Boundary Conditions for Turbulent Quantities
Like Tree1Likes
  • 1 Post By yambanshee
Old   July 25, 2019, 03:47
Default Boundary Conditions for Turbulent Quantities
Mondal131211's Avatar
Mondal
Mondal131211 is on a distinguished road
Hi all,
I have preliminary knowledge about turbulence modeling. Currently, I am trying to reproduce a result.
"Natural convection flow along a heated vertical plate"
Please have a look in the picture attached here. Everything is fine when dealing with laminar flow. But the problem arises when I try to introduce turbulence the simulation crushed. I can understand this may be because of applying the wrong BC of turbulence modeling. As I said before, I am like new in turbulence modeling. In my model, a heated plate is placed just middle of an external domain. The external domain should behave like atmosphere. In order to solve the problem, I am using buoyantPimpleFoam (solver of OpenFOAM 3.0.1). Can anyone suggest me what will be the realistic atmospheric BC for this problem? I am continuously struggling with that. This might be a simple solution for someone. Anyways, please comment or give me any thread that will help me to solve this problem.
Note that: Picture attached here for the laminar case.
Cheers
Razon
Mondal131211 is offline   Reply With Quote
Old   July 26, 2019, 03:39
Zander Meiring
yambanshee is on a distinguished road
I think this post would be more applicable in the pre-processing forum.
I would suggest using the inletOutlet boundary condition, where the inlet value is based on a turbulence intensity and length scale. For appropriate calculators, see this tool: https://www.cfd-online.com/Tools/turbulence.php
The inletOutlet BC is handy in that for outflow, a zeroGradient condition is applied, but for inflow a value is specified. This normally leads to a stable solution, and makes a reasonable amount of sense in the physical world.
Mondal131211 likes this.
yambanshee is offline   Reply With Quote
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
