OpenFOAM v2012 tutorial issue
Old   February 15, 2021, 01:49
Default OpenFOAM v2012 tutorial issue
Ken Johnson
Kendawgg22 is on a distinguished road
I have been having this problem getting OpenFOAM to run tutorial 2.2 which is a flow around a cylinder. At first I used openfoam v1912. I was given these command lines to download the files needed in order for the tutorial to work sudo apt-get install build-essential flex bison cmake zlib1g-dev libboost-system-dev libboost-thread-dev libopenmpi-dev openmpi-bin gnuplot libreadline-dev libncurses-dev libxt-dev. I got it to generate the blockMesh but it would not run the simulation when I typed potentialFoam.
I upgraded to openfoam v2012 hoping that maybe that would fix it and now it won't even generate the blockMesh anymore.
I attached images below.
Kendawgg22 is offline   Reply With Quote
Getting Started with OpenFOAM wyldckat OpenFOAM 26 June 21, 2024 07:54
OpenFOAM tutorial 2.2 question? Kendawgg22 OpenFOAM Running, Solving & CFD 11 February 11, 2021 02:09
[Tutorials] Video Tutorial Owls for OpenFOAM postprocessing gregor OpenFOAM Community Contributions 0 November 14, 2019 05:25
Dam break tutorial - transportProperties issue Guimloute OpenFOAM Running, Solving & CFD 4 June 27, 2017 12:52
Tutorial Not Running In OpenFOAM H0T_S0UP OpenFOAM 2 January 20, 2015 17:58
