December 11, 2020, 20:44 |
Overset 3D mesh case crash at start
TWB
Rep Power: 19 |
I'm trying to run a Overset 3D mesh case. I used the fvScheme and fvSolution from the tutorials. However, when I tried to run it, it crashes at the 1st time step. The output is shown below. In this case, there's no mesh motion and I'm using a steady state solver overSimpleFoam. Previously, I tried a 2D case and it worked. Any suggestion? Starting time loop forces forces: rho: rhoInf Freestream density (rhoInf) set to 1.2 Not including porosity effects forceCoeffs ForceCoeffs: rho: rhoInf Freestream density (rhoInf) set to 1.2 Not including porosity effects Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.00262235, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.00253801, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.00361835, No Iterations 3 -------------------------------------------------------------------------- An MPI process has executed an operation involving a call to the "fork()" system call to create a child process. Open MPI is currently operating in a condition that could result in memory corruption or |
Overset mesh for Fluid Structure Interaction in OpenFOAM | Thaw Tar | OpenFOAM Programming & Development | 4 | August 25, 2023 18:56 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets | Struggle_Achieve | OpenFOAM Meshing & Mesh Conversion | 3 | June 17, 2019 10:29 |
help with setting up overset mesh | calv | FLUENT | 0 | May 14, 2017 10:12 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 15:53 |
