problem running parallel simulation
Old   January 21, 2021, 06:42
Default problem running parallel simulation
denis08 is on a distinguished road
Hello everyone!
I have a problem running a parallel simulation.
In the first steps of my case, I do the following instructions:
-surfaceFeatureExtract
-blockMesh
-refineMesh
-snappyHexMesh
-setFields
-decomposePar
I have no problem with these steps.
Then, i type: "mpirun -np 4 interFoam -parallel"
But here, the simulation encounters a problem and send the following message:
"No MRF models present
No finite volume options present
[DESKTOP-5F3QC7E:02342] 3 more processes have sent help message help-btl-vader.txt / cma-permission-denied
[DESKTOP-5F3QC7E:02342] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 8.39055e-06, No Iterations 14
time step continuity errors : sum local = 6.2272e-12, global = 1.00873e-13, cumulative = 1.00873e-13
Starting time loop
forces forces:
Not including porosity effects
Flow time scale min/max = 0.00243343, 1
Smoothed flow time scale min/max = 0.00243343, 1
Time = 1
PIMPLE: iteration 1
smoothSolver: Solving for alpha.water, Initial residual = 0, Final residual = 0, No Iterations 1
Phase-1 volume fraction = 0 Min(alpha.water) = 0 Max(alpha.water) = 0
MULES: Correcting alpha.water
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[10340,1],0]
Exit code: 144"
Does anyone knows what i do wrong?
denis08 is offline   Reply With Quote
Old   January 21, 2021, 16:38
Federico Zabaleta
fedez91 is on a distinguished road
Does the simulation runs in serial mode? Have to tried just running interFoam without decomposing the domain?
fedez91 is offline   Reply With Quote
Old   January 21, 2021, 17:12
Petros Ampatzidis
petros is on a distinguished road
Hi denis08,
You provide very little information about your case so it is not easy to guess. However, from the top of my head I would say to run refineMesh and snappyHexMesh like is shown below in order to overwrite the existing polyMesh:
refineMesh -overwrite
snappyHexMesh -overwrite
petros is offline   Reply With Quote
Old   May 27, 2022, 02:56
Anis Hanani
Anis Hanani is on a distinguished road
Hello.
I am currently facing the same error. Have you found a solution for this?
Thank you.
Anis Hanani is offline   Reply With Quote
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
Problem with running foam-extend 4.0 in parallel in Ubuntu 18.04 amuzeshi OpenFOAM Running, Solving & CFD 4 September 27, 2019 10:16
running multiple parallel cases in openfoam slows the simulation kkpal OpenFOAM Running, Solving & CFD 2 August 21, 2015 12:08
Problem running parallel. Hernán STAR-CCM+ 1 December 23, 2009 13:04
Problem running parallel Hernán Main CFD Forum 0 December 22, 2009 05:36
