Two fuel injection for combustion inside a LPRE using sprayFoam. |
October 27, 2022, 04:14 |
Kanishque Kumar
Rep Power: 6 |
I'm trying to simulate spray break-up and combustion of two hypergolic propellants using sprayFoam. The main issue I'm facing is, 'how to model the injection of two fuel sprays'. My injection surface needs to be a disc and the spray should come out as a cone. For this I'm confused whether I should coneNozzleInjection or coneInjection. (you may suggest any other injection model, that I might have missed to search upon). And how can I model injection of the two fluids from different surfaces. It would be a great help, as I'm stuck on this part of modelling for more than a week |
November 11, 2022, 06:32 |
Rep Power: 12 |
I'm actually interested as well if sprayFoam has the capability to model multiple fuels. Did you figure this out?
water injection error (modify the position of water injection) | wjchoi | Main CFD Forum | 0 | January 17, 2022 08:17 |
Modelling of air assisted fuel injection system | JVJ | CONVERGE | 1 | October 6, 2021 13:50 |
trying to simulate the compression stroke inside cylinder, using UDF for injection | mayur | Fluent UDF and Scheme Programming | 15 | December 16, 2013 05:30 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 02:30 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 13:37 |
