August 25, 2020, 12:57 |
reactingFoam transsonic option
Patti Michelle Sheaffer
Rep Power: 8 |
Has anyone used the reactingFoam "transsonic" option and gotten it to work? It seems like a pretty robust solver, but in particular the BC's might be difficult to set up. Are input/output totalpressure and velocity-zerogradient are what are required?
https://www.openfoam.com/documentati...ctingFoam.html |
August 25, 2020, 15:59 |
I am wondering about the same. It might make sense to
1/3: run rhoSimpleFoam / rhoPimple using the transonic option: see tutorials and Chapter 16 of Moukalled e.a. for setting up the bc; 2/3: run reactingFoam with the combustion switched off (see e.g. initialization of SandiaD tutorial on how to switch off the combustion). Similar (same?) results as in Step 1/3 are expected; 3/3: run reactingFoam with the combustion switched on; |
August 25, 2020, 16:13 |
#3 | |
Rep Power: 8 |
That would be good. I did notice that reactingFoam generates some reasonable-looking shock structures without the transsonic option; although, I don't think I had the BC's set up correctly (should be stagnation pressure at the inlet, total pressure at the outlet). Thanks for mentioning the SandiaD tutorial - it's nice how the adjust the run to develop the flowfield. I'll have to test that and see how well it works. |
August 26, 2020, 17:08 |
Rep Power: 8 |
Well, it's a little off-topic but, basically, chemical reactions can be very fast and can dominate flowfield values by orders of magnitude. Physically, you can make a fully-developed flowfield, then turn-on chemistry, and obtain a deflagration wave or a deflagration/detonation transition, both of which can easily crash solvers. Also, the flowfield with chemistry is often very different from a flowfield without chemistry. (For instance, a parcel of 5% hydrogen in air will detonate when ignition is applied.) So unless the chemistry is slow/simple/highly-dilute, calculating a no-chemistry flowfield beforehand wouldn't be of much use.
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 03:54 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 14:32 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
