June 30, 2022, 20:24 |
time step continuity error, SSG model
Haroun
Rep Power: 4 |
Dear Foamers,
I have a case that I want to solve using a LRR and a SSG turbulence model. The LRR case is running fine but I keep getting a time step continuity error for the SSG model.
They all gives me the same error message : Code:
time step continuity errors : sum local = 1.293e+65, global = 5.57821e+54, cumulative = 1.54365e+55 [2] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [2] #1 Foam::sigFpe::sigHandler(int) at ??:? [2] #2 ? in /lib64/libpthread.so.0 [2] #3 Foam::tmp<Foam::GeometricField<Foam::innerProduct<Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>::value_type, Foam::Vector<double> >::type, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::surfaceInterpolationScheme<Foam::Vector<double> >::dotInterpolate<Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) at ??:? [2] #4 Foam::surfaceInterpolationScheme<Foam::Vector<double> >::dotInterpolate(Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) const at ??:? [2] #5 ? at gaussLaplacianSchemes.C:? [2] #6 Foam::fv::gaussLaplacianScheme<double, Foam::SymmTensor<double> >::gammaSnGradCorr(Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? [2] #7 Foam::fv::gaussLaplacianScheme<double, Foam::SymmTensor<double> >::fvmLaplacian(Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? [2] #8 Foam::fv::laplacianScheme<double, Foam::SymmTensor<double> >::fvmLaplacian(Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? [2] #9 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, Foam::SymmTensor<double> >(Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? [2] #10 Foam::RASModels::SSG<Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::correct() at ??:? [2] #11 ? at ??:? [2] #12 __libc_start_main in /lib64/libc.so.6 [2] #13 ? at ??:? [n075:76036] *** Process received signal *** [n075:76036] Signal: Floating point exception (8) [n075:76036] Signal code: (-6) [n075:76036] Failing at address: 0x11fc85d00012904 [n075:76036] [ 0] /lib64/libpthread.so.0(+0xf630)[0x7fa7b8f19630] [n075:76036] [ 1] /lib64/libpthread.so.0(raise+0x2b)[0x7fa7b8f194fb] [n075:76036] [ 2] /lib64/libpthread.so.0(+0xf630)[0x7fa7b8f19630] [n075:76036] [ 3] /home/018860125/OpenFOAM/OpenFOAM-common/platforms/linux64GccDPInt64Opt/lib/libfiniteVolume.so(_ZN4Foam26surfaceInterpolationSchemeINS_6VectorIdEEE14dotInterpolateINS_14GeometricFieldIS2_NS_13fvsPatchFieldENS_11surfaceMeshEEEEENS_3tmpINS5_INS_12innerProductINT_10value_typeES2_E4typeES6_S7_EEEERKSB_RKNS5_IS2_NS_12fvPatchFieldENS_7volMeshEEERKNS9_INS5_IdS6_S7_EEEE+0x7ee)[0x7fa7bf57097e] [n075:76036] [ 4] /home/018860125/OpenFOAM/OpenFOAM-common/platforms/linux64GccDPInt64Opt/lib/libfiniteVolume.so(_ZNK4Foam26surfaceInterpolationSchemeINS_6VectorIdEEE14dotInterpolateERKNS_14GeometricFieldIS2_NS_13fvsPatchFieldENS_11surfaceMeshEEERKNS4_IS2_NS_12fvPatchFieldENS_7volMeshEEE+0x72)[0x7fa7bf572732] [n075:76036] [ 5] /home/018860125/OpenFOAM/OpenFOAM-common/platforms/linux64GccDPInt64Opt/lib/libfiniteVolume.so(+0x165143d)[0x7fa7bfa5343d] [n075:76036] [ 6] /home/018860125/OpenFOAM/OpenFOAM-common/platforms/linux64GccDPInt64Opt/lib/libfiniteVolume.so(_ZN4Foam2fv20gaussLaplacianSchemeIdNS_10SymmTensorIdEEE15gammaSnGradCorrERKNS_14GeometricFieldINS_6VectorIdEENS_13fvsPatchFieldENS_11surfaceMeshEEERKNS5_IdNS_12fvPatchFieldENS_7volMeshEEE+0x1e8)[0x7fa7bfa6c6d8] [n075:76036] [ 7] /home/018860125/OpenFOAM/OpenFOAM-common/platforms/linux64GccDPInt64Opt/lib/libfiniteVolume.so(_ZN4Foam2fv20gaussLaplacianSchemeIdNS_10SymmTensorIdEEE12fvmLaplacianERKNS_14GeometricFieldIS3_NS_13fvsPatchFieldENS_11surfaceMeshEEERKNS5_IdNS_12fvPatchFieldENS_7volMeshEEE+0x1a8)[0x7fa7bfa6f778] [n075:76036] [ 