how to reverse the rotordisk rotational direction |
November 17, 2023, 05:33 |
Rep Power: 5 |
I have tested some variations in the fvOptions of the rotorDisk tutorial, see below, but unfortunately I haven't found the way to reverse the rotational direction of the rotor. How this could be done? Thank you Code:
disk { type rotorDisk; selectionMode cellZone; cellZone rotatingZone; fields (U); // Names of fields on which to apply source nBlades 3; // Number of blades tipEffect 0.96; // Normalised radius above which lift = 0 inletFlowType local; // Inlet flow type specification inletVelocity (0 1 0); geometryMode specified; origin (0 0 0); axis (0 1 0); refDirection (0 0 1); // Reference direction // - used as reference for psi angle rpm 1000; //pointAbove (0 0 0.25); trimModel fixedTrim; // fixed || targetForce rhoRef 1000; rhoInf 1; fixedTrimCoeffs { theta0 0; theta1c 0; theta1s 0; } flapCoeffs { beta0 0; // Coning angle [deg] beta1c 0; // Lateral flapping coeff (cos coeff) beta2s 0; // Longitudinal flapping coeff (sin coeff) } blade { data ( (profile1 (0.1 -6 0.02)) (profile1 (0.25 -6 0.02)) ); } profiles { profile1 { type lookup; data ( (-90 0.21 1.45) (-18 0.21 1.45) (-16 0.165 1.3) (-14 0.125 1.1) (-12 0.092 0.95) (-10 0.07 0.8) (-8 0.05 0.64) (-6 0.04 0.5) (-4 0.028 0.32) (-2 0.022 0.18) (0 0.02 0) (2 0.022 0.18) (4 0.028 0.32) (6 0.04 0.5) (8 0.05 0.64) (10 0.07 0.8) (12 0.092 0.95) (14 0.125 1.1) (16 0.165 1.3) (18 0.21 1.45) (90 0.21 1.45) ); } } } |
November 18, 2023, 17:25 |
Rep Power: 9 |
Is it not simply -1000 for rpm, or axis (0 -1 0);?
I am using it currently as well, but I find it will not run for rpm lower than 1000. Did you have this problem? Also, not sure if rpm is actually rpm or rad/s .. |
November 21, 2023, 03:29 |
Rep Power: 5 |
If I try an opposite rpm (-1000) or an opposite reference direction, ie. (0 -1 0) instead of (0 1 0), then the run crashes.
However I have just found a way to do it: invert the fan axis (not the reference axis) and then invert the blade angle. I use openFoam v2212 Furthermore do you know how to write the effective drag, effective lift, min/max(AOA) and rotation direction in an output file? Last edited by AlxB; November 21, 2023 at 06:40. Reason: found a kind of answer to my problem |
June 14, 2024, 09:30 |
Time saver!
#4 | |
Flavio Martins
Rep Power: 8 |
I just tried this and it worked. I expent half of my day trying to reverse the rotor rotational direction.
ERROR: Flow direction on the boundaries must not be tangential to the boundary. | turbomax | CFX | 3 | October 27, 2024 07:19 |
Flow simulation moving in the reverse direction | samoalfred | STAR-CCM+ | 1 | February 9, 2016 04:40 |
Flow simulation moving in the reverse direction | samoalfred | Main CFD Forum | 0 | February 6, 2016 20:27 |
[ICEM] Changing edge direction | la7low | ANSYS Meshing & Geometry | 2 | June 7, 2010 14:26 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
