turbulentDFSEMInlet for LES imulation for naca0012 aerofoil
Old   October 22, 2019, 23:03
Default turbulentDFSEMInlet for LES imulation for naca0012 aerofoil
zein elserfy
zeinelserfy is on a distinguished road
I am trying to use turbulentDFSEMInlet at the inlet for simulation flow over aerofoil (The domain is attached below
domain size ( 5c upstream, 10 c downstream and spanwise 0.1 c ) c is the chord length (c=0.3048 m)
inlet condition
    inlet
        type            turbulentDFSEMInlet;
        delta           2;
        nCellPerEddy    3;
        mapMethod       nearestCell;
        R               uniform (0.5 0 0 0.5 0 0.5);
        U               uniform (71.3 0 0);
        L               uniform 0.17;
        value           uniform (0 0 0);
the turbulenceProperties file
| \\	  /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:	www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format	ascii;
    class	dictionary;
    location    "constant";
    object	turbulenceProperties;
simulationType LES;
LES
LESModel        kEqn;
turbulence	on;
printCoeffs     on;
delta           vanDriest;
vanDriestCoeffs
    delta           cubeRootVol;
    cubeRootVolCoeffs
     	deltaCoeff	1;
    Aplus           26;
    Cdelta          0.158;
After running the simulation for the first time step, the only 5 eddy is generated at the inlet
Starting time loop
Courant Number mean: 0.000449944 max: 0.0468918
deltaT = 1.2e-07
Time = 1.2e-07
PIMPLE: iteration 1
Turbulent DFSEM patch: inlet seeded 5 eddies with total volume 0.0519412
smoothSolver:  Solving for Ux, Initial residual = 3.70186e-06, Final residual = 5.58285e-09, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 2.02752e-06, Final residual = 7.27509e-08, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.000726498, Final residual = 8.2538e-08, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.999923, Final residual = 1.86291, No Iterations 1000
GAMG:  Solving for p, Initial residual = 0.0407024, Final residual = 0.0142608, No Iterations 1000
time step continuity errors : sum local = 9.09561e-07, global = -1.32729e-08, cumulative = -1.32729e-08
GAMG:  Solving for p, Initial residual = 0.0149751, Final residual = 0.00549751, No Iterations 1000
GAMG:  Solving for p, Initial residual = 0.0055067, Final residual = 0.00168609, No Iterations 1000
time step continuity errors : sum local = 1.49201e-07, global = -4.97451e-09, cumulative = -1.82474e-08
Does anyone have used this boundary condition for external flow case ?
zeinelserfy is offline   Reply With Quote
Old   December 4, 2020, 11:50
Haoran Shi
Haoran is on a distinguished road
Maybe it is too late. I met the same problem. And I found that even though the OpenFOAM website says we can set constant values for U, L and R, but it does not work. For my case, U and L can be set as constant, but for R, I have to use the mapping method, otherwise it will stop at the first iter. And the deltaT is extremly small.
Haoran is offline   Reply With Quote
les inlet conditions, openfoam 1906, turbulentdfseminlet
2D Aerofoil with rotating cylinders - Help & Advice! Bluejay OpenFOAM 1 December 31, 2012 05:40
