No MRF models present No finite volume options present
Old   October 9, 2022, 08:32
Default No MRF models present No finite volume options present
Dai Li
daily_7 is on a distinguished road
Hello!
I am new to openFoam. I am simulating the flow of liquid in a pipe like the shape of 'Y'. I converted icem mesh to openfoam. I'm using simpleFoam solver but i got the error,
daili@daili-virtual-machine:~/daily/pipe$ simpleFoam
| \\ / O peration | Version: 5.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 5.x-7f7d351b741b
Exec : simpleFoam
Date : Oct 09 2022
Time : 19:16:26
Host : "daili-virtual-machine"
PID : 49074
I/O : uncollated
Case : /home/daili/daily/pipe
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
field p tolerance 0.01
field U tolerance 0.001
field "(k|epsilon)" tolerance 0.001
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model realizableKE
RAS
RASModel realizableKE;
turbulence on;
printCoeffs on;
A0 4;
C2 1.9;
sigmak 1;
sigmaEps 1.2;
Starting time loop
Time = 1e-05
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0972003, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0972498, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.072886, No Iterations 2
GAMG: Solving for p, Initial residual = 1, Final residual = 1.4352e+82, No Iterations 1000
time step continuity errors : sum local = 1.17854e+77, global = -1.10524e+77, cumulative = -1.10524e+77
smoothSolver: Solving for epsilon, Initial residual = 0.00592644, Final residual = 5.29249e+49, No Iterations 1000
bounding epsilon, min: -1.09254e+75 max: 5.66035e+75 average: 4.99357e+71
smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0230622, No Iterations 2
bounding k, min: -1.42321e+81 max: 2.62943e+83 average: 3.03619e+80
ExecutionTime = 19.56 s ClockTime = 20 s
Time = 2e-05
smoothSolver: Solving for Ux, Initial residual = 0.0332246, Final residual = 0.00312569, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 0.0329014, Final residual = 0.00312953, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 0.0743329, Final residual = 0.00671912, No Iterations 1
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
#4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/daili/OpenFOAM/OpenFOAM-5.x/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
#8 Foam::fvMatrix<double>::solve() in "/home/daili/OpenFOAM/OpenFOAM-5.x/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
#9 ? in "/home/daili/OpenFOAM/OpenFOAM-5.x/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? in "/home/daili/OpenFOAM/OpenFOAM-5.x/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
daily_7 is offline   Reply With Quote
Old   October 10, 2022, 06:18
Yann
Yann will become famous soon enoughYann will become famous soon enough
In simpleFoam, you can use MRF models, or finite volume options (fvOptions) to define additional models such as porous zones, source terms, etc...
These messages are just stating there is no MRF model and fvOptions for the case you are running, which is perfectly normal as long as you were not trying to use such models.
On your first iteration you get this:
Pressure is diverging and you have continuity error: most probably something is wrong with your boundary conditions.
Regards,
Yann
Yann is offline   Reply With Quote
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
interFoam: No finite volume options present mehdinekooee OpenFOAM Running, Solving & CFD 4 July 15, 2014 12:05
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
The aspect ratio of the volume elements in Finite Volume Method CharlieTan84 Main CFD Forum 3 August 28, 2012 03:34
