wrong forceCoeffs for standart airFoil2D simpleFoam case
Old   April 23, 2022, 05:22
Default wrong forceCoeffs for standart airFoil2D simpleFoam case
Reptider is on a distinguished road
Hello, FOAMers. I try to calculate Cd и Cl coeffs for airFoil2D using simpleFoam (standard case) OpenFOAM v1912. I'm based on this thread: Problem in simpleFoam airFoil2D forceCoeffs.
controlDict data:
|  \\    /   O peration     | Version:  v1912                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     simpleFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         500;
deltaT          1;
writeControl    timeStep;
writeInterval   50;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
functions
	forces
	type forceCoeffs;
	libs ( "libforces.so" );
        // Store and write volume field representations of forces and moments
        writeFields     yes;
        // Centre of rotation for moment calculations
        CofR            (0 0 0);
	patches ( walls );
	p p;
	U U;
	rho rhoInf;
	log true;
	rhoInf 1.225;
	liftDir (-0.139173 0.990268 0);
	dragDir (0.990268 0.139173 0);
	pitchAxis (0 0 1);
	magUInf 26;
	lRef 1;
	Aref 1;
So I get other drag and lift coeffs (Cd = 0514466, Cl = 1.7015) as opposed to the above thread.
SIMPLE solution converged in 313 iterations
forceCoeffs forces execute:
    Coefficients
        Cd       : 0.0514466	(pressure: 0.0433982	viscous: 0.00804843)
        Cs       : 5.33394e-17	(pressure: 5.38832e-17	viscous: -5.43772e-19)
        Cl       : 1.7015	(pressure: 1.70157	viscous: -6.34881e-05)
        CmRoll       : -0.0425376	(pressure: -0.0425392	viscous: 1.5872e-06)
        CmPitch       : 98.4881	(pressure: 98.4116	viscous: 0.0764274)
        CmYaw       : 0.00128616	(pressure: 0.00108495	viscous: 0.000201211)
        Cd(f)    : -0.0168143
        Cd(r)    : 0.0682609
        Cs(f)    : 0.00128616
        Cs(r)    : -0.00128616
        Cl(f)    : 99.3388
        Cl(r)    : -97.6373
End
I understand that a lot of time has passed from 2012 year and methods of calcutating could be change. I have tried this standard case with help OpenFOAMv9 and got similar results.
Could you give me advise? Why do results differ from old ones? Tnx in advanсe.
Reptider is offline   Reply With Quote
simpleFoam airfoil case not running for RAS JETZ OpenFOAM Running, Solving & CFD 5 August 28, 2021 14:19
simpleFoam - wrong results? Zibi OpenFOAM Running, Solving & CFD 26 October 9, 2020 13:21
udf error srihari FLUENT 1 October 31, 2016 15:18
SimpleFoam converges to wrong values eruwaedhiel OpenFOAM Running, Solving & CFD 3 July 1, 2015 04:01
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
