weird result of nut
Old   December 14, 2023, 07:15
Exclamation weird result of nut
Saeed Jamshidi
saeed jamshidi is on a distinguished road
I have simulated turbulent flow around a cylinder, and I have come across strange figure of nut!!
here is the nut BC:
|  \\    /   O peration     | Version:  v2112                                |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    Bottom
        type            calculated;
        value           uniform 0;
    top
        type            calculated;
        value           uniform 0;
	cylinder
        type fixedValue;
		value uniform 0;
    front
        type            calculated;
        value           uniform 0;
	Back
        type            calculated;
        value           uniform 0;
would you tell me why nut has undergone these steep changes? at the inlet and locations with mesh refinement.
Besides, z component of the velocity does not make sence!!
By the way, I am using k omega SST.
thank you in advance.
saeed jamshidi is offline   Reply With Quote
Really weird sensitivity convergence result of SU2 6.2.0 Kevin_N SU2 Shape Design 0 July 18, 2019 05:00
FlLUENT Hydrofoil weird result Polymont FLUENT 1 June 21, 2019 05:03
Does a larger number of iterations for steady state gives better result? cfdnewb123 FLUENT 0 March 3, 2019 01:09
nut for kklomega giammy92 OpenFOAM 6 June 21, 2016 05:36
Airfoil 2D, very weird result Martin FLUENT 4 June 13, 2007 13:21
