v2306 floatingBody tutorial dimensions *100 error |
December 11, 2023, 11:47 |
Marco Trucchi
Hello!
I am new to OpenFOAM and pretty rusted in general on CFD. I am trying to start from the tutorial "floatingBody" v2306 and make some modifications. The original floatingBody tutorial runs seamlessy on my machine (I use Windows11, WSL Ubuntu, openfoam v2306). I am now trying to scale the problem, by multiplying all the dimension *100. The tutorial mesh is around 1m, but we need to compute a barge so we think that a global mesh of 100m will be ok for us. I made the modifications as you can see in attachment (diff result over all the tutorial directory vs my modified directory). Surprise, the job does not work (;-)). I get these errors in the log.overInterDyMFoam. many times this one: error: call of overloaded ‘sqr(int)’ is ambiguous then --> FOAM FATAL IO ERROR: (openfoam-2306) Failed wmake "dynamicCode/_39e562e5763abcfc00ccdd84bb7744835b6d3704/platforms/linux64GccDPInt32Opt/lib/libcodeStream_39e562e5763abcfc00ccdd84bb7744835b6d 3704.so" See the whole log.overInterDyMFoam in attachment. Any idea on how to solve this problem? Thank you!!! Marco |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 07:35 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 07:25 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