8] /home/018860125/OpenFOAM/OpenFOAM-common/platforms/linux64GccDPInt64Opt/lib/libfiniteVolume.so(_ZN4Foam2fv15laplacianSchemeIdNS_10SymmTensorIdEEE12fvmLaplacianERKNS_14GeometricFieldIS3_NS_12fvPatchFieldENS_7volMeshEEERKNS5_IdS6_S7_EE+0x60)[0x7fa7bfa69830] [n075:76036] [ 9] /home/018860125/OpenFOAM/OpenFOAM-common/platforms/linux64GccDPInt64Opt/lib/libfvOptions.so(_ZN4Foam3fvm9laplacianIdNS_10SymmTensorIdEEEENS_3tmpINS_8fvMatrixIT_EEEERKNS_14GeometricFieldIT0_NS_12fvPatchFieldENS_7volMeshEEERKNS9_IS6_SB_SC_EE+0x134)[0x7fa7be032fb4] [n075:76036] [10] /home/018860125/OpenFOAM/OpenFOAM-common/platforms/linux64GccDPInt64Opt/lib/libincompressibleTurbulenceModels.so(_ZN4Foam9RASModels3SSGINS_29IncompressibleTurbulenceModelINS_14transportModelEEEE7correctEv+0x36a)[0x7fa7bc4f055a] [n075:76036] [11] pimpleFoam[0x429542] [n075:76036] [12] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7fa7b8b5e555] [n075:76036] [13] pimpleFoam[0x42ce3c] [n075:76036] *** End of error message *** Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2106 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application pimpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 30; deltaT 1e-2; writeControl adjustableRunTime; writeInterval 0.25; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression on; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep no; maxCo 0.6; maxDeltaT 1.0e-3; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2106 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; //CrankNicolson 0.7; } gradSchemes { default leastSquares; //Gauss linear limited 0.5; } divSchemes { default none; div(phi,U) Gauss linearUpwindV grad(U); div(phi,h) Gauss linearUpwind default; div(phi,e) Gauss linearUpwind default; div(phi,k) Gauss upwind default; div(phi,epsilon) Gauss upwind default; div(phi,R) Gauss linearUpwind default; div(phiv,p) Gauss linearUpwind default; div(phi,K) Gauss linearUpwind default; div(phi,Ekp) Gauss linearUpwind default; div(R) Gauss linear; div((nuEff*dev2(T(grad(U))))) Gauss linear; div((nu*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear limited 0.5; } interpolationSchemes { default linear; } snGradSchemes { default limited 0.5; } wallDist { method meshWave; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2106 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p//p_rgh { solver PCG; preconditioner DIC; tolerance 1e-4; relTol 0.1; } pFinal//p_rghFinal { solver PCG; preconditioner DIC; tolerance 1e-4; relTol 1e-8; } "(U|h|e|k|epsilon|R)" { solver PBiCG; preconditioner DILU; tolerance 1e-3; relTol 0.1; } "(U|h|e|k|epsilon|R)Final" { solver PBiCG; preconditioner DILU; tolerance 1e-2; relTol 1e-8; } } PIMPLE { momentumPredictor yes; nOuterCorrectors 50; nCorrectors 3; nNonOrthogonalCorrectors 2; pRefCell 0; pRefValue 1.0e5; turbOnFinalIterOnly no; outerCorrectorResidualControl { p { tolerance 1e-4; relTol 0.1; } U { tolerance 1e-4; relTol 0.1; } h { tolerance 1e-3; relTol 0.1; } T { tolerance 1e-3; relTol 0.01; } "(k|epsilon|R.*)" { tolerance 1e-10; relTol 0.01; } } } relaxationFactors { equations { U 0.7; k 0.7; epsilon 0.3; R 0.7; p 0.3; } } // ************************************************************************* // I read on an other post that it can be due to the boundary condition. I checked it and everything seems correct to me, if the LRR case can run with those BCs I don't see why the SSG couldn't ? |
December 13, 2023, 06:12 |
ASR
Rep Power: 3 |
Hi Haroun,
Have you managed to solve this issue. I am having similar problems with SSG model for transient solver (I'm using interFOAM with PIMPLE) and I initialised my solution from a converged and stable SST K-Omega simulation |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 17, 2019 00:12 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 06:28 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 06:49 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 08:47 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
