Removing Patches
Old   January 11, 2023, 09:43
Default Removing Patches
Kylian Keimel
KylianK is on a distinguished road
Hello everyone,
Iīm relatively new to OpenFoam and canīt find the problem in the following. I used the annual thermal mixer tutorial to simulate an axial compressor. When I run the simulation I get the following message and it stops immediately:
--> FOAM Warning :
From function const Foam::HashTable<Foam::List<int>, Foam::word>& Foam:olyBoundaryMesh::groupPatchIDs() const
in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 473
Removing patchGroup 'inlet' which clashes with patch 1 of the same name.
--> FOAM Warning :
Removing patchGroup 'outlet' which clashes with patch 2 of the same name.
AMI: Creating addressing and weights between 27432 source faces and 27432 target faces
AMI: Patch source sum(weights) min/max/average = 1, 1.4106, 1.00004
AMI: Patch target sum(weights) min/max/average = 0, 1.41657, 1.00004
I found similar problems here in the forum, which then were solved by checking the createPatchDict...but I canīt find that one. Does somebody know where I can look for errors?
Thanks to whoever will answer!
KylianK is offline   Reply With Quote
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
Problem using AMI vinz OpenFOAM Running, Solving & CFD 298 November 13, 2023 09:19
[Other] [cfMesh] Error when creating AMI patches propeller gabrielfelix OpenFOAM Community Contributions 2 July 5, 2023 21:54
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." lethu OpenFOAM Meshing & Mesh Conversion 1 June 3, 2020 08:49
Possible bug with stitchMesh and cyclics in OpenFoam Jack001 OpenFOAM Pre-Processing 0 May 21, 2016 09:00
