Export matrix of coefficients into a .txt file
Old   September 8, 2020, 06:45
Default Export matrix of coefficients into a .txt file
AndreaCFD is on a distinguished road
Dear members,
I am new to OpenFoam and I am trying to modify the icoFoam solver to export the matrix of coefficients UEqn into a text file readable by Matlab.
What is the easiest way? I am really new to C++ too and I can't compile the solver without errors. May you help?
Thanks in advance,
Andrea
AndreaCFD is offline   Reply With Quote
Old   September 8, 2020, 09:17
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by AndreaCFD View Post
Dear members,
Thanks in advance,
Andrea
Changing any solver to simply dump out a matrix of coefficients is really not a good idea. It falls apart when you want to try the same for a different field, for a slightly different solver, or when you upgrade versions. Provided that you do not yet wish to examine the coefficients for the pressure equation, you can implement your writing routine as a matrix constraint that does not modify the coefficients, but only prints them out. If you are new to OpenFOAM and to C++, it will not be completely easy in any case. You need to walk the OpenFOAM sparse matrix storage, and also handle processor-to-processor connections.
If you want a bit of code to start from, I have revived some old code (temporarily?) that probably does most of what you want, or at least can give you some ideas. It dumps coefficients in a MatrixMarket format. Although it is from 2018, it should compile OK with OpenFOAM-v1906,1912,2006. I cannot remember if there is anything missing or broken in it.
https://develop.openfoam.com/modules...src/dumpMatrix
olesen is offline   Reply With Quote
Old   September 9, 2020, 22:28
Duc Anh
anhkenyt is on a distinguished road
Dear members,
Thanks in advance,
Andrea
Hi Andrea,
To start, the document below will give you some simple suggestions
https://www.foamacademy.com/wp-conte...2018matrix.pdf
anhkenyt is offline   Reply With Quote
Old   September 10, 2020, 13:30
Originally Posted by anhkenyt View Post
Hi Andrea,
Dear Van Duc Anh,
thanks for the useful documentation. I tried to write the code as follows:
fvVectorMatrix UEqn
			fvm::laplacian(nu, U)-
			fvm::div(phi_zero, U)-
			fvc::div(phi,U_zero)
		label NC = mesh.nCells(); //Number of cells
		simpleMatrix<scalar> A(NC); //Coeff.matrix
		// Initialization of matrix
		for(label i=0; i<NC; i++)
				A.source()[i] = 0.0;
				for(label j=0; j<NC; j++)
						A[i][j] = 0.0;
		// Assigning diagonal coefficients
				A[i][i] = UEqn.diag()[i];
		// Assigning off-diagonal coefficients
		for(label faceI=0; faceI<UEqn.lduAddr().lowerAddr().size(); faceI++)
				label l = UEqn.lduAddr().lowerAddr()[faceI];
				label u = UEqn.lduAddr().upperAddr()[faceI];
				A[l][u] = UEqn.upper()[faceI];
				A[u][l] = UEqn.upper()[faceI];
		// Assigning contribution from BC
		forAll(U.boundaryField(), patchI)
				const fvPatch &pp = U.boundaryField()[patchI].patch();
				forAll(pp, faceI)
						label cellI = pp.faceCells()[faceI];
						A[cellI][cellI] += UEqn.internalCoeffs()[patchI][faceI];
						A.source()[cellI] += UEqn.boundaryCoeffs()[patchI][faceI];
		Info << "\n==Coefficients of Matrix A=="<< endl;
						Info<< A[i][j] << " ";
				Info<< A.source()[i] << endl;
But I get an error I am not able to understand:
[/CODE] error: no match for ‘operator+=’ (operand types are ‘double’ and ‘Foam::Vector<double>’)
A[cellI][cellI] += UEqn.internalCoeffs()[patchI][faceI]; [/CODE]
How do I overcome it?
Thanks in Advance
Andrea
Old   September 11, 2020, 03:55
Domenico Lahaye
dlahaye is on a distinguished road
https://openfoamwiki.net/images/1/18/GdbOF-Manual.pdf
dlahaye is offline   Reply With Quote
Old   August 10, 2022, 14:54
TommyJ is on a distinguished road
@Mr. Olesen, The link you provided is broken. Was there a problem with the code?
@Mr. Lahaye, can gdbOf print the coefficients in a parallel run?
TommyJ is offline   Reply With Quote
Old   August 11, 2022, 03:51
Domenico Lahaye
@tommyJ: not sure.
Possibly yes: gdb seems to support parallel runs.
Possibly no: in parallel, OpenFoam stores the matrix per processor in separate (diagonal and off-diagonal blocks), and the macros provided in OFgdb might not extend to this situation. Possibly OFgdb can be extended to treat this case.
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
A CFX-POST error (ver 14.5.7) wangyflp88 CFX 2 July 22, 2017 01:17
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
