February 10, 2021, 13:20 |
Adding pressure-dependent heat source
Jonathan Wells
Rep Power: 6 |
I'm working on a problem that requires me to modify the heat source in the flow field. For instance, I am wondering how to change the rho*r term in Eqn. 15 at this page:
http://https://cfd.direct/openfoam/energy-equation/ It says the term, rho*r, is a heat source, where r is any specific heat source. I'd like to make this heat source a function of pressure everywhere in the domain. Is this possible with a fvOptions code? I've seen fvOptions examples using a temperature hot spot, but never one that includes an actual term for the energy equation. I would like to do this in rhoPimpleFoam if possible, where the energy equation is: Code:
( fvm::ddt(rho, he)+fvm::div(phi, he)+fvc::ddt(rho, K)+fvc::div(phi, K)+(he.name()=="e" ? fvc::div(fvc::absolute(phi/fvc::interpolate(rho), U), p, "div(phiv,p)") :-dpdt) - fvm::laplacian(turbulence->alphaEff(), he) = =fvOptions(rho, he) ) |
February 10, 2021, 16:32 |
Herpes Free Engineer
Rep Power: 13 |
Yes, you can create your own fvOptions to affect this governing equation through the "fvOptions(rho, he)" term.
Please have a look at the available fvOptions here: https://develop.openfoam.com/Develop...ources/derived . Find the most similar one to your case, and try to modify it accordingly.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
February 10, 2021, 20:36 |
#3 | |
Jonathan Wells
Rep Power: 6 |
For instance, my equation is an isentropic relationship between pressure and heat, so how would I include the mach number and temperature? What about using the pressure from the current and previous time steps? Does anyone have experience with this? |
February 11, 2021, 04:27 |
Rep Power: 13 |
Might help? There are a bit more involved fvOptions here, where temperature field has been used as well: https://develop.openfoam.com/Develop...dels/fvOptions
February 12, 2021, 16:39 |
#5 | |
Jonathan Wells
Rep Power: 6 |
Those actually help quite a bit. I'm essentially using as many examples as I can to fill in the parts that I need. Having said that, I need to apply a minimum value to the field I compute. Is there some ability to do something like if (field < 0.2) { field = 0.2; } to replace only values within the newly-computed field that meet the if statement? I know I can use a nested for loop, but I doubt that's the correct way to do it. |
February 12, 2021, 16:46 |
Rep Power: 13 |
- maybe `Foam::volScalarField& Foam::bound(volScalarField& vsf, const dimensionedScalar& lowerBound)`, like in `bound(k_, this->kMin_);` of `kEpsilon.C`? - not the second parameter is not `scalar` but `dimensionedScalar`.
February 12, 2021, 17:11 |
Jonathan Wells
Rep Power: 6 |
Should it still be a dimensionedScalar if I'm computing a non-dimensional quantity? My thought is to do mach number like this. From looking at other files, it seems like this goes in the constructor in the .c file, so I was planning to implement it like this:
option(sourceName, modelType, dict, mesh), UName_(coeffs_.getOrDefault<word>("U", "U")), a0_ ( dimensionedScalar ( dimLength/dimTime, coeffs_.getCheckOrDefault<scalar> ( "a0", 329.204, scalarMinMax::ge(SMALL) // do I need this line? ) ) ), mach_ ( dimensionedScalar ( coeffs_.getCheckOrDefault<scalar> ( "mach", U/a0, // can I put an eqn in the constructor? <bound mach number here?> ) ) ) |
February 13, 2021, 11:15 |
#8 | |
Rep Power: 13 |
I don't think you can compile the `mach_` like the above. Could you please explain us (but like explaining to a person with a two-digit IQ) what you want to do as a pseudo-code, if possible? Many thanks
February 13, 2021, 11:39 |
#9 | |
Jonathan Wells
Rep Power: 6 |
My goal is to add a source term to the rhoPimpleFoam energy equation using fvOptions. This source term is an isentropic relation between pressure and heat, in the form I was thinking that I would add this by doing the following: 1. compute speed of sound in the flow field 2. compute mach number in the flow field 3. compute the above equation I'm unsure how to do this, because I have EXTREMELY little experience with OpenFOAM (I've run some tutorials and I have a rhoPimpleFoam case of my flow field that runs). After some reading online, I am sure that using fvOptions is the correct way forward, but I don't have the experience to modify existing options without asking a lot of questions. I'm using a lot of the existing fvOptions codes to help guide me, but the process is slow and painful. I'm still unsure if my approach is reasonable. |
February 13, 2021, 13:46 |
#10 |
Michael Alletto
Rep Power: 16 |
just out of interest, can you provide a reference for the equation. |
February 13, 2021, 13:58 |
#11 |
Jonathan Wells
Rep Power: 6 |
February 13, 2021, 15:15 |
#12 |
Rep Power: 13 |
Let's see what we can do during the next week. (At least something for you to progress further rather than a complete solution.)
