How to add forces to flow
Old   August 19, 2020, 12:52
Exclamation How to add forces to flow
Tom Waits
TomWaits is on a distinguished road
Hi All,
I am interested in adding a force F(x,y,z) distributed over some area in my domain over the entire simulation time. What is the best way of doing this?
There are certain fvOptions that already do a constrained version of this - take for example actuationDiskSource which applies a constant force to a circular region. I was wondering whether openfoam/any literature has generalized this to applying a non-constant force over a non-circular region.
Many thanks in advance,
Tom Waits
TomWaits is offline   Reply With Quote
Old   August 19, 2020, 22:26
Claudio Boezio
Ship Designer is on a distinguished road
If the force you need to be applied acts on a boundary patch, it's probably the easiest if you convert it to pressure and choose a proper boundary condition for it. If the force is distributed over the area, maybe there's a way to use a nonuniform internalField. If the area is internal to the domain, you might need to create a baffle.
Ship Designer is offline   Reply With Quote
Old   August 20, 2020, 07:55
Tom Waits
Thank you very much for your response, I will give these options a test. The area will be internal to my domain and the force will be a 2-D function.
Old   August 24, 2020, 17:51
Luis Eduardo
lebc is on a distinguished road
Hi Tom,
You may want to take a look at radialActuationDiskSource: https://github.com/OpenFOAM/OpenFOAM...tionDiskSource
It uses a radial distribution of Thrust, you can change it as you like to use your own Thrust distribution function.
Best Regards,
Luis
lebc is offline   Reply With Quote
Review: Reversed flow CRT FLUENT 1 May 7, 2018 06:36
Flow dependent forces lichmaster OpenFOAM Programming & Development 4 July 19, 2011 05:48
Add inflation on a laminar flow xyq102296 ANSYS Meshing & Geometry 0 October 21, 2010 08:37
Forces in compressible internal flow zabar OpenFOAM 6 April 26, 2010 12:21
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
