Could not find mandatory etc entry (mode=ugo) 'controlDict' |
January 19, 2021, 17:08 |
Rep Power: 6 |
hello
I have just installed OFv2012 on ubuntu 20.04 LTS WSL2. I went through the install process (https://www.openfoam.com/download/in...ry-windows.php) but it fails at the final validation Here is the error message: # ~/tutorials/incompressible/icoFoam/cavity$ blockMesh --> FOAM FATAL ERROR : Could not find mandatory etc entry (mode=ugo) 'controlDict' # would it be anyone who knows what could be wrong ? thank you |
July 9, 2021, 10:52 |
A
Rep Power: 8 |
Hi Sir, did you find out the solution for this issue
May 20, 2022, 07:50 |
Avdeev Evgeniy
Rep Power: 21 |
Topic is old, but for anyone who will meet same problem in future.
I had this error/problem when trying to run blockMesh under root user. Problem solved just by running blockMesh under regular (non-root) user. |
Foam::findEtcFile() : could not find mandatory file 'controlDict' | AndersO | OpenFOAM | 10 | October 18, 2022 13:17 |
FOAM FATAL ERROR in Foam::findEtcFile() : could not find mandatory file | makaveli_lcf | OpenFOAM Running, Solving & CFD | 15 | November 18, 2015 20:00 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 13:38 |
Converting Starccm+ mesh | Ladnam | OpenFOAM | 0 | September 14, 2011 07:30 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