February 14, 2021, 12:03 |
#13 |
Michael Alletto
Rep Power: 16 |
You can use a coded fvOption to include your source term. https://www.openfoam.com/documentati...ces-coded.html
And you also need to decide your equation by dt to insert it into the energy equation. Did you check the dimensions of the source term in the energy equation |
February 14, 2021, 12:12 |
#14 | |
Jonathan Wells
Rep Power: 6 |
February 14, 2021, 12:32 |
#15 |
Michael Alletto
Rep Power: 16 |
Maybe it's better if you post the final equation you want to implement. This would lead you faster to your goal.
February 14, 2021, 13:05 |
#16 | |
Jonathan Wells
Rep Power: 6 |
I see that the units are and So, the units for the first term, and therefore all terms, is correct? My equation, modified using perfect gas assumption, is for which the units are So, if I were to insert my equation into the openfoam energy equation as it looks like the units are correct, unless I've made a mistake somewhere. |
February 15, 2021, 13:50 |
#17 |
Jonathan Wells
Rep Power: 6 |
Here are my first attempts at modifying the variableHeatTransfer fvOptions files to do what I am trying to do. I'm sure there are mistakes, and probably a lot of places where I have misunderstood what the code is doing. To anyone willing to look it over and check it out, I'd be extremely thankful.
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | www.openfoam.com \\/ M anipulation | ------------------------------------------------------------------------------- Copyright (C) 2011-2015 OpenFOAM Foundation Copyright (C) 2020 OpenCFD Ltd. ------------------------------------------------------------------------------- License This file is part of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. Class Foam::fv::variableHeatTransfer Group grpFvOptionsSources Description Applies an additional source term to the rhoPimpleFoam energy equation via the fvOptions. The source term is computed using Shapiro's influence coefficient table as an isentropic relationship between heat and Static Pressure, where \vartable a0 | Speed of Sound Cp0 | Specific Heat Capacity (constant pressure) mach | Mach Number \endvartable ------------------- this section requires modification ------------------------- Required fields: \verbatim \endverbatim Usage Minimal example by using \c constant/fvOptions: \verbatim variableHeatTransfer1 { // Mandatory entries (unmodifiable) type variableHeatTransfer; // Optional entries (runtime modifiable) UNbr U; PNbr p; rhoNbr rho; Cp 1005; R 287.058; a0 329.204; // Mandatory/Optional (inherited) entries ... } \endverbatim where the entries mean: \table Property | Description | Type | Reqd | Dflt type | Type name: variableHeatTransfer | word | yes | - UNbr | Name of velocity field | word | no | U PNbr | Name of pressure field | word | no | p rhoNbr | Name of density field | word | no | rho Cp | Specific Heat Capacity | scalar | no | 0 R | Universal Gas Constant | scalar | no | 0 a0 | Speed of Sound | scalar | no | 0 \endtable See also - Foam::fv::interRegionHeatTransferModel - Foam::fv::tabulatedHeatTransfer - Foam::fv::tabulatedNTUHeatTransfer - Foam::fv::constantHeatTransfer SourceFiles variableHeatTransfer.C \*---------------------------------------------------------------------------*/ #ifndef variableHeatTransfer_H #define variableHeatTransfer_H #include "fvOption.H" #include "autoPtr.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // namespace Foam { namespace fv { /*---------------------------------------------------------------------------*\ Class variableHeatTransfer Declaration \*---------------------------------------------------------------------------*/ class variableHeatTransfer : public option { // Private Data //- Name of operand neighbour velocity field word UName_; //- Speed of Sound dimensionedScalar a0_; //- Specific Heat Capacity const dimensionedScalar Cp0_; //- Mach Number autoPtr<volScalarField> mach_; //- Universal Gas Constant const dimensionedScalar R_; public: //- Runtime type information TypeName("variableHeatTransfer"); // Constructors //- Construct from dictionary variableHeatTransfer ( const word& name, const word& modelType, const dictionary& dict, const fvMesh& mesh ); //- No copy construct variableHeatTransfer(const variableHeatTransfer&) = delete; //- No copy