April 29, 2022, 08:04 |
FOAM FATAL ERROR: bad size -1954478958
Yuanwei Cao
Rep Power: 9 |
Dear Foamers,
recently, I am simulating a bubble rising with compressibleInterIsoFoam (v2006). After some time, I got an error: FOAM FATAL ERROR: bad size -1954478958. But I do not know why. Could anyone give me some hints? |
May 2, 2022, 12:37 |
Julio Pieri
Rep Power: 9 |
There are many possible reasons for this error. Have searched this forum? look here bad setSize while building up a too large mesh ?
February 13, 2023, 15:02 |
Rep Power: 13 |
In my case, I encountered the same error but solved it by decomposing my problem with more MPI processes.
April 19, 2024, 06:16 |
Taihang Zhu
Rep Power: 8 |
Hello, I was having a similar problem running OpenFOAM 10 with 256 cores. It was solved when I switched OpenFOAM 10 to OpenFOAM 9..... I don't know if this is just a coincidence but you may have a try when facing this problem.
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." | lethu | OpenFOAM Meshing & Mesh Conversion | 1 | June 3, 2020 08:49 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 11:51 |
Incompatible dimensions for operation | ruben23 | OpenFOAM Running, Solving & CFD | 2 | June 12, 2015 05:14 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
