Any tutorial for moveDynamic mesh using Finite Element Method in foam-extend?
Old   November 9, 2023, 02:21
Default Any tutorial for moveDynamic mesh using Finite Element Method in foam-extend?
M. Montero
be_inspired is on a distinguished road
Hi all,
I am trying to simulate a cylinder while moving with a prescribed movement. While having a y+ mesh around 100, the FV methods based on the laplacian solver work (OpenFoam 2212 and a proper diffusivity law), but with a y+ mesh around 1, the same approach does not work and I get inverted cells at first deltaT.
According to the foam-extend 4.1 release notes:
* Finite Element Method with support for polyhedral meshes This is
mainly used in mesh deformation and over the last 15 years it has
proven vastly superior to all other dynamic mesh methods.
But, I am not able to find any tutorial in the repository to use it, neither in foam-extend 4.1 of 5.0.
I have seen some tutorials using RBF or mesquite, but if I am not wrong, they are fv methods.
Best Regards
M.
be_inspired is offline   Reply With Quote
New Book Proposal: Project-based Finite Element Method Dr Youssef Hafez Main CFD Forum 1 January 1, 2023 12:45
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 12:32
How can be calculate a surface integral in the finite element method? HectorRedal Main CFD Forum 3 March 13, 2015 09:25
autoPatch error, mesh quality related...? Alexvader OpenFOAM 0 October 6, 2011 18:57