assignment void operator=(const variableHeatTransfer&) = delete; //- Destructor virtual ~variableHeatTransfer() = default; // Member Functions //- Compute the Mach Number for the entire field virtual void heatCompute ( const dimensionedScalar& a0, const dimensionedScalar& Cp0, const dimensionedScalar timeStepSize_, const volScalarField& rho, fvMatrix<scalar>& eqn, const label fieldi ); // Public Functions //- Read dictionary virtual bool read(const dictionary& dict); }; // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // } // End namespace fv } // End namespace Foam // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #endif // ************************************************************************* // Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | www.openfoam.com \\/ M anipulation | ------------------------------------------------------------------------------- Copyright (C) 2011-2016 OpenFOAM Foundation Copyright (C) 2020 OpenCFD Ltd. ------------------------------------------------------------------------------- License This file is part of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. \*---------------------------------------------------------------------------*/ #include "variableHeatTransfer.H" #include "turbulentFluidThermoModel.H" #include "addToRunTimeSelectionTable.H" // * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * // namespace Foam { namespace fv { defineTypeNameAndDebug(variableHeatTransfer, 0); addToRunTimeSelectionTable(option, variableHeatTransfer, dictionary); } } // * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * // Foam::fv::variableHeatTransfer::variableHeatTransfer ( const word& name, const word& modelType, const dictionary& dict, const fvMesh& mesh ) : option(sourceName, modelType, dict, mesh), UName_(coeffs_.getOrDefault<word>("UNbr", "U")), PName_(coeffs_.getOrDefault<word>("PNbr","p")), rhoName_(coeffs_.getOrDefault<word>("rhoNbr","rho")), Cp0_ ( dimensionedScalar ( sqr(dimLength)/sqr(dimTime)/dimTemperature, coeffs_.getCheckOrDefault<scalar> ( "Cp0", 1005.0, scalarMinMax::ge(SMALL) ) ) ), R_ ( dimensionedScalar ( sqr(dimLength)/sqr(dimTime)/dimTemperature, coeffs_.getCheckOrDefault<scalar> ( "R", 287.058, scalarMinMax::ge(SMALL) ) ) ), a0_ ( dimensionedScalar ( dimLength/dimTime, coeffs_.getCheckOrDefault<scalar> ( "a0", 329.204, scalarMinMax::ge(SMALL) ) ) ), { } // * * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * // void Foam::fv::variableHeatTransfer::heatCompute() { const auto& nbrMesh = mesh_.time().lookupObject<fvMesh>(nbrRegionName()); const auto& UNbr = nbrMesh.lookupObject<volVectorField>(UName_); const auto& PNbr = nbrMesh.lookupObject<volScalarField>(PName_); const auto& rhoNbr = nbrMesh.lookupObject<volScalarField>(rhoName_); tmp<volScalarField> Mach(mag(UNbr)/a0_); // Need to bound the lower limit of mach number here... eqn += fvm::ddt(((PNbr*timeStepSize_)*(1-(Mach*Mach))*Cp0_)/(1.4*(Mach*Mach)*rho*R_)); } bool Foam::fv::variableHeatTransfer::read(const dictionary& dict) { if (interRegionHeatTransferModel::read(dict)) { coeffs_.readIfPresent("UNbr", UName_); coeffs_.readIfPresent("a0", a0_); coeffs_.readIfPresent("Cp0", Cp0_); coeffs_.readIfPresent("M", mach_); coeffs_.readIfPresent("R", R_); return true; } return false; } // ************************************************************************* // |
February 16, 2021, 07:20 |
#18 |
Michael Alletto
Rep Power: 16 |
Did you try to compile your fvOption and execute it within your solver?
February 16, 2021, 10:46 |
#19 |
Jonathan Wells
Rep Power: 6 |
I haven't yet, mostly because I was trying to find out how to properly bound the mach number before starting on that.
I also am not sure how to compile these, since I've never done it. Do I have to rebuild all of OpenFOAM or just the files I changed? |
February 17, 2021, 02:56 |
#20 |
Michael Alletto
Rep Power: 16 |
Yes you need to compile only your fvOption. You'll find plenty of tutorials by googling how to write something new by Coping an existing file in OF
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 04:52 |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 17:05 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 06:35 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 07:42 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
