buoyantBoussinesqPimpleFoam natural convection case courant number blows up
Old   July 16, 2019, 20:12
Default buoyantBoussinesqPimpleFoam natural convection case courant number blows up
Cham Yang Han
cfd1609496 is on a distinguished road
Hi Foamers,
the solution was all fun and games until stop running after 1020s because the courant number blows up.
Below is my geometry, right arrow shows heatedWall(315celsius), left arrow shows wall (300celsius). Top and bottom big box are 'atmosphere' i trying to simulate, i may not catch the correct b.c. yet tho:https://drive.google.com/open?id=1G4...53g986ClGk3f2g
fvSchemes:
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss linearUpwind grad(U);
    div(phi,T)      Gauss limitedLinear 1;
    turbulence      Gauss limitedLinear 1;
    div(phi,k)      $turbulence;
    div(phi,epsilon) $turbulence;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fvSolution:
solvers
    p_rgh
        solver          GAMG;
        smoother        DIC;
        tolerance       1e-8;
        relTol          0.01;
    p_rghFinal
        $p_rgh;
        relTol          0;
    "(U|T|k|epsilon)"
        solver          PBiCGStab;
        preconditioner  DILU;
        tolerance       1e-8;
        relTol          0.01;
    "(U|T|k|epsilon)Final"
        $T;
        relTol          0;
PIMPLE
    momentumPredictor no;
    nNonOrthogonalCorrectors 0;
    nCorrectors       2;
    pRefCell          0;
    pRefValue         0;
relaxationFactors
    equations
        ".*"   1.0;
from time 0 to 540 it was fine, should be acceptable convection look like this below...but start from somewhere 600+ the result seems weird and until last 1020s whole domain shows full velocity....???
time 540s:
https://drive.google.com/open?id=1ad...u5DYM4xcj-XPzh
time 640s:
https://drive.google.com/open?id=1-e...E1f9Dpi9Yyfr3T
time 960s:
https://drive.google.com/open?id=1Bf...Mzh1iaLDHPQIf6
time 1020s:
https://drive.google.com/open?id=1n9...50kGgpv8NjOQVf
would be so kind of you to help gives some idea to me
Many thanks,
Cham
cfd1609496 is offline   Reply With Quote
Old   July 17, 2019, 21:48
Obi
obiscolly50 is on a distinguished road
Are you using fixed or adjustable timestep?
obiscolly50 is offline   Reply With Quote
Old   July 18, 2019, 02:43
Cham Yang Han
should be fixed right?
application     buoyantBoussinesqPimpleFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         2000;
deltaT          0.005;
writeControl    runTime;
writeInterval   20;
purgeWrite      0;
writeFormat     binary;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
functions
    #includeFunc residuals
    #includeFunc streamlines
Old   July 18, 2019, 07:59
Obi
Not necessarily. You can try using an adjustable time step and set the maximum courant number (maxCo) to 1. Check some of the openfoam tutorials on how to do this.
Old   July 18, 2019, 08:13
Cham Yang Han
Thank you Obi! I will try it out first and see how
Old   July 22, 2019, 05:47
Cham Yang Han
Hi Obi,
i tried with adjustable timestep with max Co number= 1 and even with max Co number= 3...the solver stop somewhere around 60s and 40s. This means theres something wrong with the fvSchemes and fvSolutions, or maybe the /0 files?
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
