alpha.water-question in the application of interIsoFoam
Old   September 25, 2019, 08:48
Default alpha.water-question in the application of interIsoFoam
philip lu
philiplu is on a distinguished road
hello,
some results of certain cells in certain time step of an (random) interIsoFoam-application:
alpha.water is 0, but
U is not 0 e.g. (0 0 -2.31698)
thus by assuming that "alpha.water=0" refers to e.g. air (i.e. no water), I wonder if U = e.g. (0 0 -2.31698) namely not U = 0, is logical
thank you in advance
philiplu is offline   Reply With Quote
Old   September 25, 2019, 10:01
Rishikesh
mrishi is on a distinguished road
U is not meant to be zero if alpha.water is 0. U is the velocity shared by the mixture of phases, so its value tells you value of whatever composition of mixture you have in a given cell. In this case it would correspond to velocity of air.
mrishi is offline   Reply With Quote
Old   September 25, 2019, 20:49
Default thank you, mrishi
philip lu
Hello, mrishi,
thank you for the reply and the clear explanation.
thanks, regards
SimpleFoam cannot open include file Marija OpenFOAM Running, Solving & CFD 1 October 28, 2020 11:35
Adapt Fluent Mesh to weirOverflow tutorial WaterHammer1985 OpenFOAM Running, Solving & CFD 2 July 5, 2018 03:37
Ansys Licence Serve on Ubuntu 16.04 LTS david.pasquale ANSYS 2 January 20, 2017 12:52
Automotive Application: Aero Balance Question plucas OpenFOAM Running, Solving & CFD 0 December 21, 2012 12:46
CHANNEL FLOW: a question and a request Carlos Main CFD Forum 4 August 23, 2002 06:55
