MultiphaseEulerFoam: issues with Temperatur
Old   July 25, 2023, 08:36
Default MultiphaseEulerFoam: issues with Temperatur
Myth
Mytho is on a distinguished road
Hello everybody,
Currently, I'm working on a two-phase simulation using the multiphaseEulerFoam solver. However, I've run into some issues with the temperature field.
My main objective is to simulate a water wall boiling process. To achieve this, I need to specify a given Heat Flux at the Wall and a specific Mass Rate/Velocity at the inlet. The initial temperature of the water liquid is 385.15K. Unfortunately, as you can see in the picture, the temperature rises very slowly (Tmax) and drops (Tmin) below the initial temperature, which is not expected. Eventually, after a few time steps, the simulation crashes without any specific error message.
I've been trying to find the source of the problem, but so far, I haven't been successful. I would be incredibly grateful if anyone with expertise could help me diagnose potential sources of error in my setup.To aid in the analysis, I have attached the relevant case parameters and and a part of the log file.
In the simulation, I am using a helix tube with the following dimensions: length of 8m, height of 0.5m, and a tube diameter of 0.0145m. Prior to the simulation, I performed a checkMesh, and fortunately, all aspects seemed satisfactory. The mesh consists of approximately 4 million cells with a length of 1mm and 3 fine layers at the wall.
If anyone could provide assistance with this issue, I would greatly appreciate it.
Thank you.
Mytho is offline   Reply With Quote
Old   November 15, 2023, 08:05
Default solved?
Jo Mar
KingKraut is on a distinguished road
you did not attach pictures, or gave information about the version of OpenFOAM you used - if you were a bit more specifif, I think people would much rather comment a little... ;-)
Anyway, how did you manage to get multiphaseEulerFoam running *with* temperature dependence? To me it seems that the temperature dependence is not actually implemented in the solver... :-(
I am using OpenFOAM-v2306.
Thanks a lot in advance for your answer.
kraut
KingKraut is offline   Reply With Quote
Old   May 14, 2024, 22:32
van wang
vanvan1 is on a distinguished road
hi, do you solve this problem? i met this problems too, i add q
into T.liquid but tempreture is going down
vanvan1 is offline   Reply With Quote
issues with multiphaseEulerFoam solver for binary simulation in fluidized beds Esmaeel OpenFOAM Running, Solving & CFD 6 June 7, 2023 02:41
OpenFOAM 10 - multiphaseEulerFoam compilation error palmera2 OpenFOAM Programming & Development 1 February 16, 2023 09:24
MaxwellStefanFourier in multiphaseEulerFoam? deepblue17 OpenFOAM Running, Solving & CFD 2 October 14, 2021 06:32
Convergence issues for Flat plate with sharp edge rajnarayang FLUENT 3 June 20, 2017 13:02
Multigrid Stability Issues ThomasHermann SU2 1 November 5, 2014 17:18
