July 27, 2020, 17:45 |
overInterDyMFoam stops without error message
Isnard Baptiste
Rep Power: 6 |
Hello everybody,
I have been using openfoam for a short time and I want to perform multiphase simulations using the oversetmesh function. I wish to make a 3D simulation of a buoy floating in the presence of waves. I have no problem to simulate waves alone, to simulate the buoy that floats without overset or to simulate the buoy that floats with the overset in 2D. On the other hand, when I want to perform the simulation with waves and the overset in 3D the solver overInterDyMFoam stops without any error message. I don't understand why! I have the impression that there is a problem in the zoneID identification during the use of 6DOF but I am not sure. I'm attaching all the files I use for this simulation. I'm running the following commands: blockMesh snappyHexMesh mergeMeshes .../sphere -overwrite checkMesh setFields overInterDyMFoam In the attachement, the file sphere/constant/triSurface is empty here to have the good size of file but on my computer there are two stl file: one sphere od 1cm diameter and one oversetPatch which is also a sphere so snappy is acting between both sphere. I don't understand where my mistake is I hope someone will have an answer for me. Thank you in advance for your answers and for your time. Have a nice day. |
September 2, 2020, 06:05 |
Isnard Baptiste
Rep Power: 6 |
The answer to my problem was that the boundary condition on the bottom for the velocity have to be a slip condition.
Simulation stops after writing each timestep although stopAt sets to end time | shimakasaei | OpenFOAM Running, Solving & CFD | 0 | September 18, 2019 13:44 |
open foam stops running simulation - reactingFoam | Vittorio94 | OpenFOAM Running, Solving & CFD | 0 | June 12, 2019 12:51 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 06:28 |
Stops responding after adaptation command! | diamondx | FLUENT | 0 | July 26, 2011 22:52 |
case stops when fuel injection starts | Antony | Siemens | 1 | August 7, 2005 14:42 |
