.5; minVol 1e-15; minTetQuality 1e-18; minArea -1; minTwist 0.02; minDeterminant 0.001; minFaceWeight 0.02; minVolRatio 0.01; minTriangleTwist -1; // ************************************************************************* // Maybe someone with more experience could test my setup. No idea how to continue right now. And this is still a relatively easy geometry which is frustrating... |
May 19, 2024, 05:36 |
#9 |
Marius
Rep Power: 4 |
I managed to get rid of the concaveCells by increasing the resolveFeatureAngle to 60.
There are now 8 concave angles left. I tried to run simpleFoam and this is how my residuals look like: |
May 19, 2024, 05:46 |
#10 |
M
Rep Power: 13 |
That's not good.
You seem to focus on concave metric, what is skewness and nonOrthogonality in this case? More hints: - why do you have implicitFeatureSnap and explicitFeatureSnap active? Its either one or the other. I always mesh with the default. Don't know what snappy does if both are on. - increase cellsBetweenLevels to 2, 3 or 4. Heads up: this WILL increase the size of the mesh. But it's usually a good way to improve the mesh near walls if the wall cell level is higher than in the surrounding mesh. It becomes even more important if you want to use layers on these faces. |
May 19, 2024, 05:49 |
#11 |
Marius
Rep Power: 4 |
I already disabled implicitFeatureSnap in the last run. You are right, it should only be one.
This is what the latest checkMesh looks like. Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2312 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _1d8f0d55f7-20231221 OPENFOAM=2312 version=v2312 Arch : "LSB;label=32;scalar=64" Exec : checkMesh -allGeometry -allTopology -writeSets vtk Date : May 19 2024 Time : 08:52:20 Host : MacBook-Pro.fritz.box PID : 30583 I/O : uncollated Case : /Users/marius.erlenbruch/Downloads/CFD-Openfoam/Radiator-coarse-2 nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Check mesh... Enabling all (cell, face, edge, point) topology checks. Enabling all geometry checks. Reconstructing and writing vtk representation of all faceSets and cellSets. Time = 0 Mesh stats points: 401336 faces: 1177231 internal faces: 1145538 cells: 390387 faces per cell: 5.94991 boundary patches: 3 point zones: 1 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 375621 prisms: 6760 wedges: 0 pyramids: 0 tet wedges: 86 tetrahedra: 2 polyhedra: 7918 Breakdown of polyhedra by number of faces: faces number of cells 4 4699 5 3219 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Face-face connectivity OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box walls 26374 30555 ok (non-closed singly connected) (0.277333 -0.332837 -0.437441) (0.543034 0.202975 0.15) outlet 3620 4296 ok (non-closed singly connected) (0.279424 0.00407739 -0.437441) (0.543034 0.202975 -0.265192) inlet 1699 1763 ok (non-closed singly connected) (0.290792 -0.332837 0.14946) (0.483291 -0.194518 0.15) ".*" 31693 36196 ok (closed singly connected) (0.277333 -0.332837 -0.437441) (0.543034 0.202975 0.15) Checking faceZone topology for multiply connected surfaces... No faceZones found. Checking basic cellZone addressing... No cellZones found. Checking basic pointZone addressing... PointZone PointsBoundingBox frozenPoints 0(1e+150 1e+150 1e+150) (-1e+150 -1e+150 -1e+150) Checking geometry... Overall domain bounding box (0.277333 -0.332837 -0.437441) (0.543034 0.202975 0.15) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-1.78687e-17 2.02728e-16 -2.22045e-16) OK. Max cell openness = 3.00327e-16 OK. Max aspect ratio = 5.32817 OK. Minimum face area = 2.2764e-06. Maximum face area = 4.12514e-05. Face area magnitudes OK. Min volume = 4.22218e-09. Max volume = 8.98825e-08. Total volume = 0.0193022. Cell volumes OK. Mesh non-orthogonality Max: 60.4705 average: 3.4999 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.76827 OK. Coupled point location match (average 0) OK. Face tets OK. Min/max edge length = 0.000237348 0.0090701 OK. *There are 8 faces with concave angles between consecutive edges. Max concave angle = 51.7665 degrees. <<Writing 8 faces with concave angles to set concaveFaces Face flatness (1 = flat, 0 = butterfly) : min = 0.85528 average = 0.999394 All face flatness OK. Cell determinant (wellposedness) : minimum: 0.0185579 average: 0.950219 Cell determinant check OK. Concave cell check OK. Face interpolation weight : minimum: 0.157128 average: 0.494249 Face interpolation weight check OK. Face volume ratio : minimum: 0.118938 average: 0.969777 Face volume ratio check OK. Mesh OK. End |
May 19, 2024, 16:32 |
#12 | |
Marius
Rep Power: 4 |
I tried increasing cellsBetweenLevels but the checkMesh stays the same - which is plausible because I only used the same cellLevels over all regions and now span from 1-3 for example. Another issue I have is on the edges: Code:
Removing mesh beyond surface intersections ------------------------------------------ Setting cellZones according to locationsInMesh: Location : (0.4 0.05 -0.25) cellZone : none For cellZone none found point (0.4 0.05 -0.25) in global region 1 out of 2 regions. --> FOAM Warning : From void Foam::meshRefinement::nearestFace(const Foam::labelUList &, const Foam::bitSet &, autoPtr<Foam::mapDistribute> &, Foam::labelList &, const Foam::label) const in file meshRefinement/meshRefinement.C at line 515 Did not visit some faces, e.g. face 0 at (0.293269 -0.344904 -0.158424) Keeping all cells containing inside points Selected for keeping : 124570 cells. Edge intersection testing: Number of edges : 427281 Number of edges to retest : 46140 Number of intersected edges : 51513 |
How to use PIMPLE properly? | floquation | OpenFOAM Running, Solving & CFD | 27 | August 12, 2024 11:15 |
LES, Courant Number, Crash, Sudden | Alhasan | OpenFOAM Running, Solving & CFD | 5 | November 22, 2019 03:05 |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 16:53 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 04:34 |
